[pdal-commits] [PDAL/PDAL] 34e4d8: Seek to the end of an IStream
GitHub
noreply at github.com
Tue Mar 10 10:46:56 PDT 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 34e4d82e63880b4bbe569b5c563550cf2405a180
https://github.com/PDAL/PDAL/commit/34e4d82e63880b4bbe569b5c563550cf2405a180
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2015-03-10 (Tue, 10 Mar 2015)
Changed paths:
M include/pdal/util/IStream.hpp
Log Message:
Adds an overload on IStream::seek that allows seeking from position.
Commit: 7052f43253eb0446a98f75cfcb8d935fbcb4001f
https://github.com/PDAL/PDAL/commit/7052f43253eb0446a98f75cfcb8d935fbcb4001f
Changed paths:
M include/pdal/util/Extractor.hpp
Log Message:
Add Switchable Extractor and IStream
These switchable variants can be used in the QFit reader, which has to
determine the endianness of its source data at runtime. I could have
done this with virtuals, but I thought I'd make it explicit and not
sully up the existing ILeStream and LeExtractor interface.
Commit: cf383ad9fdd6fa5f809d6b33e54fc391d376a25e
https://github.com/PDAL/PDAL/commit/cf383ad9fdd6fa5f809d6b33e54fc391d376a25e
Changed paths:
M io/qfit/QfitReader.cpp
M io/qfit/QfitReader.hpp
Log Message:
Refactor the QFit reader to not use Utils::read_n
Instead, we use the new SwitchableExtractor and ISwitchableStream.
One step along to road for #783.
Commit: 1839bb272a9b726e7e605d1fc981def494b9e11a
https://github.com/PDAL/PDAL/commit/1839bb272a9b726e7e605d1fc981def494b9e11a
Changed paths:
M io/terrasolid/TerrasolidReader.hpp
M test/unit/CMakeLists.txt
A test/unit/io/terrasolid/TerrasolidReaderTest.cpp
Log Message:
Add TerrasolidReaderTest
Note that the tests fail at this point, because the TerrasolidReader is
broken.
Commit: 98abdda7f50a9b87871681c6a4671193a3cf99d3
https://github.com/PDAL/PDAL/commit/98abdda7f50a9b87871681c6a4671193a3cf99d3
Changed paths:
M io/terrasolid/TerrasolidReader.cpp
Log Message:
Increment counter in TerrasolidReader
The reader was broken, stuck in an infinite loop.
Commit: 3403025515332b3f6b78abb6825d812b0bc408dd
https://github.com/PDAL/PDAL/commit/3403025515332b3f6b78abb6825d812b0bc408dd
Changed paths:
Log Message:
Smarten up the Terrasolid return number
The Terrasolid spec doesn't give us real return number information, for
whatever reason, but if it is a first or only return we can
intelligently set those values. Otherwise we're SOL.
Commit: c6890b916d94a322c925ad7b950149a0068ff694
https://github.com/PDAL/PDAL/commit/c6890b916d94a322c925ad7b950149a0068ff694
Changed paths:
Log Message:
Remove read_n from Terrasolid reader
More progress on #783.
Commit: 2cecc1dbc9d86d75f86a934e3c572fec86f4f47a
https://github.com/PDAL/PDAL/commit/2cecc1dbc9d86d75f86a934e3c572fec86f4f47a
Changed paths:
M include/pdal/Utils.hpp
Log Message:
Remove read_n and read_field from Utils.hpp
They have been superseded by IStream and Extractor.
Fixes #783.
Commit: ddf20bd18a7b6f599d72a2d87e8e2086b62faad7
https://github.com/PDAL/PDAL/commit/ddf20bd18a7b6f599d72a2d87e8e2086b62faad7
Changed paths:
Log Message:
Merge pull request #791 from gadomski/issues/783-purge-read-n
Purge read_n and read_field from Utils.hpp
Compare: https://github.com/PDAL/PDAL/compare/98adff6c1d0a...ddf20bd18a7b
More information about the pdal-commits
