[pdal-commits] [PDAL/PDAL] bf6bb4: add gcc-multilib and g++-multilib to the Vagrant c...
GitHub
noreply at github.com
Wed Jan 21 08:42:38 PST 2015
Branch: refs/heads/issues/version-info
Home: https://github.com/PDAL/PDAL
Commit: bf6bb4ef61d0a0950bc59d2eabda4e56b1ab40cb
https://github.com/PDAL/PDAL/commit/bf6bb4ef61d0a0950bc59d2eabda4e56b1ab40cb
Author: Howard Butler <howard at hobu.co>
Date: 2015-01-20 (Tue, 20 Jan 2015)
Changed paths:
M Vagrantfile
Log Message:
add gcc-multilib and g++-multilib to the Vagrant config
Commit: 73cef630125b2067486afe729b5f9968deb18e0b
https://github.com/PDAL/PDAL/commit/73cef630125b2067486afe729b5f9968deb18e0b
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M plugins/rxp/CMakeLists.txt
Log Message:
Fix rivlib test's cmakelists
The plugin directory was named incorrectly, breaking tests.
Commit: 5adf4c19f7d1ee1f80214da6c90af3dcb065ecf0
https://github.com/PDAL/PDAL/commit/5adf4c19f7d1ee1f80214da6c90af3dcb065ecf0
Changed paths:
Log Message:
Merge pull request #718 from gadomski/rivlib-tests
Commit: 2487515d7f077e6f64f27b0c2b434bdcfeeb711d
https://github.com/PDAL/PDAL/commit/2487515d7f077e6f64f27b0c2b434bdcfeeb711d
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M include/pdal/Writer.hpp
M io/bpf/BpfWriter.cpp
M io/bpf/BpfWriter.hpp
M io/las/LasWriter.cpp
M io/las/LasWriter.hpp
M src/Writer.cpp
Log Message:
Add scaling to BPF writer.
Commit: fa986d10179e864bca4ffc7941b7fd76a181cffd
https://github.com/PDAL/PDAL/commit/fa986d10179e864bca4ffc7941b7fd76a181cffd
Date: 2015-01-21 (Wed, 21 Jan 2015)
Changed paths:
M CMakeLists.txt
M scripts/ci/script.sh
M scripts/vagrant/pdal.sh
Log Message:
BUILD_PLUGIN_PYTHON should not depend
The WITH_PYTHON option was removed in
76a82b61fdeadd8f16092873d67bc39168dcef45, causing BUILD_PLUGIN_PYTHON to
not appear for fresh builds. Our Travis scripts were still setting this
option, causing the python tests to still run.
Commit: b16eb2500462c363d5b0c8ea683dfe19c5770c20
https://github.com/PDAL/PDAL/commit/b16eb2500462c363d5b0c8ea683dfe19c5770c20
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #720 from gadomski/with-python
BUILD_PLUGIN_PYTHON should not depend on WITH_PYTHON
Commit: 641a0dcfa96684b5b4cfe66e665c6d75988b9ef9
https://github.com/PDAL/PDAL/commit/641a0dcfa96684b5b4cfe66e665c6d75988b9ef9
Changed paths:
M CMakeLists.txt
M Vagrantfile
M src/Writer.cpp
Log Message:
Merge branch 'master' into issues/version-info
Compare: https://github.com/PDAL/PDAL/compare/6d7f10cc45e5...641a0dcfa966
More information about the pdal-commits
