[pdal-commits] [PDAL/PDAL] a6e8bb: Improve the las reader's file signature error
GitHub
noreply at github.com
Tue May 6 11:08:33 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: a6e8bbc559dab83a3b21beec1841d82faf03421e
https://github.com/PDAL/PDAL/commit/a6e8bbc559dab83a3b21beec1841d82faf03421e
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2014-05-06 (Tue, 06 May 2014)
Changed paths:
M src/drivers/las/Reader.cpp
M test/unit/drivers/las/LasReaderTest.cpp
Log Message:
Catch the las header's invalid file signature error and improve the
error message, mostly by including the file name. In order to provide
the filename under more circumstances, set the "filename" option when
using the filename-only las::Reader constructor.
Fixes #277.
Commit: b275189cb00da21865f9942b2cb31972f9743226
https://github.com/PDAL/PDAL/commit/b275189cb00da21865f9942b2cb31972f9743226
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #351 from gadomski/issue/277-inval-file-sig
Compare: https://github.com/PDAL/PDAL/compare/3ec4c100c6dd...b275189cb00d
More information about the pdal-commits
