[pdal-commits] [PDAL/PDAL] c8c2d4: Reorg library files
GitHub
noreply at github.com
Mon Jan 12 10:42:32 PST 2015
Branch: refs/heads/mimic-llvm-and-clang
Home: https://github.com/PDAL/PDAL
Commit: c8c2d4bdf7191ac689c389f05c34b952c05c3e29
https://github.com/PDAL/PDAL/commit/c8c2d4bdf7191ac689c389f05c34b952c05c3e29
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-01-12 (Mon, 12 Jan 2015)
Changed paths:
M CMakeLists.txt
M apps/CMakeLists.txt
M apps/pdal.cpp
M cmake/directories.cmake
R filters/CMakeLists.txt
R filters/chipper/CMakeLists.txt
R filters/chipper/ChipperFilter.cpp
R filters/chipper/ChipperFilter.hpp
R filters/colorization/CMakeLists.txt
R filters/colorization/ColorizationFilter.cpp
R filters/colorization/ColorizationFilter.hpp
R filters/crop/CMakeLists.txt
R filters/crop/CropFilter.cpp
R filters/crop/CropFilter.hpp
R filters/decimation/CMakeLists.txt
R filters/decimation/DecimationFilter.cpp
R filters/decimation/DecimationFilter.hpp
R filters/ferry/CMakeLists.txt
R filters/ferry/FerryFilter.cpp
R filters/ferry/FerryFilter.hpp
R filters/merge/CMakeLists.txt
R filters/merge/MergeFilter.hpp
R filters/mortonorder/CMakeLists.txt
R filters/mortonorder/MortonOrderFilter.cpp
R filters/mortonorder/MortonOrderFilter.hpp
R filters/reprojection/CMakeLists.txt
R filters/reprojection/ReprojectionFilter.cpp
R filters/reprojection/ReprojectionFilter.hpp
R filters/sort/CMakeLists.txt
R filters/sort/SortFilter.hpp
R filters/splitter/CMakeLists.txt
R filters/splitter/SplitterFilter.cpp
R filters/splitter/SplitterFilter.hpp
R filters/stats/CMakeLists.txt
R filters/stats/StatsFilter.cpp
R filters/stats/StatsFilter.hpp
R filters/transformation/CMakeLists.txt
R filters/transformation/TransformationFilter.cpp
R filters/transformation/TransformationFilter.hpp
M include/pdal/Drivers.hpp
A include/pdal/Kernel.hpp
A include/pdal/KernelFactory.hpp
A include/pdal/KernelInfo.hpp
A include/pdal/KernelSupport.hpp
M include/pdal/Kernels.hpp
R io/CMakeLists.txt
R io/bpf/BpfHeader.cpp
R io/bpf/BpfHeader.hpp
R io/bpf/BpfReader.cpp
R io/bpf/BpfReader.hpp
R io/bpf/CMakeLists.txt
R io/buffer/BufferReader.hpp
R io/faux/CMakeLists.txt
R io/faux/FauxReader.cpp
R io/faux/FauxReader.hpp
R io/las/CMakeLists.txt
R io/las/GeotiffSupport.cpp
R io/las/GeotiffSupport.hpp
R io/las/LasError.hpp
R io/las/LasHeader.cpp
R io/las/LasHeader.hpp
R io/las/LasReader.cpp
R io/las/LasReader.hpp
R io/las/LasWriter.cpp
R io/las/LasWriter.hpp
R io/las/SummaryData.cpp
R io/las/SummaryData.hpp
R io/las/VariableLengthRecord.cpp
R io/las/VariableLengthRecord.hpp
R io/las/ZipPoint.cpp
R io/las/ZipPoint.hpp
R io/qfit/CMakeLists.txt
R io/qfit/QfitReader.cpp
R io/qfit/QfitReader.hpp
R io/sbet/CMakeLists.txt
R io/sbet/SbetCommon.cpp
R io/sbet/SbetCommon.hpp
R io/sbet/SbetReader.cpp
R io/sbet/SbetReader.hpp
R io/sbet/SbetWriter.cpp
R io/sbet/SbetWriter.hpp
R io/terrasolid/CMakeLists.txt
