[pdal-commits] [PDAL/PDAL] cfad73: We were using the default dimension name rather th...
GitHub noreply at github.com
Wed Jan 21 14:45:54 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: cfad732f824d491fe97b8e0087399ea2a36eaee7
      https://github.com/PDAL/PDAL/commit/cfad732f824d491fe97b8e0087399ea2a36eaee7
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-01-21 (Wed, 21 Jan 2015)
  Changed paths:
    M src/plang/BufferedInvocation.cpp
  Log Message:
  We were using the default dimension name rather than the actual dimension name for filtering. Custom dimensions ended up being ''
  Commit: 440fbd001ad547b7283c0a3db94e05c652e5a900
      https://github.com/PDAL/PDAL/commit/440fbd001ad547b7283c0a3db94e05c652e5a900
  Changed paths:
  Log Message:
  Merge pull request #721 from PDAL/use-real-dimension-name-for-filtering
Compare: https://github.com/PDAL/PDAL/compare/85114890ac49...440fbd001ad5
More information about the pdal-commits mailing list
