[pdal-commits] [PDAL/PDAL] 2194ca: Remove errant size set for location scaling.
GitHub
noreply at github.com
Thu Apr 9 06:35:38 PDT 2015
Branch: refs/heads/sdo_pc
Home: https://github.com/PDAL/PDAL
Commit: 2194ca08f5740c642815e141a40cd2ca60970e3d
https://github.com/PDAL/PDAL/commit/2194ca08f5740c642815e141a40cd2ca60970e3d
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-04-01 (Wed, 01 Apr 2015)
Changed paths:
M src/DbWriter.cpp
Log Message:
Commit: ea549945e64e33c0fbf90a09b92df7790ecee966
https://github.com/PDAL/PDAL/commit/ea549945e64e33c0fbf90a09b92df7790ecee966
Changed paths:
M plugins/oci/io/OciWriter.cpp
Log Message:
Add auto-offset support to OCI.
Commit: 0de04d24b9eb68a72aafc02fb64f5b83e5299018
https://github.com/PDAL/PDAL/commit/0de04d24b9eb68a72aafc02fb64f5b83e5299018
Changed paths:
M plugins/oci/CMakeLists.txt
M plugins/oci/io/OciCommon.cpp
M plugins/oci/test/OCITest.cpp
M test/unit/TestConfig.cpp
M test/unit/TestConfig.hpp.in
Log Message:
Make OCI tests work.
Allow OCI connection string to be set in CMakeCache.txt or with
--connection=string on command line.
Commit: ef905e8263ed5be8f08a5c1b299367cb5a05a7ef
https://github.com/PDAL/PDAL/commit/ef905e8263ed5be8f08a5c1b299367cb5a05a7ef
Changed paths:
M plugins/oci/io/OciReader.cpp
Log Message:
Fix point-major reads for OCI.
Add point-major tests for OCI.
Commit: 0b20d202c533eccf2651542d274871d702fa9c8a
https://github.com/PDAL/PDAL/commit/0b20d202c533eccf2651542d274871d702fa9c8a
Author: Howard Butler <howard at hobu.co>
Date: 2015-04-03 (Fri, 03 Apr 2015)
Changed paths:
M plugins/nitf/io/NitfWriter.cpp
Log Message:
apply patch from Todd Murphy to ensure valid boxes for small footprints in IGEOLO in writers.nitf
Commit: 5ba08b7cdcc029702abfbf28da500b411f48fdab
https://github.com/PDAL/PDAL/commit/5ba08b7cdcc029702abfbf28da500b411f48fdab
Changed paths:
M filters/colorization/ColorizationFilter.cpp
M filters/reprojection/ReprojectionFilter.cpp
M filters/reprojection/ReprojectionFilter.hpp
M include/pdal/GlobalEnvironment.hpp
M include/pdal/PointView.hpp
M plugins/attribute/filters/AttributeFilter.cpp
M src/GlobalEnvironment.cpp
M src/plang/Script.cpp
Log Message:
commit aea7c9db37f3b30a3d035aa6559dc20609233ae5
Date: Fri Apr 3 14:02:09 2015 -0500
Only set GDAL log once.
Close #864
Commit: a8071565c009369634710e939069f5cbe054ab32
https://github.com/PDAL/PDAL/commit/a8071565c009369634710e939069f5cbe054ab32
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2015-04-05 (Sun, 05 Apr 2015)
Changed paths:
M CMakeLists.txt
Log Message:
Bump required cmake version to 2.8.11
I tried with 2.8.7 and things blew up.
Commit: 5a841978f3b14db3cc783886cbfa93bcfe1d47ee
https://github.com/PDAL/PDAL/commit/5a841978f3b14db3cc783886cbfa93bcfe1d47ee
Changed paths:
M scripts/ci/before_install.sh
Log Message:
Install libgeotiff from apt instead of from source
Commit: 4de85917e7aea9bad23fa621c904dd60a3cf8033
https://github.com/PDAL/PDAL/commit/4de85917e7aea9bad23fa621c904dd60a3cf8033
Changed paths:
Log Message:
Consolidate apt-get installs
Commit: d893b5bf042a5b16f6e411828800c790d7fc0fa9
https://github.com/PDAL/PDAL/commit/d893b5bf042a5b16f6e411828800c790d7fc0fa9
Changed paths:
Log Message:
Use pdal's ppa for pgpointcloud
This is a ppa that we maintain for continuous integration packages.
