[pdal-commits] [PDAL/PDAL] 6d23d7: Add RialtoWriter
GitHub
noreply at github.com
Wed Mar 11 07:39:19 PDT 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 6d23d72059e02e4f32c5f7ad14ff750278fff967
https://github.com/PDAL/PDAL/commit/6d23d72059e02e4f32c5f7ad14ff750278fff967
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-03-11 (Wed, 11 Mar 2015)
Changed paths:
A doc/stages/writers.rialto.rst
M include/pdal/util/FileUtils.hpp
M io/CMakeLists.txt
A io/rialto/CMakeLists.txt
A io/rialto/RialtoCommon.cpp
A io/rialto/RialtoCommon.hpp
A io/rialto/RialtoWriter.cpp
A io/rialto/RialtoWriter.hpp
M src/StageFactory.cpp
M src/util/FileUtils.cpp
A test/data/io/header.json
M test/unit/CMakeLists.txt
A test/unit/io/rialto/RialtoWriterTest.cpp
Log Message:
Add RialtoWriter
RialtoWriter is a tiled format that is currently under development. See
http://lists.osgeo.org/pipermail/pointdown/2015-February/000001.html for more
information.
In addition to the RialtoWriter, we have added several functions to FileUtils
to facilitate handling of directories (existance, recursive removal, and
creation).
We have also fixed a bug in TranslateKernel, in which the output_srs option was
not being passed to the reprojection filter.
Commit: 4c4464fa1bc3aed3ecdf30db625eed0e3243c64e
https://github.com/PDAL/PDAL/commit/4c4464fa1bc3aed3ecdf30db625eed0e3243c64e
Changed paths:
M io/rialto/RialtoCommon.cpp
M io/rialto/RialtoCommon.hpp
M io/rialto/RialtoWriter.cpp
M io/rialto/RialtoWriter.hpp
M test/unit/io/rialto/RialtoWriterTest.cpp
Log Message:
update RialtoWriter per the recent plugin changes, make sure it compiles on msvc
Commit: d685a3a9b8f00440460586274fd51f5c264a276d
https://github.com/PDAL/PDAL/commit/d685a3a9b8f00440460586274fd51f5c264a276d
Changed paths:
Log Message:
getDefaultOptions is no longer static
Commit: d68427c292ff60a118d818f089dc286ebc3e7834
https://github.com/PDAL/PDAL/commit/d68427c292ff60a118d818f089dc286ebc3e7834
Changed paths:
Log Message:
add RialtoWriter to StageFactory and sort sections by filters/readers/writers
Commit: 1eaf0f8dd63b22fcca0e2fb000ebd8c6a16e42e7
https://github.com/PDAL/PDAL/commit/1eaf0f8dd63b22fcca0e2fb000ebd8c6a16e42e7
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M io/CMakeLists.txt
Log Message:
Merge pull request #784 from PDAL/rialto-writer
Add RialtoWriter
Compare: https://github.com/PDAL/PDAL/compare/ebba6662eae0...1eaf0f8dd63b
More information about the pdal-commits
