[pdal-commits] [PDAL/PDAL] aede8e: Split inferWriterDriver into two
GitHub noreply at github.com
Thu May 1 14:48:39 PDT 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: aede8eccc62a900fb67014f6e98f4bc9cc818a54
      https://github.com/PDAL/PDAL/commit/aede8eccc62a900fb67014f6e98f4bc9cc818a54
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2014-05-01 (Thu, 01 May 2014)
  Changed paths:
    M include/pdal/StageFactory.hpp
    M src/StageFactory.cpp
    M src/kernel/Support.cpp
  Log Message:
Similar to #340, the 2-argument infer{Reader|Writer}Driver might try to
do too much by both modifying options and finding the correct driver.
This patch splits the inferWriterDriver into two pieces. The
inferWriterDriver part does just that, while a new method,
inferWriterOptionsChanges, modifies an options object based upon a given
filename.
  Commit: b4edd34d5bbe06c9bcd220e021495368ce95955a
      https://github.com/PDAL/PDAL/commit/b4edd34d5bbe06c9bcd220e021495368ce95955a
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #341 from gadomski/feature/split-infer-writer-driver
Compare: https://github.com/PDAL/PDAL/compare/6e216d464791...b4edd34d5bbe
More information about the pdal-commits mailing list
