[pdal-commits] [PDAL/PDAL] 6facd8: PCL_VISUALIZATION_FOUND will be TRUE if it is supp...
GitHub
noreply at github.com
Mon Oct 27 08:45:11 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 6facd80ac69d8c31b38ddc142f51da8013d35ee1
https://github.com/PDAL/PDAL/commit/6facd80ac69d8c31b38ddc142f51da8013d35ee1
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-10-27 (Mon, 27 Oct 2014)
Changed paths:
M plugins/pcl/CMakeLists.txt
Log Message:
PCL_VISUALIZATION_FOUND will be TRUE if it is supported, only build the PCLVisualization driver if that is the case
Commit: ff5b19aedc7ec4779f0534e71119a75e9894036c
https://github.com/PDAL/PDAL/commit/ff5b19aedc7ec4779f0534e71119a75e9894036c
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #552 from PDAL/issues/551-pcl-visualization-check
PCL_VISUALIZATION_FOUND will be TRUE if it is supported, only build the ...
Compare: https://github.com/PDAL/PDAL/compare/fc8a26b52b12...ff5b19aedc7e
More information about the pdal-commits