Commit: 4bc4aa7733d79435a921a49c330dcc36c165b22d
https://github.com/PDAL/PDAL/commit/4bc4aa7733d79435a921a49c330dcc36c165b22d
Changed paths:
Log Message:
Reorganize apt-get installs
Split out the installs by expected ppa source, so the ppa <-> package
links are easier to maintain over time.
Commit: c57744108d7f7889f7df597fc76560da4bd86287
https://github.com/PDAL/PDAL/commit/c57744108d7f7889f7df597fc76560da4bd86287
Changed paths:
M scripts/ci/script.sh
Log Message:
Remove unused cmake variables in CI script
WITH_ICONV and WITH_LIBXML2 were unused.
Commit: d40458e577de82758d872727ca6201933ca38e01
https://github.com/PDAL/PDAL/commit/d40458e577de82758d872727ca6201933ca38e01
Date: 2015-04-06 (Mon, 06 Apr 2015)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #866 from gadomski/travis-cleanup
Travis cleanup and beginnings of ppa-ification
Commit: 67319310a054cedc8dd7f7adea88ba923477205c
https://github.com/PDAL/PDAL/commit/67319310a054cedc8dd7f7adea88ba923477205c
Author: Connor Manning <connor at hobu.co>
Changed paths:
M include/pdal/PipelineManager.hpp
M include/pdal/PointLayout.hpp
M include/pdal/PointTable.hpp
Log Message:
Make the PointTable's Layout not be a shared pointer.
Commit: 475895338f980ebb411b911b0cc48c21cbdeaa05
https://github.com/PDAL/PDAL/commit/475895338f980ebb411b911b0cc48c21cbdeaa05
Changed paths:
M include/pdal/Compression.hpp
M include/pdal/Utils.hpp
M plugins/oci/io/OciReader.hpp
M plugins/oci/io/OciWriter.hpp
M test/unit/CompressionTest.cpp
M test/unit/MetadataTest.cpp
Log Message:
Add compression to OCI.
Add a simple buffer implementation to the Compression header.
Make sure done() only gets called once for the LazPerf compressor.
Have compression tests use new compression buffer.
Conflicts:
Commit: 21e853dd79b47421e07123152edb1559428a9f3a
https://github.com/PDAL/PDAL/commit/21e853dd79b47421e07123152edb1559428a9f3a
Changed paths:
Log Message:
Merge pull request #868 from PDAL/layout-ownership
Commit: 9c5c50eeab702f7654c6e69b79b76d19230ce794
https://github.com/PDAL/PDAL/commit/9c5c50eeab702f7654c6e69b79b76d19230ce794
Changed paths:
M plugins/pcl/filters/GroundFilter.hpp
Log Message:
Remove unnecessary typedef declarations.
Commit: 6cf508146627c481133c70555a0812aee12cf596
https://github.com/PDAL/PDAL/commit/6cf508146627c481133c70555a0812aee12cf596
Date: 2015-04-07 (Tue, 07 Apr 2015)
Changed paths:
M filters/chipper/ChipperFilter.hpp
M filters/colorization/ColorizationFilter.hpp
M filters/crop/CropFilter.hpp
M filters/decimation/DecimationFilter.hpp
M filters/ferry/FerryFilter.hpp
M filters/merge/MergeFilter.hpp
M filters/mortonorder/MortonOrderFilter.hpp
M filters/range/RangeFilter.hpp
M filters/sort/SortFilter.hpp
M filters/splitter/SplitterFilter.hpp
M filters/stats/StatsFilter.hpp
M filters/transformation/TransformationFilter.hpp
M include/pdal/PluginManager.hpp
M include/pdal/Stage.hpp
M include/pdal/pdal_macros.hpp
R include/pdal/plugin.h
A include/pdal/plugin.hpp
M io/bpf/BpfReader.hpp
M io/bpf/BpfWriter.hpp
M io/faux/FauxReader.hpp
M io/las/LasReader.hpp
M io/las/LasWriter.hpp
M io/null/NullWriter.hpp
M io/optech/OptechReader.hpp
M io/qfit/QfitReader.hpp
M io/rialto/RialtoWriter.hpp
M io/sbet/SbetReader.hpp
M io/sbet/SbetWriter.hpp
M io/terrasolid/TerrasolidReader.hpp
M io/text/TextWriter.hpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.hpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.hpp
M kernels/translate/TranslateKernel.hpp
Log Message:
Change plugin.h to plugin.hpp.
Modify the plugin structure to use std::string.
Commit: 428172e0b825bfc4d12c4093c786ed757c965d0c
https://github.com/PDAL/PDAL/commit/428172e0b825bfc4d12c4093c786ed757c965d0c
Changed paths:
Log Message:
Fix typo.
