[pdal-commits] [PDAL/PDAL] b0f306: initial draft at PCL submodules
GitHub
noreply at github.com
Thu Oct 16 11:49:18 PDT 2014
Branch: refs/heads/pcl-submodule
Home: https://github.com/PDAL/PDAL
Commit: b0f3060b0c048063f0129d316c6e7a1b1af98b2b
https://github.com/PDAL/PDAL/commit/b0f3060b0c048063f0129d316c6e7a1b1af98b2b
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-10-16 (Thu, 16 Oct 2014)
Changed paths:
M CMakeLists.txt
M cmake/pdal_targets.cmake
M include/pdal/Drivers.hpp
R include/pdal/drivers/pcd/Common.hpp
R include/pdal/drivers/pcd/Reader.hpp
R include/pdal/drivers/pcd/Writer.hpp
R include/pdal/drivers/pcd/point_types.hpp
R include/pdal/drivers/pclvisualizer/PCLVisualizer.hpp
M include/pdal/pdal_macros.hpp
A plugins/CMakeLists.txt
A plugins/pcl/CMakeLists.txt
A plugins/pcl/drivers/PCLVisualizer.cpp
A plugins/pcl/drivers/PCLVisualizer.hpp
A plugins/pcl/drivers/PcdCommon.cpp
A plugins/pcl/drivers/PcdCommon.hpp
A plugins/pcl/drivers/PcdReader.cpp
A plugins/pcl/drivers/PcdReader.hpp
A plugins/pcl/drivers/PcdWriter.cpp
A plugins/pcl/drivers/PcdWriter.hpp
A plugins/pcl/drivers/point_types.hpp
M src/CMakeLists.txt
M src/StageFactory.cpp
M src/drivers/oci/OciReader.cpp
M src/drivers/oci/Writer.cpp
R src/drivers/pcd/Common.cpp
R src/drivers/pcd/Reader.cpp
R src/drivers/pcd/Writer.cpp
R src/drivers/pclvisualizer/PCLVisualizer.cpp
M src/drivers/pgpointcloud/PgReader.cpp
M src/drivers/pgpointcloud/Reader.cpp
M src/drivers/pgpointcloud/Writer.cpp
M src/drivers/sqlite/SQLiteReader.cpp
M src/drivers/sqlite/SQLiteWriter.cpp
M src/drivers/text/Writer.cpp
Log Message:
Commit: da7826ba5e59c98181891d30f020047f0b308941
https://github.com/PDAL/PDAL/commit/da7826ba5e59c98181891d30f020047f0b308941
Changed paths:
M apps/pdal.cpp
R include/pdal/filters/PCLBlock.hpp
M plugins/pcl/CMakeLists.txt
A plugins/pcl/filters/PCLBlock.cpp
A plugins/pcl/filters/PCLBlock.hpp
A plugins/pcl/pipeline/PCLPipeline.cpp
A plugins/pcl/pipeline/PCLPipeline.h
A plugins/pcl/pipeline/PCLPipeline.hpp
R src/filters/PCLBlock.cpp
R src/pclsupport/PCLPipeline.cpp
R src/pclsupport/PCLPipeline.h
R src/pclsupport/PCLPipeline.hpp
M test/unit/CMakeLists.txt
Log Message:
pclblock and pclpipeline relocated, ground and pcl kernels along with pclblock test disabled temporarily
Commit: b2102edd2cbe7103a314f8557f2a4779cc33c63d
https://github.com/PDAL/PDAL/commit/b2102edd2cbe7103a314f8557f2a4779cc33c63d
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
R include/pdal/Kernel.hpp
M include/pdal/kernel/Application.hpp
M include/pdal/kernel/Delta.hpp
M include/pdal/kernel/Diff.hpp
R include/pdal/kernel/Ground.hpp
M include/pdal/kernel/Info.hpp
M include/pdal/kernel/Kernel.hpp
A include/pdal/kernel/KernelFactory.hpp
A include/pdal/kernel/KernelInfo.hpp
A include/pdal/kernel/Kernels.hpp
R include/pdal/kernel/PCL.hpp
M include/pdal/kernel/Pipeline.hpp
M include/pdal/kernel/Random.hpp
M include/pdal/kernel/Translate.hpp
A plugins/pcl/kernel/Ground.cpp
A plugins/pcl/kernel/Ground.hpp
A plugins/pcl/kernel/PCL.cpp
A plugins/pcl/kernel/PCL.hpp
M src/kernel/Application.cpp
M src/kernel/Delta.cpp
M src/kernel/Diff.cpp
R src/kernel/Ground.cpp
M src/kernel/Info.cpp
A src/kernel/Kernel.cpp
A src/kernel/KernelFactory.cpp
A src/kernel/KernelInfo.cpp
R src/kernel/PCL.cpp
M src/kernel/Pipeline.cpp
M src/kernel/Random.cpp
M src/kernel/Translate.cpp
Log Message:
add Kernel, KernelFactory, and KernelInfo, register kernel plugins
Commit: f9f6b6731dba54270c0c01cb71200c23c425f810
https://github.com/PDAL/PDAL/commit/f9f6b6731dba54270c0c01cb71200c23c425f810
Changed paths:
R include/pdal/kernel/View.hpp
M plugins/pcl/kernel/Ground.cpp
M plugins/pcl/kernel/Ground.hpp
A plugins/pcl/kernel/View.cpp
A plugins/pcl/kernel/View.hpp
R src/kernel/View.cpp
Log Message:
make ground and kernel plugins
Commit: db026b204f0490e62ed1f307006ca01248dc1219
https://github.com/PDAL/PDAL/commit/db026b204f0490e62ed1f307006ca01248dc1219
Changed paths:
M src/FileUtils.cpp
Log Message:
assume that if the filename starts with http, we are passing a greyhound url
Compare: https://github.com/PDAL/PDAL/compare/447565386ac0...db026b204f04
More information about the pdal-commits
