[pdal-commits] [PDAL/PDAL] 850484: rename drivers as io
    GitHub
    noreply at github.com
    Thu Nov 20 18:29:45 PST 2014
  Branch: refs/heads/drivers-to-io
  Home:   https://github.com/PDAL/PDAL
  Commit: 85048470100acea1503a8360a74d83174f87ffc3
      https://github.com/PDAL/PDAL/commit/85048470100acea1503a8360a74d83174f87ffc3
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-11-20 (Thu, 20 Nov 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/reading.rst
    M doc/tutorial/writing.rst
    R drivers/CMakeLists.txt
    R drivers/bpf/BpfHeader.cpp
    R drivers/bpf/BpfHeader.hpp
    R drivers/bpf/BpfReader.cpp
    R drivers/bpf/BpfReader.hpp
    R drivers/bpf/CMakeLists.txt
    R drivers/buffer/BufferReader.hpp
    R drivers/faux/CMakeLists.txt
    R drivers/faux/FauxReader.cpp
    R drivers/faux/FauxReader.hpp
    R drivers/las/CMakeLists.txt
    R drivers/las/GeotiffSupport.cpp
    R drivers/las/GeotiffSupport.hpp
    R drivers/las/LasHeader.cpp
    R drivers/las/LasHeader.hpp
    R drivers/las/LasReader.cpp
    R drivers/las/LasReader.hpp
    R drivers/las/LasWriter.cpp
    R drivers/las/LasWriter.hpp
    R drivers/las/SummaryData.cpp
    R drivers/las/SummaryData.hpp
    R drivers/las/VariableLengthRecord.cpp
    R drivers/las/VariableLengthRecord.hpp
    R drivers/las/ZipPoint.cpp
    R drivers/las/ZipPoint.hpp
    R drivers/qfit/CMakeLists.txt
    R drivers/qfit/QfitReader.cpp
    R drivers/qfit/QfitReader.hpp
    R drivers/sbet/CMakeLists.txt
    R drivers/sbet/SbetCommon.cpp
    R drivers/sbet/SbetCommon.hpp
    R drivers/sbet/SbetReader.cpp
    R drivers/sbet/SbetReader.hpp
    R drivers/sbet/SbetWriter.cpp
    R drivers/sbet/SbetWriter.hpp
    R drivers/terrasolid/CMakeLists.txt
    R drivers/terrasolid/TerrasolidReader.cpp
    R drivers/terrasolid/TerrasolidReader.hpp
    R drivers/text/CMakeLists.txt
    R drivers/text/TextWriter.cpp
    R drivers/text/TextWriter.hpp
    A io/CMakeLists.txt
    A io/bpf/BpfHeader.cpp
    A io/bpf/BpfHeader.hpp
    A io/bpf/BpfReader.cpp
    A io/bpf/BpfReader.hpp
    A io/bpf/CMakeLists.txt
    A io/buffer/BufferReader.hpp
    A io/faux/CMakeLists.txt
    A io/faux/FauxReader.cpp
    A io/faux/FauxReader.hpp
    A io/las/CMakeLists.txt
    A io/las/GeotiffSupport.cpp
    A io/las/GeotiffSupport.hpp
    A io/las/LasHeader.cpp
    A io/las/LasHeader.hpp
    A io/las/LasReader.cpp
    A io/las/LasReader.hpp
    A io/las/LasWriter.cpp
    A io/las/LasWriter.hpp
    A io/las/SummaryData.cpp
    A io/las/SummaryData.hpp
    A io/las/VariableLengthRecord.cpp
    A io/las/VariableLengthRecord.hpp
    A io/las/ZipPoint.cpp
    A io/las/ZipPoint.hpp
    A io/qfit/CMakeLists.txt
    A io/qfit/QfitReader.cpp
    A io/qfit/QfitReader.hpp
    A io/sbet/CMakeLists.txt
    A io/sbet/SbetCommon.cpp
    A io/sbet/SbetCommon.hpp
    A io/sbet/SbetReader.cpp
    A io/sbet/SbetReader.hpp
    A io/sbet/SbetWriter.cpp
    A io/sbet/SbetWriter.hpp
    A io/terrasolid/CMakeLists.txt
    A io/terrasolid/TerrasolidReader.cpp
    A io/terrasolid/TerrasolidReader.hpp
