[pdal-commits] [PDAL/PDAL] b91c50: initial commit of PDALConfig.cmake
GitHub
noreply at github.com
Tue Jan 20 10:55:39 PST 2015
Branch: refs/heads/PDALConfig
Home: https://github.com/PDAL/PDAL
Commit: b91c50ea3f304e0870f74605d457a2913b16880d
https://github.com/PDAL/PDAL/commit/b91c50ea3f304e0870f74605d457a2913b16880d
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-01-20 (Tue, 20 Jan 2015)
Changed paths:
M CMakeLists.txt
A PDALConfig.cmake.in
A cmake/config.cmake
M cmake/macros.cmake
A examples/writing/CMakeLists.txt
A examples/writing/tutorial.cpp
Log Message:
Those wishing to link against PDAL will not need a FindPDAL.cmake file,
they will only need to set PDAL_DIR to point to PDALConfig.cmake, which
is installed by PDAL (typically in /usr/local/lib/pdal/cmake).
This is a minimal approach for now, only addressing a very basic PDAL
build (i.e., no plugins). It also does not propagate flags, definitions,
etc. as it probably should in the end.
A version of the writing tutorial from the docs is provided as an
example.
Commit: bafd980939dde9d2ed2c83777d3f318f0d478d5b
https://github.com/PDAL/PDAL/commit/bafd980939dde9d2ed2c83777d3f318f0d478d5b
Changed paths:
M CMakeLists.txt
Log Message:
we can specify multiple targets on the export line
Compare: https://github.com/PDAL/PDAL/compare/7265d20a0c7c...bafd980939dd
More information about the pdal-commits
