[pdal-commits] [PDAL/PDAL] 7bcbbd: Remove lambda with default arg.
GitHub noreply at github.com
Thu Jan 15 08:39:13 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 7bcbbdd559a093f05da6497af888d9db7390cf87
      https://github.com/PDAL/PDAL/commit/7bcbbdd559a093f05da6497af888d9db7390cf87
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-01-15 (Thu, 15 Jan 2015)
  Changed paths:
    M tools/lasdump/Dumper.cpp
  Log Message:
  Commit: 3334338d6d7b931792194cea761dd9973be6a11f
      https://github.com/PDAL/PDAL/commit/3334338d6d7b931792194cea761dd9973be6a11f
  Changed paths:
    M filters/transformation/TransformationFilter.hpp
    A include/pdal/BufferReader.hpp
    M include/pdal/Drivers.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/pdal_export.hpp
    R io/buffer/BufferReader.hpp
    M kernels/Kernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M src/CMakeLists.txt
    M test/unit/io/buffer/BufferTest.cpp
    M util/Bounds.hpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL
Compare: https://github.com/PDAL/PDAL/compare/e587ff3b1496...3334338d6d7b
More information about the pdal-commits mailing list