    A io/text/CMakeLists.txt
    A io/text/TextWriter.cpp
    A io/text/TextWriter.hpp
    M plugins/greyhound/CMakeLists.txt
    R plugins/greyhound/drivers/Exchanges.hpp
    R plugins/greyhound/drivers/GreyhoundReader.cpp
    R plugins/greyhound/drivers/GreyhoundReader.hpp
    R plugins/greyhound/drivers/WebSocketClient.cpp
    R plugins/greyhound/drivers/WebSocketClient.hpp
    A plugins/greyhound/io/Exchanges.hpp
    A plugins/greyhound/io/GreyhoundReader.cpp
    A plugins/greyhound/io/GreyhoundReader.hpp
    A plugins/greyhound/io/WebSocketClient.cpp
    A plugins/greyhound/io/WebSocketClient.hpp
    M plugins/hexbin/CMakeLists.txt
    M plugins/icebridge/CMakeLists.txt
    R plugins/icebridge/drivers/Hdf5Handler.cpp
    R plugins/icebridge/drivers/Hdf5Handler.hpp
    R plugins/icebridge/drivers/IcebridgeReader.cpp
    R plugins/icebridge/drivers/IcebridgeReader.hpp
    A plugins/icebridge/io/Hdf5Handler.cpp
    A plugins/icebridge/io/Hdf5Handler.hpp
    A plugins/icebridge/io/IcebridgeReader.cpp
    A plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/mrsid/CMakeLists.txt
    R plugins/mrsid/drivers/MrsidReader.cpp
    R plugins/mrsid/drivers/MrsidReader.hpp
    A plugins/mrsid/io/MrsidReader.cpp
    A plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/CMakeLists.txt
    R plugins/nitf/drivers/MetadataReader.cpp
    R plugins/nitf/drivers/MetadataReader.hpp
    R plugins/nitf/drivers/NitfFile.cpp
    R plugins/nitf/drivers/NitfFile.hpp
    R plugins/nitf/drivers/NitfReader.cpp
    R plugins/nitf/drivers/NitfReader.hpp
    R plugins/nitf/drivers/NitfWriter.cpp
    R plugins/nitf/drivers/NitfWriter.hpp
    R plugins/nitf/drivers/nitflib.h
    R plugins/nitf/drivers/tre_plugins.cpp
    R plugins/nitf/drivers/tre_plugins.hpp
    A plugins/nitf/io/MetadataReader.cpp
    A plugins/nitf/io/MetadataReader.hpp
    A plugins/nitf/io/NitfFile.cpp
    A plugins/nitf/io/NitfFile.hpp
    A plugins/nitf/io/NitfReader.cpp
    A plugins/nitf/io/NitfReader.hpp
    A plugins/nitf/io/NitfWriter.cpp
    A plugins/nitf/io/NitfWriter.hpp
    A plugins/nitf/io/nitflib.h
    A plugins/nitf/io/tre_plugins.cpp
    A plugins/nitf/io/tre_plugins.hpp
    M plugins/oci/CMakeLists.txt
    R plugins/oci/drivers/OciCommon.cpp
    R plugins/oci/drivers/OciCommon.hpp
    R plugins/oci/drivers/OciReader.cpp
    R plugins/oci/drivers/OciReader.hpp
    R plugins/oci/drivers/OciWrapper.cpp
    R plugins/oci/drivers/OciWrapper.h
    R plugins/oci/drivers/OciWriter.cpp
    R plugins/oci/drivers/OciWriter.hpp
    A plugins/oci/io/OciCommon.cpp
    A plugins/oci/io/OciCommon.hpp
    A plugins/oci/io/OciReader.cpp
    A plugins/oci/io/OciReader.hpp
    A plugins/oci/io/OciWrapper.cpp
    A plugins/oci/io/OciWrapper.h
    A plugins/oci/io/OciWriter.cpp
    A plugins/oci/io/OciWriter.hpp
    M plugins/p2g/CMakeLists.txt
    R plugins/p2g/drivers/P2gWriter.cpp
    R plugins/p2g/drivers/P2gWriter.hpp
    A plugins/p2g/io/P2gWriter.cpp
    A plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/CMakeLists.txt
