[pdal-commits] [PDAL/PDAL] 765c0a: Turn PCL on in Travis as an optional component
GitHub
noreply at github.com
Sat Jul 18 08:15:18 PDT 2015
Branch: refs/tags/grid-1.4.0.1
Home: https://github.com/PDAL/PDAL
Commit: 765c0a0802ca260341ab591bf68e635cb4423120
https://github.com/PDAL/PDAL/commit/765c0a0802ca260341ab591bf68e635cb4423120
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-06-19 (Fri, 19 Jun 2015)
Changed paths:
M scripts/ci/before_install.sh
M scripts/ci/script.sh
Log Message:
Commit: 17124c81cd40d38a514afa0e54a97ffda0232e24
https://github.com/PDAL/PDAL/commit/17124c81cd40d38a514afa0e54a97ffda0232e24
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-07-01 (Wed, 01 Jul 2015)
Changed paths:
M plugins/pcl/io/PCLVisualizer.hpp
M plugins/pcl/io/PcdWriter.hpp
Log Message:
Add back ctors.
Commit: dfea62c7bb58972d7e82f4a2554032715eccdb7a
https://github.com/PDAL/PDAL/commit/dfea62c7bb58972d7e82f4a2554032715eccdb7a
Date: 2015-07-02 (Thu, 02 Jul 2015)
Changed paths:
M doc/stages/writers.bpf.rst
A include/pdal/FlexWriter.hpp
M include/pdal/Writer.hpp
M include/pdal/util/OStream.hpp
M io/bpf/BpfWriter.cpp
M io/bpf/BpfWriter.hpp
M src/CMakeLists.txt
M test/unit/io/bpf/BPFTest.cpp
Log Message:
Make BpfWriter a FlexWriter.
Commit: dbe9c2fbb9d0da15d4903f5d25b937626f5ed51d
https://github.com/PDAL/PDAL/commit/dbe9c2fbb9d0da15d4903f5d25b937626f5ed51d
Author: Howard Butler <howard at hobu.co>
Date: 2015-07-03 (Fri, 03 Jul 2015)
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into grid-1.4.0
Commit: 56d42d1734f9866106ee603887fb511551147b1f
https://github.com/PDAL/PDAL/commit/56d42d1734f9866106ee603887fb511551147b1f
Changed paths:
Log Message:
PclVisualizer typo
Commit: c408c6bbc112becff054558393d37af7ab7fc2e8
https://github.com/PDAL/PDAL/commit/c408c6bbc112becff054558393d37af7ab7fc2e8
Changed paths:
M kernels/tindex/TIndexKernel.cpp
Log Message:
make sure to set filename when fetching file info in tindex
Commit: d73524d08e45b55e4633e8622e37d5e69a26a1d2
https://github.com/PDAL/PDAL/commit/d73524d08e45b55e4633e8622e37d5e69a26a1d2
Changed paths:
Log Message:
trap for when we can't make the filters.hexbin stage in tindex
Commit: e4f2927e765dafaac13aa36d55a9c9a3468e0029
https://github.com/PDAL/PDAL/commit/e4f2927e765dafaac13aa36d55a9c9a3468e0029
Changed paths:
Log Message:
bring forward inferred options from the writer (for compression) for tindex
Commit: 990b21de2cf52efa9f8db170c5e784a7cc01b9e3
https://github.com/PDAL/PDAL/commit/990b21de2cf52efa9f8db170c5e784a7cc01b9e3
Changed paths:
M src/Kernel.cpp
Log Message:
take in offsets as strings instead of doubles in setCommonOptions to support auto
Commit: 16bbd1587ed78d83264111c68fa4819736e13ddb
https://github.com/PDAL/PDAL/commit/16bbd1587ed78d83264111c68fa4819736e13ddb
Changed paths:
M kernels/translate/TranslateKernel.cpp
Log Message:
use correct options for reprojectionStage in kernels.translate
Commit: 089156986055fd282ea13a79debccbf4605ed639
https://github.com/PDAL/PDAL/commit/089156986055fd282ea13a79debccbf4605ed639
Date: 2015-07-05 (Sun, 05 Jul 2015)
Changed paths:
M cmake/compiler_options.cmake
M cmake/win32_compiler_options.cmake
Log Message:
Revert "Set default build type to RelWithDebInfo."
