[pdal-commits] [PDAL/PDAL] b66973: add MovingLeastSquares access and Smooth kernel, d...
GitHub
noreply at github.com
Mon Oct 20 06:42:25 PDT 2014
Branch: refs/heads/pcl-submodule
Home: https://github.com/PDAL/PDAL
Commit: b66973070c5650ebba5d51b3933cc7e28a3c56fc
https://github.com/PDAL/PDAL/commit/b66973070c5650ebba5d51b3933cc7e28a3c56fc
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-10-20 (Mon, 20 Oct 2014)
Changed paths:
M apps/pdal.cpp
M plugins/pcl/CMakeLists.txt
M plugins/pcl/filters/PCLBlock.cpp
A plugins/pcl/kernel/Smooth.cpp
A plugins/pcl/kernel/Smooth.hpp
M plugins/pcl/pipeline/PCLPipeline.cpp
M plugins/pcl/pipeline/PCLPipeline.h
M plugins/pcl/pipeline/PCLPipeline.hpp
Log Message:
add MovingLeastSquares access and Smooth kernel, disable normals for now (do we really need/use them?)
Commit: 7b134ab140a8e98c410f7d8d9cba7bdf551051c9
https://github.com/PDAL/PDAL/commit/7b134ab140a8e98c410f7d8d9cba7bdf551051c9
Changed paths:
Log Message:
add pcl integration/todo notes
Commit: b359a8f6256e8106458691bb735c7dc65716188b
https://github.com/PDAL/PDAL/commit/b359a8f6256e8106458691bb735c7dc65716188b
Changed paths:
M src/CMakeLists.txt
M test/unit/CMakeLists.txt
M test/unit/filters/PCLBlockFilterTest.cpp
Log Message:
test without linking PCL in src/CMakeLists.txt, re-enable PCLBlockFilterTest and test for PCL presence using the StageFactory getFilterCreator
Commit: f9f1983c108ad3b01adfcaecddead037a8543d01
https://github.com/PDAL/PDAL/commit/f9f1983c108ad3b01adfcaecddead037a8543d01
Changed paths:
M CMakeLists.txt
M pdal_defines.h.in
M src/kernel/Kernel.cpp
Log Message:
PCL unit tests pass with a warning if PCL plugins are not installed - though we should still move PCL tests to the plugin folder
Compare: https://github.com/PDAL/PDAL/compare/74dbab6ce827...f9f1983c108a
More information about the pdal-commits