    R plugins/pcl/drivers/PCLVisualizer.cpp
    R plugins/pcl/drivers/PCLVisualizer.hpp
    R plugins/pcl/drivers/PcdCommon.cpp
    R plugins/pcl/drivers/PcdCommon.hpp
    R plugins/pcl/drivers/PcdReader.cpp
    R plugins/pcl/drivers/PcdReader.hpp
    R plugins/pcl/drivers/PcdWriter.cpp
    R plugins/pcl/drivers/PcdWriter.hpp
    R plugins/pcl/drivers/point_types.hpp
    A plugins/pcl/io/PCLVisualizer.cpp
    A plugins/pcl/io/PCLVisualizer.hpp
    A plugins/pcl/io/PcdCommon.cpp
    A plugins/pcl/io/PcdCommon.hpp
    A plugins/pcl/io/PcdReader.cpp
    A plugins/pcl/io/PcdReader.hpp
    A plugins/pcl/io/PcdWriter.cpp
    A plugins/pcl/io/PcdWriter.hpp
    A plugins/pcl/io/point_types.hpp
    M plugins/pcl/kernel/Ground.cpp
    M plugins/pcl/kernel/PCL.cpp
    M plugins/pcl/kernel/Smooth.cpp
    M plugins/pgpointcloud/CMakeLists.txt
    R plugins/pgpointcloud/drivers/PgCommon.hpp
    R plugins/pgpointcloud/drivers/PgReader.cpp
    R plugins/pgpointcloud/drivers/PgReader.hpp
    R plugins/pgpointcloud/drivers/PgWriter.cpp
    R plugins/pgpointcloud/drivers/PgWriter.hpp
    A plugins/pgpointcloud/io/PgCommon.hpp
    A plugins/pgpointcloud/io/PgReader.cpp
    A plugins/pgpointcloud/io/PgReader.hpp
    A plugins/pgpointcloud/io/PgWriter.cpp
    A plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/rxp/CMakeLists.txt
    R plugins/rxp/drivers/RxpReader.cpp
    R plugins/rxp/drivers/RxpReader.hpp
    A plugins/rxp/io/RxpReader.cpp
    A plugins/rxp/io/RxpReader.hpp
    M plugins/sqlite/CMakeLists.txt
    R plugins/sqlite/drivers/SQLiteCommon.hpp
    R plugins/sqlite/drivers/SQLiteReader.cpp
    R plugins/sqlite/drivers/SQLiteReader.hpp
    R plugins/sqlite/drivers/SQLiteWriter.cpp
    R plugins/sqlite/drivers/SQLiteWriter.hpp
    A plugins/sqlite/io/SQLiteCommon.hpp
    A plugins/sqlite/io/SQLiteReader.cpp
    A plugins/sqlite/io/SQLiteReader.hpp
    A plugins/sqlite/io/SQLiteWriter.cpp
    A plugins/sqlite/io/SQLiteWriter.hpp
    M src/CMakeLists.txt
    M test/unit/CMakeLists.txt
    R test/unit/drivers/bpf/BPFTest.cpp
    R test/unit/drivers/buffer/BufferTest.cpp
    R test/unit/drivers/faux/FauxReaderTest.cpp
    R test/unit/drivers/las/LasReaderTest.cpp
    R test/unit/drivers/las/LasWriterTest.cpp
    R test/unit/drivers/oci/oracle_array.cpp
    R test/unit/drivers/qfit/QFITReaderTest.cpp
    R test/unit/drivers/sbet/SbetReaderTest.cpp
    R test/unit/drivers/sbet/SbetWriterTest.cpp
    R test/unit/drivers/terrasolid/TerraSolidReaderTest.cpp
    R test/unit/drivers/text/TextWriterTest.cpp
    A test/unit/io/bpf/BPFTest.cpp
    A test/unit/io/buffer/BufferTest.cpp
    A test/unit/io/faux/FauxReaderTest.cpp
    A test/unit/io/las/LasReaderTest.cpp
    A test/unit/io/las/LasWriterTest.cpp
    A test/unit/io/oci/oracle_array.cpp
    A test/unit/io/qfit/QFITReaderTest.cpp
    A test/unit/io/sbet/SbetReaderTest.cpp
    A test/unit/io/sbet/SbetWriterTest.cpp
    A test/unit/io/terrasolid/TerraSolidReaderTest.cpp
    A test/unit/io/text/TextWriterTest.cpp
  Log Message:
More information about the pdal-commits
