[pdal-commits] [PDAL/PDAL] 0cf557: Remove SET_STAGE_ENABLED and SET_KERNEL_ENABLED
GitHub
noreply at github.com
Mon Jan 5 11:09:40 PST 2015
Branch: refs/heads/issue/673-remove-set-stage-enabled
Home: https://github.com/PDAL/PDAL
Commit: 0cf5576ae6385d0898257e573cd04cb3e5acfe19
https://github.com/PDAL/PDAL/commit/0cf5576ae6385d0898257e573cd04cb3e5acfe19
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-01-05 (Mon, 05 Jan 2015)
Changed paths:
M doc/tutorial/overview.rst
M filters/chipper/ChipperFilter.hpp
M filters/colorization/ColorizationFilter.hpp
M filters/crop/CropFilter.hpp
M filters/decimation/DecimationFilter.hpp
M filters/ferry/FerryFilter.hpp
M filters/merge/MergeFilter.hpp
M filters/mortonorder/MortonOrderFilter.hpp
M filters/reprojection/ReprojectionFilter.hpp
M filters/sort/SortFilter.hpp
M filters/splitter/SplitterFilter.hpp
M filters/stats/StatsFilter.hpp
M include/pdal/Stage.hpp
M include/pdal/StageFactory.hpp
M include/pdal/StageInfo.hpp
M io/bpf/BpfReader.hpp
M io/buffer/BufferReader.hpp
M io/faux/FauxReader.hpp
M io/las/LasReader.hpp
M io/las/LasWriter.hpp
M io/qfit/QfitReader.hpp
M io/sbet/SbetReader.hpp
M io/sbet/SbetWriter.hpp
M io/terrasolid/TerrasolidReader.hpp
M io/text/TextWriter.hpp
M kernels/Kernel.hpp
M kernels/KernelFactory.hpp
M kernels/KernelInfo.cpp
M kernels/KernelInfo.hpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.hpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.hpp
M kernels/translate/TranslateKernel.hpp
M plugins/attribute/filters/AttributeFilter.hpp
M plugins/greyhound/io/GreyhoundReader.hpp
M plugins/hexbin/filters/HexBin.hpp
M plugins/icebridge/io/IcebridgeReader.hpp
M plugins/mrsid/io/MrsidReader.hpp
M plugins/nitf/io/NitfReader.hpp
M plugins/nitf/io/NitfWriter.hpp
M plugins/oci/io/OciReader.hpp
M plugins/oci/io/OciWriter.hpp
M plugins/p2g/io/P2gWriter.hpp
M plugins/pcl/filters/PCLBlock.hpp
M plugins/pcl/io/PCLVisualizer.hpp
M plugins/pcl/io/PcdReader.hpp
M plugins/pcl/io/PcdWriter.hpp
M plugins/pcl/kernel/GroundKernel.hpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/pcl/kernel/ViewKernel.hpp
M plugins/pgpointcloud/io/PgReader.hpp
M plugins/pgpointcloud/io/PgWriter.hpp
M plugins/python/filters/PredicateFilter.hpp
M plugins/python/filters/ProgrammableFilter.hpp
M plugins/rxp/io/RxpReader.hpp
M plugins/sqlite/io/SQLiteReader.hpp
M plugins/sqlite/io/SQLiteWriter.hpp
M src/StageInfo.cpp
Log Message:
We no longer have a situation in which a driver is built but would not
be enabled. Drivers that have dependencies will simply not be built if
the dependency is not met; this is controlled by CMake. Running `pdal
drivers` will still provide visibility at runtime into which drivers are
available.
More information about the pdal-commits