This reverts commit d49efb7bd0d4fd2c44dcc7d52d481fd4d0161a34.
Commit: 1b8c75b0d40f0f0403298b0a57ac475d4f5a725a
https://github.com/PDAL/PDAL/commit/1b8c75b0d40f0f0403298b0a57ac475d4f5a725a
Changed paths:
Log Message:
Merge pull request #943 from PDAL/pcl-travis
Commit: c378b6c9fba0fa55ac1b742278a98c86373343e4
https://github.com/PDAL/PDAL/commit/c378b6c9fba0fa55ac1b742278a98c86373343e4
Date: 2015-07-06 (Mon, 06 Jul 2015)
Changed paths:
M io/las/LasWriter.cpp
M io/las/LasWriter.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/NitfWriter.hpp
M test/unit/io/las/LasWriterTest.cpp
Log Message:
Make LasWriter a FlexWriter.
Commit: 5d4f28ac074cec54934a10657ffaed329d806fbc
https://github.com/PDAL/PDAL/commit/5d4f28ac074cec54934a10657ffaed329d806fbc
Changed paths:
M doc/stages/writers.las.rst
Log Message:
Add documentation for LasWriter as FlexWriter.
Commit: 3cf759b2e5dac96c71c36a68b5fdb3c7798ef4d2
https://github.com/PDAL/PDAL/commit/3cf759b2e5dac96c71c36a68b5fdb3c7798ef4d2
Date: 2015-07-07 (Tue, 07 Jul 2015)
Changed paths:
M io/las/LasReader.cpp
M plugins/nitf/io/MetadataReader.cpp
M plugins/nitf/io/NitfFile.cpp
M plugins/nitf/io/NitfReader.cpp
M plugins/nitf/test/NitfWriterTest.cpp
Log Message:
Add tests for NitfWriter as FlexWriter.
Commit: 835a7d7a1e92eebae60b8aec45c10aafebe2b3c8
https://github.com/PDAL/PDAL/commit/835a7d7a1e92eebae60b8aec45c10aafebe2b3c8
Date: 2015-07-08 (Wed, 08 Jul 2015)
Changed paths:
M doc/stages/writers.nitf.rst
Log Message:
Update NitfWriter documentation.
Remove dead code.
Commit: d880913e032a14476061e56ddfdac0fd5d634c28
https://github.com/PDAL/PDAL/commit/d880913e032a14476061e56ddfdac0fd5d634c28
Date: 2015-07-10 (Fri, 10 Jul 2015)
Changed paths:
Log Message:
Fix comment typo.
Commit: b62a05b3b654db332d452f09218b85bb41822cde
https://github.com/PDAL/PDAL/commit/b62a05b3b654db332d452f09218b85bb41822cde
Changed paths:
M test/unit/filters/ReprojectionFilterTest.cpp
Log Message:
Fix GEOTIFF include directive.
Commit: 95f6d9447bf90f28d6e037bfbc017d8f88eb579d
https://github.com/PDAL/PDAL/commit/95f6d9447bf90f28d6e037bfbc017d8f88eb579d
Changed paths:
Log Message:
Fix repro filter test now that GEOTIFF macro is fixed.
Commit: d7312644c3180a1e68346f6cced5674f2b098155
https://github.com/PDAL/PDAL/commit/d7312644c3180a1e68346f6cced5674f2b098155
Changed paths:
M io/las/GeotiffSupport.cpp
Log Message:
Remove dead code.
Commit: 2af45ade3b219459749e7ec2db7a29ae6ffb1853
https://github.com/PDAL/PDAL/commit/2af45ade3b219459749e7ec2db7a29ae6ffb1853
Date: 2015-07-13 (Mon, 13 Jul 2015)
Changed paths:
M doc/stages/filters.stats.rst
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
Add "count" option to stats filter.
Close #955
Commit: 3363eb800219f1163879caf068fc3551f3749ecc
https://github.com/PDAL/PDAL/commit/3363eb800219f1163879caf068fc3551f3749ecc
Changed paths:
M kernels/info/InfoKernel.cpp
Log Message:
Allow info kernel to take extra command-line options.
