[pdal-commits] [PDAL/PDAL] 8bb9d5: Isolate plugins and their dependencies, starting w...
GitHub
noreply at github.com
Mon Oct 27 07:51:45 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 8bb9d5a022b2e1b3f4da6f5d24f34c5a7cfa94c5
https://github.com/PDAL/PDAL/commit/8bb9d5a022b2e1b3f4da6f5d24f34c5a7cfa94c5
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-10-27 (Mon, 27 Oct 2014)
Changed paths:
M CMakeLists.txt
M apps/CMakeLists.txt
M apps/pdal.cpp
M cmake/pdal_targets.cmake
M include/pdal/Drivers.hpp
M include/pdal/Filters.hpp
R include/pdal/Kernel.hpp
R include/pdal/PCLConversions.hpp
M include/pdal/StageFactory.hpp
R include/pdal/drivers/pcd/Common.hpp
R include/pdal/drivers/pcd/Reader.hpp
R include/pdal/drivers/pcd/Writer.hpp
R include/pdal/drivers/pcd/point_types.hpp
R include/pdal/drivers/pclvisualizer/PCLVisualizer.hpp
M include/pdal/filters/Decimation.hpp
R include/pdal/filters/PCLBlock.hpp
M include/pdal/kernel/Delta.hpp
M include/pdal/kernel/Diff.hpp
R include/pdal/kernel/Ground.hpp
M include/pdal/kernel/Info.hpp
M include/pdal/kernel/Kernel.hpp
A include/pdal/kernel/KernelFactory.hpp
A include/pdal/kernel/KernelInfo.hpp
A include/pdal/kernel/Kernels.hpp
R include/pdal/kernel/PCL.hpp
M include/pdal/kernel/Pipeline.hpp
M include/pdal/kernel/Random.hpp
M include/pdal/kernel/Translate.hpp
R include/pdal/kernel/View.hpp
M include/pdal/pdal_macros.hpp
R include/stubs/pcl/console/print.h
R include/stubs/pcl/filters/voxel_grid.h
R include/stubs/pcl/for_each_type.h
R include/stubs/pcl/io/impl/pcd_io.hpp
R include/stubs/pcl/io/pcd_io.h
R include/stubs/pcl/pcl_config.h
R include/stubs/pcl/pipeline/pipeline.h
R include/stubs/pcl/point_traits.h
R include/stubs/pcl/point_types.h
R include/stubs/pcl/visualization/pcl_visualizer.h
R include/stubs/pcl/visualization/point_cloud_color_handlers.h
M pdal_defines.h.in
A plugins/CMakeLists.txt
A plugins/pcl/CMakeLists.txt
A plugins/pcl/PCLConversions.hpp
A plugins/pcl/drivers/PCLVisualizer.cpp
A plugins/pcl/drivers/PCLVisualizer.hpp
A plugins/pcl/drivers/PcdCommon.cpp
A plugins/pcl/drivers/PcdCommon.hpp
A plugins/pcl/drivers/PcdReader.cpp
A plugins/pcl/drivers/PcdReader.hpp
A plugins/pcl/drivers/PcdWriter.cpp
A plugins/pcl/drivers/PcdWriter.hpp
A plugins/pcl/drivers/point_types.hpp
A plugins/pcl/filters/PCLBlock.cpp
A plugins/pcl/filters/PCLBlock.hpp
A plugins/pcl/kernel/Ground.cpp
A plugins/pcl/kernel/Ground.hpp
A plugins/pcl/kernel/PCL.cpp
A plugins/pcl/kernel/PCL.hpp
A plugins/pcl/kernel/Smooth.cpp
A plugins/pcl/kernel/Smooth.hpp
A plugins/pcl/kernel/View.cpp
A plugins/pcl/kernel/View.hpp
A plugins/pcl/pipeline/PCLPipeline.cpp
A plugins/pcl/pipeline/PCLPipeline.h
A plugins/pcl/pipeline/PCLPipeline.hpp
M src/CMakeLists.txt
M src/FileUtils.cpp
M src/StageFactory.cpp
M src/drivers/oci/OciReader.cpp
M src/drivers/oci/Writer.cpp
R src/drivers/pcd/Common.cpp
R src/drivers/pcd/Reader.cpp
R src/drivers/pcd/Writer.cpp
R src/drivers/pclvisualizer/PCLVisualizer.cpp
M src/drivers/pgpointcloud/PgReader.cpp
M src/drivers/pgpointcloud/Reader.cpp
M src/drivers/pgpointcloud/Writer.cpp
M src/drivers/sqlite/SQLiteReader.cpp
M src/drivers/sqlite/SQLiteWriter.cpp
M src/drivers/text/Writer.cpp
M src/filters/Decimation.cpp
R src/filters/PCLBlock.cpp
R src/kernel/Application.cpp
M src/kernel/Delta.cpp
M src/kernel/Diff.cpp
R src/kernel/Ground.cpp
M src/kernel/Info.cpp
A src/kernel/Kernel.cpp
A src/kernel/KernelFactory.cpp
A src/kernel/KernelInfo.cpp
R src/kernel/PCL.cpp
M src/kernel/Pipeline.cpp
M src/kernel/Random.cpp
M src/kernel/Translate.cpp
R src/kernel/View.cpp
R src/pclsupport/PCLPipeline.cpp
R src/pclsupport/PCLPipeline.h
R src/pclsupport/PCLPipeline.hpp
M src/pdal_config.cpp
M test/unit/CMakeLists.txt
M test/unit/Support.cpp
M test/unit/filters/PCLBlockFilterTest.cpp
Log Message:
Isolate plugins and their dependencies, starting with PCL. Create Kernel
class for kernel plugins.