R io/terrasolid/TerrasolidReader.cpp
R io/terrasolid/TerrasolidReader.hpp
R io/text/CMakeLists.txt
R io/text/TextWriter.cpp
R io/text/TextWriter.hpp
R kernels/CMakeLists.txt
R kernels/Kernel.cpp
R kernels/Kernel.hpp
R kernels/KernelFactory.cpp
R kernels/KernelFactory.hpp
R kernels/KernelInfo.cpp
R kernels/KernelInfo.hpp
R kernels/KernelSupport.cpp
R kernels/KernelSupport.hpp
R kernels/delta/CMakeLists.txt
R kernels/delta/DeltaKernel.cpp
R kernels/delta/DeltaKernel.hpp
R kernels/diff/CMakeLists.txt
R kernels/diff/DiffKernel.cpp
R kernels/diff/DiffKernel.hpp
R kernels/info/CMakeLists.txt
R kernels/info/InfoKernel.cpp
R kernels/info/InfoKernel.hpp
R kernels/pipeline/CMakeLists.txt
R kernels/pipeline/PipelineKernel.cpp
R kernels/pipeline/PipelineKernel.hpp
R kernels/random/CMakeLists.txt
R kernels/random/RandomKernel.cpp
R kernels/random/RandomKernel.hpp
R kernels/sort/CMakeLists.txt
R kernels/sort/SortKernel.cpp
R kernels/sort/SortKernel.hpp
R kernels/translate/CMakeLists.txt
R kernels/translate/TranslateKernel.cpp
R kernels/translate/TranslateKernel.hpp
A lib/CMakeLists.txt
A lib/Charbuf.cpp
A lib/DbReader.cpp
A lib/DbWriter.cpp
A lib/FileUtils.cpp
A lib/Filter.cpp
A lib/Filters/CMakeLists.txt
A lib/Filters/Chipper/CMakeLists.txt
A lib/Filters/Chipper/ChipperFilter.cpp
A lib/Filters/Chipper/ChipperFilter.hpp
A lib/Filters/Colorization/CMakeLists.txt
A lib/Filters/Colorization/ColorizationFilter.cpp
A lib/Filters/Colorization/ColorizationFilter.hpp
A lib/Filters/Crop/CMakeLists.txt
A lib/Filters/Crop/CropFilter.cpp
A lib/Filters/Crop/CropFilter.hpp
A lib/Filters/Decimation/CMakeLists.txt
A lib/Filters/Decimation/DecimationFilter.cpp
A lib/Filters/Decimation/DecimationFilter.hpp
A lib/Filters/Ferry/CMakeLists.txt
A lib/Filters/Ferry/FerryFilter.cpp
A lib/Filters/Ferry/FerryFilter.hpp
A lib/Filters/Merge/CMakeLists.txt
A lib/Filters/Merge/MergeFilter.hpp
A lib/Filters/MortonOrder/CMakeLists.txt
A lib/Filters/MortonOrder/MortonOrderFilter.cpp
A lib/Filters/MortonOrder/MortonOrderFilter.hpp
A lib/Filters/Reprojection/CMakeLists.txt
A lib/Filters/Reprojection/ReprojectionFilter.cpp
A lib/Filters/Reprojection/ReprojectionFilter.hpp
A lib/Filters/Sort/CMakeLists.txt
A lib/Filters/Sort/SortFilter.hpp
A lib/Filters/Splitter/CMakeLists.txt
A lib/Filters/Splitter/SplitterFilter.cpp
A lib/Filters/Splitter/SplitterFilter.hpp
A lib/Filters/Stats/CMakeLists.txt
A lib/Filters/Stats/StatsFilter.cpp
A lib/Filters/Stats/StatsFilter.hpp
A lib/Filters/Transformation/CMakeLists.txt
A lib/Filters/Transformation/TransformationFilter.cpp
A lib/Filters/Transformation/TransformationFilter.hpp
A lib/GDALUtils.cpp
A lib/GlobalEnvironment.cpp
A lib/IO/Bpf/BpfHeader.cpp
A lib/IO/Bpf/BpfHeader.hpp
A lib/IO/Bpf/BpfReader.cpp
A lib/IO/Bpf/BpfReader.hpp
A lib/IO/Bpf/CMakeLists.txt
A lib/IO/Buffer/BufferReader.hpp
A lib/IO/CMakeLists.txt
A lib/IO/Faux/CMakeLists.txt