Commit: 6a676e94ac9caa2c0d8f48ee967ade474a268f92
https://github.com/PDAL/PDAL/commit/6a676e94ac9caa2c0d8f48ee967ade474a268f92
Changed paths:
Log Message:
Fix writing of point formats 6-10 to match spec.
Commit: 38f77ae3b71a85768342d1ea6dbdca6b16760a2a
https://github.com/PDAL/PDAL/commit/38f77ae3b71a85768342d1ea6dbdca6b16760a2a
Date: 2015-07-14 (Tue, 14 Jul 2015)
Changed paths:
Log Message:
Fix 1.4 scan angle.
Commit: 813dd0031846c469000950dd2e2cc36b88aa11a5
https://github.com/PDAL/PDAL/commit/813dd0031846c469000950dd2e2cc36b88aa11a5
Changed paths:
M test/unit/CompressionTest.cpp
Log Message:
Update CompressionTest for new schema.
Commit: 82bfafc137b799df9528bb7a02c123edd05eca0d
https://github.com/PDAL/PDAL/commit/82bfafc137b799df9528bb7a02c123edd05eca0d
Date: 2015-07-15 (Wed, 15 Jul 2015)
Changed paths:
M include/pdal/Metadata.hpp
M include/pdal/Options.hpp
R include/pdal/Utils.hpp
A include/pdal/util/Utils.hpp
M io/las/LasError.hpp
M io/las/LasHeader.cpp
M io/las/LasUtils.cpp
M plugins/oci/io/OciCommon.cpp
M plugins/pgpointcloud/io/PgCommon.hpp
M src/GDALUtils.cpp
M src/KernelFactory.cpp
M src/KernelSupport.cpp
M src/Log.cpp
M src/PipelineManager.cpp
M src/PluginManager.cpp
M src/PointLayout.cpp
M src/QuadIndex.cpp
M src/SpatialReference.cpp
M src/StageFactory.cpp
R src/Utils.cpp
M src/pdal_config.cpp
M src/util/CMakeLists.txt
M src/util/FileUtils.cpp
A src/util/Utils.cpp
M test/unit/FileUtilsTest.cpp
M test/unit/Support.hpp
M test/unit/SupportTest.cpp
M test/unit/UtilsTest.cpp
M test/unit/apps/MergeTest.cpp
Log Message:
Move Utils.XX to util subdir.
Commit: be086e00aa2cd2bcc967a2dc731a197c62c1481d
https://github.com/PDAL/PDAL/commit/be086e00aa2cd2bcc967a2dc731a197c62c1481d
Changed paths:
M include/pdal/PDALUtils.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/diff/DiffKernel.cpp
M src/Kernel.cpp
M src/Options.cpp
M src/PDALUtils.cpp
M src/PipelineWriter.cpp
M test/unit/BoundsTest.cpp
M test/unit/OptionsTest.cpp
M test/unit/PDALUtilsTest.cpp
M test/unit/PointViewTest.cpp
Log Message:
Put all utilities in the same namespace.
Commit: e4913f75be8590fc090362405aa6ecca04caedb2
https://github.com/PDAL/PDAL/commit/e4913f75be8590fc090362405aa6ecca04caedb2
Changed paths:
M src/PDALUtils.cpp
Log Message:
Remove dead code.
Commit: fca26d854440d60c66b4447d6709317380ccfac7
https://github.com/PDAL/PDAL/commit/fca26d854440d60c66b4447d6709317380ccfac7
Date: 2015-07-16 (Thu, 16 Jul 2015)
Changed paths:
M src/GDALUtils.cpp
M src/Kernel.cpp
M src/Log.cpp
M src/Options.cpp
M src/PDALUtils.cpp
M src/QuadIndex.cpp
R src/Utils.cpp
Log Message:
Merge branch 'master' into grid-1.4.0
Commit: 2ca6d1324327392b08166701f888af0c1414cf59
https://github.com/PDAL/PDAL/commit/2ca6d1324327392b08166701f888af0c1414cf59
Date: 2015-07-18 (Sat, 18 Jul 2015)
Changed paths:
M test/unit/apps/pcpipelineTest.cpp
Log Message:
some unix compilation fixups for gcc 4.8
Compare: https://github.com/PDAL/PDAL/compare/b9fcb740ecfb...2ca6d1324327
More information about the pdal-commits
