[pdal-commits] [PDAL/PDAL] f7ac9f: Create/use classes to insert/extract byte-ordered ...
GitHub
noreply at github.com
Wed Jan 28 08:43:19 PST 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: f7ac9f5ed5da47a888c88c899af2383379ff97e5
https://github.com/PDAL/PDAL/commit/f7ac9f5ed5da47a888c88c899af2383379ff97e5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-01-27 (Tue, 27 Jan 2015)
Changed paths:
A include/pdal/Extractor.hpp
A include/pdal/Inserter.hpp
M io/las/LasReader.cpp
M io/las/LasWriter.cpp
Log Message:
Create/use classes to insert/extract byte-ordered data from a buffer.
Commit: 68e6fcde5c59efbedfc2e7945f375deecb35321b
https://github.com/PDAL/PDAL/commit/68e6fcde5c59efbedfc2e7945f375deecb35321b
Changed paths:
M include/pdal/Utils.hpp
Log Message:
Don't create copy of collection when finding.
Commit: c962d557ef415f2eff6c851f810f4a5750154348
https://github.com/PDAL/PDAL/commit/c962d557ef415f2eff6c851f810f4a5750154348
Changed paths:
M include/pdal/PointBuffer.hpp
Log Message:
Avoid numeric cast if possible.
Commit: c63f198db2f08caa2a47b34f4c7409a248e22a12
https://github.com/PDAL/PDAL/commit/c63f198db2f08caa2a47b34f4c7409a248e22a12
Date: 2015-01-28 (Wed, 28 Jan 2015)
Changed paths:
M include/pdal/Reader.hpp
M io/las/LasReader.hpp
Log Message:
Don't call clearTemps() each time a point is added.
Read LAS points in blocks.
Commit: 742edb3fe7bd730ec25c68014446b829deb32ff7
https://github.com/PDAL/PDAL/commit/742edb3fe7bd730ec25c68014446b829deb32ff7
Changed paths:
M CMakeLists.txt
M Vagrantfile
M apps/CMakeLists.txt
M apps/pdal.cpp
R apps/pdal.pc.in
M cmake/directories.cmake
M cmake/macros.cmake
M doc/conf.py
R include/pdal/Algorithm.hpp
R include/pdal/Endian.hpp
R include/pdal/FileUtils.hpp
A include/pdal/Kernel.hpp
A include/pdal/KernelFactory.hpp
A include/pdal/KernelInfo.hpp
A include/pdal/KernelSupport.hpp
M include/pdal/Log.hpp
R include/pdal/Object.hpp
A include/pdal/util/Algorithm.hpp
A include/pdal/util/Endian.hpp
A include/pdal/util/FileUtils.hpp
M io/qfit/QfitReader.cpp
M io/terrasolid/TerrasolidReader.cpp
M io/text/TextWriter.cpp
M io/text/TextWriter.hpp
M kernels/CMakeLists.txt
R kernels/Kernel.cpp
R kernels/Kernel.hpp
R kernels/KernelFactory.cpp
R kernels/KernelFactory.hpp
R kernels/KernelInfo.cpp
R kernels/KernelInfo.hpp
R kernels/KernelSupport.cpp
R kernels/KernelSupport.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.cpp
M kernels/sort/SortKernel.hpp
M kernels/translate/TranslateKernel.cpp
M kernels/translate/TranslateKernel.hpp
M plugins/icebridge/io/Hdf5Handler.cpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/mrsid/io/MrsidReader.hpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/oci/io/OciCommon.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/pcl/io/PcdWriter.hpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/GroundKernel.hpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/pcl/kernel/ViewKernel.cpp
M plugins/pcl/kernel/ViewKernel.hpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M plugins/sqlite/test/SQLiteTest.cpp
M scripts/ci/script.sh
M src/CMakeLists.txt
R src/FileUtils.cpp
A src/Kernel.cpp
A src/KernelFactory.cpp
A src/KernelInfo.cpp
A src/KernelSupport.cpp
R src/Object.cpp
M src/Options.cpp
M src/PipelineReader.cpp
M src/PipelineWriter.cpp
M src/StreamFactory.cpp
M src/plang/Script.cpp
A src/util/Bounds.cpp
A src/util/CMakeLists.txt
A src/util/FileUtils.cpp
M test/unit/FileUtilsTest.cpp
M test/unit/GDALUtilsTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/StreamFactoryTest.cpp
M test/unit/Support.cpp
M test/unit/SupportTest.cpp
M test/unit/XMLSchemaTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/apps/pcinfoTest.cpp
M test/unit/apps/pcpipelineTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/las/LasWriterTest.cpp
R util/Bounds.cpp
R util/CMakeLists.txt
R util/README
R util/pdal
Log Message:
Merge branch 'master' of https://github.com/PDAL/PDAL
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/7e2fcf9b909d...742edb3fe7bd
More information about the pdal-commits