A lib/IO/Faux/FauxReader.cpp
A lib/IO/Faux/FauxReader.hpp
A lib/IO/Las/CMakeLists.txt
A lib/IO/Las/GeotiffSupport.cpp
A lib/IO/Las/GeotiffSupport.hpp
A lib/IO/Las/LasError.hpp
A lib/IO/Las/LasHeader.cpp
A lib/IO/Las/LasHeader.hpp
A lib/IO/Las/LasReader.cpp
A lib/IO/Las/LasReader.hpp
A lib/IO/Las/LasWriter.cpp
A lib/IO/Las/LasWriter.hpp
A lib/IO/Las/SummaryData.cpp
A lib/IO/Las/SummaryData.hpp
A lib/IO/Las/VariableLengthRecord.cpp
A lib/IO/Las/VariableLengthRecord.hpp
A lib/IO/Las/ZipPoint.cpp
A lib/IO/Las/ZipPoint.hpp
A lib/IO/Qfit/CMakeLists.txt
A lib/IO/Qfit/QfitReader.cpp
A lib/IO/Qfit/QfitReader.hpp
A lib/IO/Sbet/CMakeLists.txt
A lib/IO/Sbet/SbetCommon.cpp
A lib/IO/Sbet/SbetCommon.hpp
A lib/IO/Sbet/SbetReader.cpp
A lib/IO/Sbet/SbetReader.hpp
A lib/IO/Sbet/SbetWriter.cpp
A lib/IO/Sbet/SbetWriter.hpp
A lib/IO/Terrasolid/CMakeLists.txt
A lib/IO/Terrasolid/TerrasolidReader.cpp
A lib/IO/Terrasolid/TerrasolidReader.hpp
A lib/IO/Text/CMakeLists.txt
A lib/IO/Text/TextWriter.cpp
A lib/IO/Text/TextWriter.hpp
A lib/KDIndex.cpp
A lib/Kernel.cpp
A lib/KernelFactory.cpp
A lib/KernelInfo.cpp
A lib/KernelSupport.cpp
A lib/Kernels/CMakeLists.txt
A lib/Kernels/Delta/CMakeLists.txt
A lib/Kernels/Delta/DeltaKernel.cpp
A lib/Kernels/Delta/DeltaKernel.hpp
A lib/Kernels/Diff/CMakeLists.txt
A lib/Kernels/Diff/DiffKernel.cpp
A lib/Kernels/Diff/DiffKernel.hpp
A lib/Kernels/Info/CMakeLists.txt
A lib/Kernels/Info/InfoKernel.cpp
A lib/Kernels/Info/InfoKernel.hpp
A lib/Kernels/Pipeline/CMakeLists.txt
A lib/Kernels/Pipeline/PipelineKernel.cpp
A lib/Kernels/Pipeline/PipelineKernel.hpp
A lib/Kernels/Random/CMakeLists.txt
A lib/Kernels/Random/RandomKernel.cpp
A lib/Kernels/Random/RandomKernel.hpp
A lib/Kernels/Sort/CMakeLists.txt
A lib/Kernels/Sort/SortKernel.cpp
A lib/Kernels/Sort/SortKernel.hpp
A lib/Kernels/Translate/CMakeLists.txt
A lib/Kernels/Translate/TranslateKernel.cpp
A lib/Kernels/Translate/TranslateKernel.hpp
A lib/Log.cpp
A lib/Object.cpp
A lib/Options.cpp
A lib/PDALUtils.cpp
A lib/PipelineManager.cpp
A lib/PipelineReader.cpp
A lib/PipelineWriter.cpp
A lib/PointBuffer.cpp
A lib/QuadIndex.cpp
A lib/Reader.cpp
A lib/SpatialReference.cpp
A lib/Stage.cpp
A lib/StageFactory.cpp
A lib/StageInfo.cpp
A lib/StreamFactory.cpp
A lib/Utils.cpp
A lib/Writer.cpp
A lib/XMLSchema.cpp
A lib/pdal_config.cpp
A lib/plang/BufferedInvocation.cpp
A lib/plang/Invocation.cpp
A lib/plang/PythonEnvironment.cpp
A lib/plang/Redirector.cpp
A lib/plang/Redirector.hpp
A lib/plang/Script.cpp
A lib/prototype.vcxproj
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/GroundKernel.hpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/pcl/kernel/ViewKernel.cpp
M plugins/pcl/kernel/ViewKernel.hpp
R src/CMakeLists.txt
R src/Charbuf.cpp
R src/DbReader.cpp
R src/DbWriter.cpp
R src/FileUtils.cpp
R src/Filter.cpp
R src/GDALUtils.cpp
R src/GlobalEnvironment.cpp
R src/KDIndex.cpp
