[pdal-commits] [PDAL/PDAL] b50358: Port QFIT Reader
GitHub
noreply at github.com
Wed Nov 19 12:12:13 PST 2014
Branch: refs/heads/move-las-driver
Home: https://github.com/PDAL/PDAL
Commit: b50358ec0c49f370c67121de584907187b51c1ea
https://github.com/PDAL/PDAL/commit/b50358ec0c49f370c67121de584907187b51c1ea
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-11-18 (Tue, 18 Nov 2014)
Changed paths:
R doc/stages/drivers.qfit.reader.rst
M doc/stages/index.rst
A doc/stages/readers.qfit.rst
M drivers/CMakeLists.txt
A drivers/qfit/CMakeLists.txt
A drivers/qfit/QfitReader.cpp
A drivers/qfit/QfitReader.hpp
M include/pdal/Drivers.hpp
R include/pdal/drivers/qfit/Reader.hpp
M src/CMakeLists.txt
M src/StageFactory.cpp
R src/drivers/qfit/Reader.cpp
M test/data/oracle/qfit-write.xml
M test/data/qfit/conversion.xml
M test/data/qfit/little-endian-conversion.xml
M test/data/qfit/pipeline.xml
M test/data/qfit/reader.xml
M test/unit/CMakeLists.txt
M test/unit/drivers/qfit/QFITReaderTest.cpp
Log Message:
Port QFIT Reader
Commit: 00cbb23ad9ac0cf50166c94b3092ce98f99695e2
https://github.com/PDAL/PDAL/commit/00cbb23ad9ac0cf50166c94b3092ce98f99695e2
Author: Howard Butler <howard at hobu.co>
Changed paths:
M include/pdal/Compression.hpp
M include/pdal/PointBuffer.hpp
M plugins/sqlite/drivers/SQLiteCommon.hpp
M plugins/sqlite/test/SQLiteTest.cpp
M test/unit/CompressionTest.cpp
Log Message:
Implement stream-based PointBuffer constructor and byte fetching #604
Commit: 1c1c68942be5bc86692b7f4d504d8686d556904e
https://github.com/PDAL/PDAL/commit/1c1c68942be5bc86692b7f4d504d8686d556904e
Changed paths:
A drivers/bpf/BpfHeader.cpp
A drivers/bpf/BpfHeader.hpp
A drivers/bpf/BpfReader.cpp
A drivers/bpf/BpfReader.hpp
A drivers/bpf/CMakeLists.txt
R include/pdal/drivers/bpf/BpfHeader.hpp
R include/pdal/drivers/bpf/BpfReader.hpp
R src/drivers/bpf/BpfHeader.cpp
R src/drivers/bpf/BpfReader.cpp
M test/data/bpf/bpf.xml
M test/unit/drivers/bpf/BPFTest.cpp
Log Message:
Port BPF driver
Commit: ffb18c4041688ff6bc887682ae843c09d6ea1cc0
https://github.com/PDAL/PDAL/commit/ffb18c4041688ff6bc887682ae843c09d6ea1cc0
Changed paths:
R doc/stages/drivers.text.writer.rst
A doc/stages/writers.text.rst
A drivers/text/CMakeLists.txt
A drivers/text/TextWriter.cpp
A drivers/text/TextWriter.hpp
R include/pdal/drivers/text/Writer.hpp
R src/drivers/text/Writer.cpp
M test/data/drivers/text-writer-csv.xml
M test/data/drivers/text-writer-geojson.xml
M test/data/drivers/text-writer-space-delimited.xml
M test/data/filters/colorize-multi.xml
M test/data/filters/decimate.xml
M test/data/icebridge/pipeline.xml
M test/data/sbet/pipeline.xml
M test/unit/drivers/text/TextWriterTest.cpp
Log Message:
Port Text Writer
Commit: 5fd33654d291499e149e968c1769b93594cb330c
https://github.com/PDAL/PDAL/commit/5fd33654d291499e149e968c1769b93594cb330c
Date: 2014-11-19 (Wed, 19 Nov 2014)
Changed paths:
Log Message:
Merge pull request #608 from PDAL/move-text-driver
Port Text Writer
Commit: 2dec7e4cc38c0c446a21b70630871a9197a320ac
https://github.com/PDAL/PDAL/commit/2dec7e4cc38c0c446a21b70630871a9197a320ac
Changed paths:
Log Message:
Merge pull request #607 from PDAL/move-bpf-driver
