[pdal-commits] [PDAL/PDAL] 814077: Remove unused arguments.
GitHub
noreply at github.com
Fri Mar 13 09:42:01 PDT 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 814077b55c5b227f38e7f19a4d32af5109a6fe43
https://github.com/PDAL/PDAL/commit/814077b55c5b227f38e7f19a4d32af5109a6fe43
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-03-13 (Fri, 13 Mar 2015)
Changed paths:
M include/pdal/KDIndex.hpp
M io/bpf/BpfCompressor.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/info/InfoKernel.cpp
M src/KDIndex.cpp
M test/unit/PointBufferTest.cpp
Log Message:
Commit: 39aa7d7c6d355f5bcd6d3d298aec8ca34d8eb1de
https://github.com/PDAL/PDAL/commit/39aa7d7c6d355f5bcd6d3d298aec8ca34d8eb1de
Changed paths:
M README.md
A appveyor.yml
M cmake/compiler_options.cmake
M cmake/unix_compiler_options.cmake
M cmake/win32_compiler_options.cmake
A doc/_static/logo/dongle/back.ai
A doc/_static/logo/dongle/front.ai
M doc/compilation/dependencies.rst
M doc/conf.py
M doc/stages/filters.chipper.rst
M doc/stages/filters.programmable.rst
M doc/stages/index.rst
M doc/stages/readers.buffer.rst
M doc/stages/readers.nitf.rst
A doc/stages/readers.sqlite.rst
M doc/stages/writers.rialto.rst
A doc/stages/writers.sqlite.rst
M doc/tutorial/pcl_block_tutorial.rst
M doc/tutorial/pcl_spec.rst
M doc/vagrant.rst
M include/pdal/GDALUtils.hpp
M include/pdal/PointBuffer.hpp
M include/pdal/pdal_types.hpp
M include/pdal/plugin.h
M include/pdal/util/Bounds.hpp
M include/pdal/util/FileUtils.hpp
M io/las/GeotiffSupport.hpp
M io/las/LasHeader.cpp
M io/optech/OptechReader.cpp
M plugins/nitf/io/MetadataReader.hpp
M plugins/nitf/io/NitfFile.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/pcl/io/PCLVisualizer.cpp
M plugins/pcl/pipeline/PCLPipeline.cpp
M plugins/python/filters/PredicateFilter.cpp
M plugins/python/filters/ProgrammableFilter.cpp
A scripts/appveyor/install.cmd
M src/DynamicLibrary.cpp
M src/PipelineReader.cpp
M src/PluginManager.cpp
M src/Utils.cpp
M test/data/plang/from-module.xml.in
M test/unit/FileUtilsTest.cpp
M test/unit/Support.cpp
M test/unit/SupportTest.cpp
M test/unit/UserCallbackTest.cpp
M test/unit/apps/pcinfoTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/io/qfit/QFITReaderTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/61151e495335...39aa7d7c6d35
More information about the pdal-commits
