[pdal-commits] [PDAL/PDAL] e321b5: address ZLIB, XML2, MSGPACK, DEMANGLE
GitHub
noreply at github.com
Wed Oct 15 08:05:39 PDT 2014
Branch: refs/heads/issue523-upstream-projects
Home: https://github.com/PDAL/PDAL
Commit: e321b5785c15312046ac729b66f0279d90d8646f
https://github.com/PDAL/PDAL/commit/e321b5785c15312046ac729b66f0279d90d8646f
Author: Michael P. Gerlek <mpg at flaxen.com>
Date: 2014-10-15 (Wed, 15 Oct 2014)
Changed paths:
M CMakeLists.txt
M include/pdal/drivers/bpf/BpfReader.hpp
M pdal_defines.h.in
M scripts/ci/script.sh
M src/Utils.cpp
M src/XMLSchema.cpp
M src/drivers/bpf/BpfReader.cpp
M test/unit/drivers/bpf/BPFTest.cpp
Log Message:
- ZLIB always required
- XML2 will be enabled if a DB is enabled (cmake-only fix)
- MSGPACK removed
- DEMANGLE code changed to a single #ifdef windows
More information about the pdal-commits