Port BPF driver
Commit: c1c28795827c66f699957c438e803744cfeb9cd8
https://github.com/PDAL/PDAL/commit/c1c28795827c66f699957c438e803744cfeb9cd8
Changed paths:
Log Message:
Merge pull request #606 from PDAL/move-qfit-driver
Port QFIT Reader
Commit: aa1371b4fe6410c463c1edcd93698cb5a9e75cdd
https://github.com/PDAL/PDAL/commit/aa1371b4fe6410c463c1edcd93698cb5a9e75cdd
Changed paths:
R doc/stages/drivers.buffer.reader.rst
A doc/stages/readers.buffer.rst
A drivers/buffer/BufferReader.hpp
R include/pdal/drivers/buffer/BufferReader.hpp
M src/kernel/Kernel.cpp
M src/kernel/Sort.cpp
M src/kernel/Translate.cpp
M test/unit/drivers/buffer/BufferTest.cpp
Log Message:
Port Buffer driver
Commit: 04bfcf3acef79dbf65874a0436f70a376dac0d8a
https://github.com/PDAL/PDAL/commit/04bfcf3acef79dbf65874a0436f70a376dac0d8a
Changed paths:
M doc/tutorial/writing.rst
Log Message:
update tutorial that uses BufferReader
Commit: 339c96fe8a23ef55c2d674213e9c581f84e9e165
https://github.com/PDAL/PDAL/commit/339c96fe8a23ef55c2d674213e9c581f84e9e165
Changed paths:
Log Message:
Merge pull request #611 from PDAL/move-buffer-driver
Move buffer driver
Commit: 7944e67ccb56cea6fe7925f75dc01660486a2e6c
https://github.com/PDAL/PDAL/commit/7944e67ccb56cea6fe7925f75dc01660486a2e6c
Changed paths:
M CMakeLists.txt
R doc/stages/drivers.csar.reader.rst
R doc/stages/drivers.csardb.reader.rst
R include/pdal/drivers/caris/CloudReader.hpp
M pdal_defines.h.in
R src/drivers/caris/CloudIterator.cpp
R src/drivers/caris/CloudReader.cpp
R src/drivers/caris/Utils.cpp
R src/drivers/caris/Utils.hpp
R src/drivers/caris/caris/caris_pc_wrapper.c
R src/drivers/caris/caris/caris_pc_wrapper.h
R src/drivers/caris/config.h
R src/drivers/caris/linkline.cpp
R src/drivers/caris/pdal_csar.cpp
R src/drivers/caris/pdal_csar.def
M src/pdal_config.cpp
R test/unit/drivers/caris/CarisReaderTest.cpp
Log Message:
remove caris driver (it will be posted to PDAL/Caris)
Commit: 1ad557f41f7db466bcbab98f4d081dda9e74b546
https://github.com/PDAL/PDAL/commit/1ad557f41f7db466bcbab98f4d081dda9e74b546
Changed paths:
M pdal_defines.h.in
Log Message:
remove unused definitions from pdal_defines
Commit: ede2fe6e57fb100b99810d0e974457b9a6331c44
https://github.com/PDAL/PDAL/commit/ede2fe6e57fb100b99810d0e974457b9a6331c44
Changed paths:
M plugins/pcl/kernel/Ground.cpp
M plugins/pcl/kernel/PCL.cpp
M plugins/pcl/kernel/Smooth.cpp
Log Message:
update PCL plugin to deal with BufferReader rename
Commit: 2ce42a9d46ef24413061359c78f9349d8a25cdb5
https://github.com/PDAL/PDAL/commit/2ce42a9d46ef24413061359c78f9349d8a25cdb5
Changed paths:
M CMakeLists.txt
M pdal_defines.h.in
Log Message:
Catch up LAS reorg to master
Commit: 4438f79f2e4dccb5f0d88ca343ba9b8ded6a1509
https://github.com/PDAL/PDAL/commit/4438f79f2e4dccb5f0d88ca343ba9b8ded6a1509
Changed paths:
M plugins/oci/CMakeLists.txt
M plugins/oci/test/OCITest.cpp
M plugins/pgpointcloud/CMakeLists.txt
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M plugins/sqlite/CMakeLists.txt
Log Message:
catch up LAS reorg to master
Compare: https://github.com/PDAL/PDAL/compare/71c7f5219d1b...4438f79f2e4d
More information about the pdal-commits