Commit: 95bd938911f8f0dbe1f2a16d64a6ba845da91a3b
https://github.com/PDAL/PDAL/commit/95bd938911f8f0dbe1f2a16d64a6ba845da91a3b
Changed paths:
Log Message:
Merge branch 'issues-854'
Commit: cf9917a630e07488f00b0756f78ff7b96d7d575d
https://github.com/PDAL/PDAL/commit/cf9917a630e07488f00b0756f78ff7b96d7d575d
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/nitf-writer-igeolo-precision'
Commit: 41a3c71bc30ede0c0ec5dfd8930e7dda59d5383a
https://github.com/PDAL/PDAL/commit/41a3c71bc30ede0c0ec5dfd8930e7dda59d5383a
Changed paths:
M filters/ferry/FerryFilter.cpp
M filters/stats/StatsFilter.cpp
M filters/transformation/TransformationFilter.cpp
M include/pdal/Filter.hpp
M include/pdal/QuadIndex.hpp
M include/pdal/StageWrapper.hpp
M include/pdal/plang/BufferedInvocation.hpp
M plugins/attribute/filters/AttributeFilter.hpp
M plugins/hexbin/filters/HexBin.cpp
M plugins/hexbin/filters/HexBin.hpp
M plugins/python/filters/PredicateFilter.cpp
M plugins/python/filters/ProgrammableFilter.cpp
M plugins/python/filters/ProgrammableFilter.hpp
M src/QuadIndex.cpp
M src/plang/BufferedInvocation.cpp
M test/unit/filters/SortFilterTest.cpp
Log Message:
Take PointView reference instead of shared_ptr in filter().
Commit: cc8001baf8288526a56306a48bfc315a1a428f07
https://github.com/PDAL/PDAL/commit/cc8001baf8288526a56306a48bfc315a1a428f07
Author: Connor Manning <connormanning at users.noreply.github.com>
Changed paths:
M src/QuadIndex.cpp
Log Message:
Merge pull request #869 from PDAL/filter-reference
Take a PointView reference instead of shared_ptr in filter().
Commit: 3330758698a1733e9809709290e158c77a60ba8e
https://github.com/PDAL/PDAL/commit/3330758698a1733e9809709290e158c77a60ba8e
Changed paths:
Log Message:
Formatting.
Commit: 54bb4d710ca9ee694edce176f1a55a4072640199
https://github.com/PDAL/PDAL/commit/54bb4d710ca9ee694edce176f1a55a4072640199
Date: 2015-04-08 (Wed, 08 Apr 2015)
Changed paths:
Log Message:
Add OCI test code.
Commit: bdeeffd4d62beac297dead911d96bee5855f57ed
https://github.com/PDAL/PDAL/commit/bdeeffd4d62beac297dead911d96bee5855f57ed
Changed paths:
M src/QuadIndex.cpp
Log Message:
Merge branch 'master' of https://github.com/PDAL/PDAL
Commit: 19ad524d9597213ea7e99f9d8f35a8a2d7eb9daf
https://github.com/PDAL/PDAL/commit/19ad524d9597213ea7e99f9d8f35a8a2d7eb9daf
Changed paths:
M test/unit/PointViewTest.cpp
Log Message:
Use custom comparator for PointViewSet.
Test comparator for PointViewSet.
Commit: 7760e5d30d498385c6a359a56f9b1b31fad3cf57
https://github.com/PDAL/PDAL/commit/7760e5d30d498385c6a359a56f9b1b31fad3cf57
Changed paths:
Log Message:
Remove debug.
Commit: 3971f5498b64a32ae8973046d15db2dfe0db76e2
https://github.com/PDAL/PDAL/commit/3971f5498b64a32ae8973046d15db2dfe0db76e2
Changed paths:
Log Message:
Duh.
Commit: bf6e8e1fcb008d4b8e123292d291d649f8b85268
https://github.com/PDAL/PDAL/commit/bf6e8e1fcb008d4b8e123292d291d649f8b85268
Date: 2015-04-09 (Thu, 09 Apr 2015)
Changed paths:
Log Message:
Change LazPerfCompressor warning from exception to error output.
Commit: a216638cb1a577d98e1c914e357d25945800b484
https://github.com/PDAL/PDAL/commit/a216638cb1a577d98e1c914e357d25945800b484
Changed paths:
M CMakeLists.txt
M src/DbWriter.cpp
M src/QuadIndex.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into sdo_pc
Compare: https://github.com/PDAL/PDAL/compare/7fc3a62f0d24...a216638cb1a5
More information about the pdal-commits
