[pdal-commits] [PDAL/PDAL] 745d47: Make schema hold XMLdims so that names get output ...
GitHub
noreply at github.com
Wed Apr 15 15:07:49 PDT 2015
Branch: refs/heads/pdal-tindex
Home: https://github.com/PDAL/PDAL
Commit: 745d47268abccb0c92f209f484f42b1520a596b9
https://github.com/PDAL/PDAL/commit/745d47268abccb0c92f209f484f42b1520a596b9
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-04-14 (Tue, 14 Apr 2015)
Changed paths:
M include/pdal/DbWriter.hpp
M include/pdal/Writer.hpp
M include/pdal/XMLSchema.hpp
M io/bpf/BpfWriter.cpp
M kernels/info/InfoKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M src/DbWriter.cpp
M src/XMLSchema.cpp
M test/unit/XMLSchemaTest.cpp
Log Message:
Make schema hold XMLdims so that names get output for non-standard dimensions.
Commit: cd84b4c7461bfa5b7061acfce5f876527ae39a1a
https://github.com/PDAL/PDAL/commit/cd84b4c7461bfa5b7061acfce5f876527ae39a1a
Changed paths:
Log Message:
Add test for non-standard dimension names.
Commit: 9ab563791636887e3e0fc7145b38e482c2eaa457
https://github.com/PDAL/PDAL/commit/9ab563791636887e3e0fc7145b38e482c2eaa457
Date: 2015-04-15 (Wed, 15 Apr 2015)
Changed paths:
A doc/stages/filters.stats.rst
M doc/stages/index.rst
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M include/pdal/PDALUtils.hpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
Add support for enumeration of statistics values.
Close #879
Commit: 35b03df2a3da73e6078399db7d951ce7db8520ed
https://github.com/PDAL/PDAL/commit/35b03df2a3da73e6078399db7d951ce7db8520ed
Author: Howard Butler <howard at hobu.co>
Changed paths:
M src/DbWriter.cpp
M src/XMLSchema.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into pdal-tindex
Commit: e2b43215c55265e4c6b0aa92337d261f4faa20aa
https://github.com/PDAL/PDAL/commit/e2b43215c55265e4c6b0aa92337d261f4faa20aa
Changed paths:
M kernels/tindex/TIndexKernel.cpp
M kernels/tindex/TIndexKernel.hpp
Log Message:
very rough index working
Compare: https://github.com/PDAL/PDAL/compare/40a993e8b478...e2b43215c552
More information about the pdal-commits
