[pdal-commits] [PDAL/PDAL] aede8e: Split inferWriterDriver into two
GitHub
noreply at github.com
Tue May 6 06:34:30 PDT 2014
Branch: refs/heads/issues/339-remove-interleaving
Home: https://github.com/PDAL/PDAL
Commit: aede8eccc62a900fb67014f6e98f4bc9cc818a54
https://github.com/PDAL/PDAL/commit/aede8eccc62a900fb67014f6e98f4bc9cc818a54
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2014-05-01 (Thu, 01 May 2014)
Changed paths:
M include/pdal/StageFactory.hpp
M src/StageFactory.cpp
M src/kernel/Support.cpp
Log Message:
Similar to #340, the 2-argument infer{Reader|Writer}Driver might try to
do too much by both modifying options and finding the correct driver.
This patch splits the inferWriterDriver into two pieces. The
inferWriterDriver part does just that, while a new method,
inferWriterOptionsChanges, modifies an options object based upon a given
filename.
Commit: b4edd34d5bbe06c9bcd220e021495368ce95955a
https://github.com/PDAL/PDAL/commit/b4edd34d5bbe06c9bcd220e021495368ce95955a
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #341 from gadomski/feature/split-infer-writer-driver
Commit: 2826c9c5166062a35085ab64ec282994488fcaa9
https://github.com/PDAL/PDAL/commit/2826c9c5166062a35085ab64ec282994488fcaa9
Author: Andrew Bell <andrew.bellia at gmail.com>
Date: 2014-05-02 (Fri, 02 May 2014)
Changed paths:
M include/pdal/Log.hpp
M include/pdal/Stage.hpp
R include/pdal/StageBase.hpp
M include/pdal/StageInfo.hpp
M include/pdal/Writer.hpp
M include/pdal/drivers/caris/CloudReader.hpp
M include/pdal/drivers/oci/common.hpp
M src/CMakeLists.txt
M src/Filter.cpp
M src/MultiFilter.cpp
M src/PipelineWriter.cpp
M src/Reader.cpp
M src/Stage.cpp
R src/StageBase.cpp
M src/Writer.cpp
M src/drivers/oci/Writer.cpp
M src/filters/Scaling.cpp
M src/filters/Selector.cpp
M test/unit/PipelineManagerTest.cpp
Log Message:
Merge StageBase into Stage.
Commit: 1fdaf6bcf67af57f76fb2752d7ebb57ed0aa6d34
https://github.com/PDAL/PDAL/commit/1fdaf6bcf67af57f76fb2752d7ebb57ed0aa6d34
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M src/Filter.cpp
M src/Reader.cpp
M src/Stage.cpp
R src/StageBase.cpp
M src/Writer.cpp
Log Message:
Merge pull request #344 from PDAL/no-stage-base
Commit: 7d15d72d6591116e97f14913ebd54e15f67cf90b
https://github.com/PDAL/PDAL/commit/7d15d72d6591116e97f14913ebd54e15f67cf90b
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M include/pdal/kernel/Translate.hpp
M src/kernel/Translate.cpp
Log Message:
add decimation option to pdal translate
Commit: 20363588cc8ea65eda54032e28981c787e726a3d
https://github.com/PDAL/PDAL/commit/20363588cc8ea65eda54032e28981c787e726a3d
Changed paths:
Log Message:
Merge pull request #345 from chambbj/issues/43-pdal-translate-decimation
add decimation option to pdal translate for #43
Commit: f1af4610729ecb54999173877ae5539ee7287d93
https://github.com/PDAL/PDAL/commit/f1af4610729ecb54999173877ae5539ee7287d93
Author: Howard Butler <hobu.inc at gmail.com>
Changed paths:
M src/Filter.cpp
M src/Reader.cpp
M src/Stage.cpp
R src/StageBase.cpp
M src/Writer.cpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL into issues/339-remove-interleaving
Commit: cf1661b33baab4e1d6ceba17d55f283ffea5b9ab
https://github.com/PDAL/PDAL/commit/cf1661b33baab4e1d6ceba17d55f283ffea5b9ab
Changed paths:
A boost/import-pdal-boost.sh
R cleanup-cmake.sh
A cmake/examples/cleanup-cmake.sh
A cmake/examples/hobu-config.sh
A cmake/examples/hobu-windows.bat
A cmake/examples/mpg-config.bat
A cmake/examples/pramsey-config.sh
R hobu-config.sh
R hobu-windows.bat
R import-pdal-boost.sh
R mpg-config.bat
R pramsey-config.sh
Log Message:
remove user-specific config scripts into cmake/examples to clean up root directory #342
Commit: e22d4f77dce1fb3ba5baeabbb90d132167acd81f
https://github.com/PDAL/PDAL/commit/e22d4f77dce1fb3ba5baeabbb90d132167acd81f
Changed paths:
R cleanup-cmake.sh
R hobu-config.sh
R hobu-windows.bat
R mpg-config.bat
R pramsey-config.sh
Log Message:
Merge pull request #342 from PDAL/issues/342-no-more-top-level-config.sh
Remove personal configuration scripts
Commit: 04e4586a9755e2655e897de744f63308f818116f
https://github.com/PDAL/PDAL/commit/04e4586a9755e2655e897de744f63308f818116f
Date: 2014-05-06 (Tue, 06 May 2014)
Changed paths:
R cleanup-cmake.sh
R hobu-config.sh
R hobu-windows.bat
R mpg-config.bat
R pramsey-config.sh
Log Message:
Merge branch 'master' into issues/339-remove-interleaving
Compare: https://github.com/PDAL/PDAL/compare/60bc6eae4859...04e4586a9755
More information about the pdal-commits