R src/Log.cpp
R src/Object.cpp
R src/Options.cpp
R src/PDALUtils.cpp
R src/PipelineManager.cpp
R src/PipelineReader.cpp
R src/PipelineWriter.cpp
R src/PointBuffer.cpp
R src/QuadIndex.cpp
R src/Reader.cpp
R src/SpatialReference.cpp
R src/Stage.cpp
R src/StageFactory.cpp
R src/StageInfo.cpp
R src/StreamFactory.cpp
R src/Utils.cpp
R src/Writer.cpp
R src/XMLSchema.cpp
R src/pdal_config.cpp
R src/plang/BufferedInvocation.cpp
R src/plang/Invocation.cpp
R src/plang/PythonEnvironment.cpp
R src/plang/Redirector.cpp
R src/plang/Redirector.hpp
R src/plang/Script.cpp
R src/prototype.vcxproj
M test/unit/CMakeLists.txt
M test/unit/SpatialReferenceTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/ColorizationFilterTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/ReprojectionFilterTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/filters/TransformationFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/buffer/BufferTest.cpp
M test/unit/io/faux/FauxReaderTest.cpp
M test/unit/io/las/LasReaderTest.cpp
M test/unit/io/las/LasWriterTest.cpp
M test/unit/io/qfit/QFITReaderTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
M test/unit/io/sbet/SbetWriterTest.cpp
Log Message:
Reorg library files
Public headers remain in ./include/pdal.
All files in ./src move to ./lib to indicate that this is the location
of the source for the main library.
All filters, IO, kernels move from top-level back to ./lib (formerly
./src). The key difference between this and the original layout is that
the headers for these capabilities are now treated as local/private
headers and are not installed as part of the public API.
Kernel class (along with KernelInfo, KernelFactory, KernelSupport) move
into the public API.
Commit: e008b8e8d238427f822b4c1b4102ff88dfe12eb5
https://github.com/PDAL/PDAL/commit/e008b8e8d238427f822b4c1b4102ff88dfe12eb5
Changed paths:
M CMakeLists.txt
A include/pdal/Util/Bounds.hpp
A lib/Util/Bounds.cpp
A lib/Util/CMakeLists.txt
R util/Bounds.cpp
R util/Bounds.hpp
R util/CMakeLists.txt
R util/README
R util/pdal
Log Message:
move ./util to ./lib/Util
Commit: e124e81be245e6c74090010b8e3d061a5b44394a
https://github.com/PDAL/PDAL/commit/e124e81be245e6c74090010b8e3d061a5b44394a
Changed paths:
M include/pdal/Metadata.hpp
M include/pdal/PDALUtils.hpp
M include/pdal/PointBuffer.hpp
M include/pdal/QuadIndex.hpp
M include/pdal/QuickInfo.hpp
M lib/Filters/Chipper/ChipperFilter.hpp
M lib/Filters/Crop/CropFilter.hpp
M lib/IO/Las/LasHeader.hpp
M lib/IO/Las/SummaryData.hpp
M lib/Kernels/Random/RandomKernel.hpp
M plugins/mrsid/io/MrsidReader.hpp
M plugins/oci/io/OciCommon.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
M test/unit/BoundsTest.cpp
M test/unit/Support.hpp
Log Message:
look in the proper location for Bounds
Compare: https://github.com/PDAL/PDAL/compare/fe07f097a756...e124e81be245
More information about the pdal-commits