* A plugins folder has been created for PCL (and other) plugins. All
plugins are now built via the existing plugin framework (i.e., as
shared libs that are registered at runtime). Plugins will link
against PDAL, but PDAL can be built independently of any plugin
dependencies.
* References to PDAL_HAVE_PCL have generally been removed, as
PCL-dependent code should only be encountered within the PCL
plugin directory, and only after PCL has been detected. Within
PDAL, prior checks for PDAL_HAVE_PCL have been replaced by queries
of getFilterCreator (also Reader, Writer, Kernel), which has been
made public in StageFactory. These sections of code are only
encountered when plugins have been determined to be present at
runtime.
Remaining todos (these can be addressed post-merge)...
* Visualization option only displays output buffer for now.
Displaying the input and output buffers would force a PCL
requirement on PDAL. Still need to think through how to pass
multiple buffers to the existing PCLVisualizer driver (writers
typically only have one buffer).
* PCL unit tests pass with a warning if PCL plugins are not
installed - though we should still move PCL tests to the plugin
folder.
Other miscellaneous, but noteworthy changes include...
* In FileUtils and StageFactory, assume that if the filename starts
with http, we are passing a Greyhound url. This is independent of
the plugins changes, but allows us to import data from Greyhound.
* Remove stubs.
* Remove Application class, it is now part of Kernel.
* VoxelGrid removed from decimation filter, now called via PCLBlock
(if available) in Translate kernel.
* Unit tests binpath updated for APP_BUNDLE builds.
* Add MovingLeastSquares to PCL pipeline and Smooth kernel.
* Disable NormalEstimation and ConditionalRemoval in PCL pipeline
(allows us to stick with POINT_XYZ types).
* Remove PCL from getVersionString.
* Remove references to USE_PDAL_PLUGIN_PCD.
Commit: 9c399eb5870d7664f3aa268bc303fd936cf534a5
https://github.com/PDAL/PDAL/commit/9c399eb5870d7664f3aa268bc303fd936cf534a5
Changed paths:
M plugins/pcl/kernel/Smooth.cpp
M plugins/pcl/kernel/Smooth.hpp
Log Message:
addressing abell's comments
Commit: 4b5f6eb1b5f59b1108c7e33947352a2ef8660a10
https://github.com/PDAL/PDAL/commit/4b5f6eb1b5f59b1108c7e33947352a2ef8660a10
Author: Howard Butler <howard at hobu.co>
Changed paths:
M plugins/pcl/drivers/PcdCommon.cpp
Log Message:
include tweak #532
Commit: e3786969f9f4ed4d0a5b86042c9d838177f73d6d
https://github.com/PDAL/PDAL/commit/e3786969f9f4ed4d0a5b86042c9d838177f73d6d
Changed paths:
M src/kernel/Kernel.cpp
Log Message:
port over visualization fix from master
Commit: 0cf44aeb07aa40f22cecb200ca8c3e265466d66f
https://github.com/PDAL/PDAL/commit/0cf44aeb07aa40f22cecb200ca8c3e265466d66f
Changed paths:
M include/pdal/kernel/Kernels.hpp
Log Message:
Query is OBE
Commit: 2192875f88b10163c1ce3b2c33bae352f41c7060
https://github.com/PDAL/PDAL/commit/2192875f88b10163c1ce3b2c33bae352f41c7060
Changed paths:
M apps/pdal.cpp
M include/pdal/kernel/Sort.hpp
M src/kernel/Sort.cpp
Log Message:
update Sort from Application to Kernel
Commit: 3e6209bbfce333910df5ae7f21bf560c7a866a50
https://github.com/PDAL/PDAL/commit/3e6209bbfce333910df5ae7f21bf560c7a866a50
Changed paths:
Log Message:
do the macro thing
Commit: 85fe624537fcd6216e6dfe4c6eedc53796c2d430
https://github.com/PDAL/PDAL/commit/85fe624537fcd6216e6dfe4c6eedc53796c2d430
Changed paths:
M apps/pdal.cpp
M include/pdal/kernel/KernelFactory.hpp
M src/kernel/KernelFactory.cpp
Log Message:
use unique_ptr with createKernel
Commit: fc8a26b52b1283591bb574e41c60c68710d622ff
https://github.com/PDAL/PDAL/commit/fc8a26b52b1283591bb574e41c60c68710d622ff
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M pdal_defines.h.in
M src/FileUtils.cpp
Log Message:
Merge pull request #532 from PDAL/pcl-submodule
Isolate plugins and their dependencies, starting with PCL. Create Kernel class for kernel plugins.
Compare: https://github.com/PDAL/PDAL/compare/67ece3c300c1...fc8a26b52b12
More information about the pdal-commits
