[pdal-commits] [PDAL/PDAL] 13bbb0: Initial attempt at setting GeoWave up as a plugin ...
GitHub
noreply at github.com
Wed Mar 4 14:04:43 PST 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 13bbb03f2445f69fdb9e7a7cd054346a20b32730
https://github.com/PDAL/PDAL/commit/13bbb03f2445f69fdb9e7a7cd054346a20b32730
Author: Whitney O'Meara <womeara at radiantblue.com>
Date: 2015-02-26 (Thu, 26 Feb 2015)
Changed paths:
M Vagrantfile
A scripts/linux-install-scripts/geowave
A scripts/linux-install-scripts/geowave.sh
M scripts/linux-install-scripts/packages.sh
R scripts/linux-install-scripts/pdal.sh
A scripts/linux-install-scripts/pdal_clone.sh
A scripts/linux-install-scripts/pdal_install.sh
M scripts/linux-install-scripts/startup.sh
A scripts/vagrant/loadgeowave.xml
A scripts/vagrant/readgeowave.xml
Log Message:
Initial attempt at setting GeoWave up as a plugin within Vagrant.
Commit: 0bccf2ce4725d5d4d93d7626e143849f870590fc
https://github.com/PDAL/PDAL/commit/0bccf2ce4725d5d4d93d7626e143849f870590fc
Date: 2015-02-27 (Fri, 27 Feb 2015)
Changed paths:
M plugins/geowave/io/GeoWaveReader.cpp
M plugins/geowave/io/GeoWaveWriter.cpp
M scripts/linux-install-scripts/geowave.sh
R scripts/vagrant/loadgeowave.xml
R scripts/vagrant/readgeowave.xml
Log Message:
Updated GeoWave plugin to check to see if the JVM is already running. Also udpated GeoWaveReader to limit query results by count.
Commit: cec222c259cdeac56272a4ef13bf9f57f355f908
https://github.com/PDAL/PDAL/commit/cec222c259cdeac56272a4ef13bf9f57f355f908
Author: Howard Butler <howard at hobu.co>
Date: 2015-03-04 (Wed, 04 Mar 2015)
Changed paths:
M Vagrantfile
Log Message:
Merge pull request #776 from jwomeara/geowave-vagrant
Geowave vagrant
Compare: https://github.com/PDAL/PDAL/compare/cbe194edf5d3...cec222c259cd
More information about the pdal-commits
