[pdal-commits] [PDAL/PDAL] a6299c: record plugin version as part of stage info
GitHub noreply at github.com
Thu Jan 8 12:02:54 PST 2015
  Branch: refs/heads/lasdump
  Home:   https://github.com/PDAL/PDAL
  Commit: a6299c17ad7ea73fad9d95be6ee753f158790547
      https://github.com/PDAL/PDAL/commit/a6299c17ad7ea73fad9d95be6ee753f158790547
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-01-06 (Tue, 06 Jan 2015)
  Changed paths:
    M CMakeLists.txt
    M include/pdal/Stage.hpp
    M include/pdal/StageFactory.hpp
    M include/pdal/StageInfo.hpp
    M plugins/attribute/filters/AttributeFilter.hpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/hexbin/filters/HexBin.hpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/io/NitfWriter.hpp
    M plugins/oci/io/OciReader.hpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/filters/PCLBlock.hpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdReader.hpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pgpointcloud/io/PgReader.hpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/python/filters/PredicateFilter.hpp
    M plugins/python/filters/ProgrammableFilter.hpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/sqlite/io/SQLiteReader.hpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M src/StageInfo.cpp
  Log Message:
  Commit: 2923d099d80b6f397c5832b38af22572d48f29c4
      https://github.com/PDAL/PDAL/commit/2923d099d80b6f397c5832b38af22572d48f29c4
  Date:   2015-01-07 (Wed, 07 Jan 2015)
  Changed paths:
  Log Message:
  only print plugin version if it is set
  Commit: 2556bbaf78428a8ee8884fd72365ffcd4bf6c87e
      https://github.com/PDAL/PDAL/commit/2556bbaf78428a8ee8884fd72365ffcd4bf6c87e
  Changed paths:
    M apps/pdal.cpp
    M src/StageInfo.cpp
  Log Message:
  Modify pdal app outputs
--drivers output is condensed into a table without links.
--options output is added (was previously only available through
  kernels/subcommands).
--help now displays program_options and commonly used
  kernels/subcommands, but no version information. Calling pdal with
  wrong arguments now displays help.
--version now displays only version information (not help).
--debug and --drivers are now parsed as program_options, not actions.
Renamed actions as commands.
  Commit: 1ab469523140553d5abbeba2f33ca0acc8c775f4
      https://github.com/PDAL/PDAL/commit/1ab469523140553d5abbeba2f33ca0acc8c775f4
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Changed paths:
    M plugins/rxp/CMakeLists.txt
  Log Message:
  Update rxp plugin's include directories
  Commit: 3461188cd472f9b4ef6ea0630f8d74cd60cc13a1
      https://github.com/PDAL/PDAL/commit/3461188cd472f9b4ef6ea0630f8d74cd60cc13a1
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #682 from gadomski/rxp-include-directories
  Commit: 9f23e9fad767669d48db1c5e9cb4bc4313b94843
      https://github.com/PDAL/PDAL/commit/9f23e9fad767669d48db1c5e9cb4bc4313b94843
  Changed paths:
    M apps/pdal.cpp
    M src/StageInfo.cpp
  Log Message:
  Merge pull request #681 from PDAL/pdal-app-driver-options-listing
  Commit: e4a20c1c97e6ef2d7a966e8030965977326940b5
      https://github.com/PDAL/PDAL/commit/e4a20c1c97e6ef2d7a966e8030965977326940b5
  Changed paths:
    M CMakeLists.txt
    M src/StageInfo.cpp
  Log Message:
  Merge pull request #679 from PDAL/issue/549-plugin-version
Issue/549 plugin version
  Commit: 16d76ab18c9eed5bc2c07a504bbcc8bd31dcd442
      https://github.com/PDAL/PDAL/commit/16d76ab18c9eed5bc2c07a504bbcc8bd31dcd442
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-01-08 (Thu, 08 Jan 2015)
  Changed paths:
    M src/XMLSchema.cpp
  Log Message:
  Initialize position with something reasonable so that sorting works.
  Commit: a376d09d176b1ec7a2edbe7eb8ba5bf4ff72df1e
      https://github.com/PDAL/PDAL/commit/a376d09d176b1ec7a2edbe7eb8ba5bf4ff72df1e
  Changed paths:
    M include/pdal/Drivers.hpp
  Log Message:
  Cleanup Drivers.hpp
* pdal_config.hpp is not required
* sort includes and remove whitespace
  Commit: f32ab9615aa07bb0839cb63a1e7a416af78e351c
      https://github.com/PDAL/PDAL/commit/f32ab9615aa07bb0839cb63a1e7a416af78e351c
  Changed paths:
    M filters/ferry/FerryFilter.cpp
    M include/pdal/PointContext.hpp
    M kernels/Kernel.cpp
    M kernels/KernelFactory.cpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/attribute/filters/AttributeFilter.cpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/rxp/io/RxpReader.cpp
    M src/StageFactory.cpp
    M test/unit/OptionsTest.cpp
  Log Message:
  We generally do not need a copy when using auto.
  Commit: 1224ce48fd31cbdd998cb89db9468b5d5a94cdb5
      https://github.com/PDAL/PDAL/commit/1224ce48fd31cbdd998cb89db9468b5d5a94cdb5
  Changed paths:
    M test/unit/io/las/LasWriterTest.cpp
    M tools/lasdump/CMakeLists.txt
  Log Message:
  Don't build lasdump with no LASzip.
  Commit: ad6d0c67ddd8e41c9b8d265f1dd5ba547d916323
      https://github.com/PDAL/PDAL/commit/ad6d0c67ddd8e41c9b8d265f1dd5ba547d916323
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M src/StageInfo.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into lasdump
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/10ef667e8a4e...ad6d0c67ddd8
More information about the pdal-commits mailing list
