[pdal-commits] [PDAL/PDAL] 3a01bd: Duplicate Context/Buffer -> Table/View.
GitHub
noreply at github.com
Sun Mar 15 11:03:39 PDT 2015
Branch: refs/heads/layout
Home: https://github.com/PDAL/PDAL
Commit: 3a01bdce64990b178d1f7b93c5d17adeb034da9a
https://github.com/PDAL/PDAL/commit/3a01bdce64990b178d1f7b93c5d17adeb034da9a
Author: Connor Manning <connor at hobu.co>
Date: 2015-03-14 (Sat, 14 Mar 2015)
Changed paths:
M include/pdal/Metadata.hpp
A include/pdal/PointTable.hpp
A include/pdal/PointView.hpp
A include/pdal/PointViewIter.hpp
M src/CMakeLists.txt
A src/PointTable.cpp
A src/PointView.cpp
Log Message:
Commit: c3a295b1dc3cd345c85e61a8ebc7093d64acc728
https://github.com/PDAL/PDAL/commit/c3a295b1dc3cd345c85e61a8ebc7093d64acc728
Date: 2015-03-15 (Sun, 15 Mar 2015)
Changed paths:
A include/pdal/PointLayout.hpp
M include/pdal/PointView.hpp
A src/PointLayout.cpp
M src/PointTable.cpp
M src/PointView.cpp
Log Message:
Layout/table/view separation sample.
Commit: 03313efe711f7806c1e2c759ccf0c5b5d188fc08
https://github.com/PDAL/PDAL/commit/03313efe711f7806c1e2c759ccf0c5b5d188fc08
Changed paths:
M filters/chipper/ChipperFilter.cpp
M filters/chipper/ChipperFilter.hpp
M filters/colorization/ColorizationFilter.cpp
M filters/colorization/ColorizationFilter.hpp
M filters/crop/CropFilter.cpp
M filters/crop/CropFilter.hpp
M filters/decimation/DecimationFilter.cpp
M filters/decimation/DecimationFilter.hpp
M filters/ferry/FerryFilter.cpp
M filters/ferry/FerryFilter.hpp
M filters/merge/MergeFilter.hpp
M filters/mortonorder/MortonOrderFilter.cpp
M filters/mortonorder/MortonOrderFilter.hpp
M filters/range/RangeFilter.cpp
M filters/range/RangeFilter.hpp
M filters/reprojection/ReprojectionFilter.cpp
M filters/reprojection/ReprojectionFilter.hpp
M filters/sort/SortFilter.hpp
M filters/splitter/SplitterFilter.cpp
M filters/splitter/SplitterFilter.hpp
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M filters/transformation/TransformationFilter.cpp
M filters/transformation/TransformationFilter.hpp
M include/pdal/BufferReader.hpp
M include/pdal/Compression.hpp
M include/pdal/DbReader.hpp
M include/pdal/DbWriter.hpp
M include/pdal/Filter.hpp
M include/pdal/KDIndex.hpp
M include/pdal/Kernel.hpp
M include/pdal/PDALUtils.hpp
M include/pdal/PipelineManager.hpp
M include/pdal/PipelineWriter.hpp
R include/pdal/PointBuffer.hpp
R include/pdal/PointBufferIter.hpp
R include/pdal/PointContext.hpp
M include/pdal/PointTable.hpp
M include/pdal/QuadIndex.hpp
R include/pdal/RawPtBuf.hpp
M include/pdal/Reader.hpp
M include/pdal/Stage.hpp
M include/pdal/Writer.hpp
M io/bpf/BpfReader.cpp
M io/bpf/BpfReader.hpp
M io/bpf/BpfWriter.cpp
M io/bpf/BpfWriter.hpp
M io/faux/FauxReader.cpp
M io/faux/FauxReader.hpp
M io/las/LasReader.cpp
M io/las/LasReader.hpp
M io/las/LasWriter.cpp
M io/las/LasWriter.hpp
M io/optech/OptechReader.cpp
M io/optech/OptechReader.hpp
M io/qfit/QfitReader.cpp
M io/qfit/QfitReader.hpp
M io/rialto/RialtoCommon.cpp
M io/rialto/RialtoCommon.hpp
M io/rialto/RialtoWriter.cpp
M io/rialto/RialtoWriter.hpp
M io/sbet/SbetReader.cpp
M io/sbet/SbetReader.hpp
M io/sbet/SbetWriter.cpp
M io/sbet/SbetWriter.hpp
M io/terrasolid/TerrasolidReader.cpp
M io/terrasolid/TerrasolidReader.hpp
M io/text/TextWriter.cpp
M io/text/TextWriter.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.cpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/translate/TranslateKernel.cpp
M plugins/pgpointcloud/io/PgReader.cpp
M plugins/pgpointcloud/io/PgReader.hpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/pgpointcloud/io/PgWriter.hpp
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M src/DbReader.cpp
M src/DbWriter.cpp
M src/KDIndex.cpp
M src/Kernel.cpp
M src/PipelineManager.cpp
M src/PipelineWriter.cpp
R src/PointBuffer.cpp
M src/QuadIndex.cpp
M src/Stage.cpp
M src/StageRunner.hpp
M src/Writer.cpp
M test/data/logs/logtest.txt
M test/data/logs/logtest_1.txt
M test/data/logs/logtest_123.txt
M test/unit/LogTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/PointBufferTest.cpp
M test/unit/PointContextTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/StageTester.hpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/XMLSchemaTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/ColorizationFilterTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/MergeTest.cpp
M test/unit/filters/RangeFilterTest.cpp
M test/unit/filters/ReprojectionFilterTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/filters/SplitterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/filters/TransformationFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/buffer/BufferTest.cpp
M test/unit/io/faux/FauxReaderTest.cpp
M test/unit/io/las/LasReaderTest.cpp
M test/unit/io/las/LasWriterTest.cpp
M test/unit/io/optech/OptechReaderTest.cpp
M test/unit/io/qfit/QFITReaderTest.cpp
M test/unit/io/rialto/RialtoWriterTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
M test/unit/io/sbet/SbetWriterTest.cpp
M test/unit/io/terrasolid/TerrasolidReaderTest.cpp
Log Message:
Try codebase switch to layout/table/view format. Mostly just renaming.
Compare: https://github.com/PDAL/PDAL/compare/3a01bdce6499^...03313efe711f
More information about the pdal-commits
