[pdal-commits] [PDAL/PDAL] 9b916f: attribute filter depends on geos, so it should be ...
GitHub
noreply at github.com
Thu Nov 20 06:32:14 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 9b916f59f2e90516656829c00811c15b9427ad3a
https://github.com/PDAL/PDAL/commit/9b916f59f2e90516656829c00811c15b9427ad3a
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-11-19 (Wed, 19 Nov 2014)
Changed paths:
M CMakeLists.txt
M filters/CMakeLists.txt
R filters/attribute/AttributeFilter.cpp
R filters/attribute/AttributeFilter.hpp
R filters/attribute/CMakeLists.txt
M include/pdal/Filters.hpp
M plugins/CMakeLists.txt
A plugins/attribute/AttributeFilter.cpp
A plugins/attribute/AttributeFilter.hpp
A plugins/attribute/CMakeLists.txt
M scripts/ci/script.sh
M src/StageFactory.cpp
Log Message:
attribute filter depends on geos, so it should be a plugin filter
Commit: c99e3c12d11dd214e9b06b537b341ab4835ac72b
https://github.com/PDAL/PDAL/commit/c99e3c12d11dd214e9b06b537b341ab4835ac72b
Changed paths:
R plugins/attribute/AttributeFilter.cpp
R plugins/attribute/AttributeFilter.hpp
M plugins/attribute/CMakeLists.txt
A plugins/attribute/filters/AttributeFilter.cpp
A plugins/attribute/filters/AttributeFilter.hpp
Log Message:
move attribute sources and fix typos
Commit: 65b88b0e41bcb4c2f90c4b34d667b96f194e691e
https://github.com/PDAL/PDAL/commit/65b88b0e41bcb4c2f90c4b34d667b96f194e691e
Author: Howard Butler <howard at hobu.co>
Date: 2014-11-20 (Thu, 20 Nov 2014)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #619 from PDAL/convert-attribute-to-plugin
Convert attribute filter to plugin
Compare: https://github.com/PDAL/PDAL/compare/a66b5e28832d...65b88b0e41bc
More information about the pdal-commits
