[pdal-commits] [PDAL/PDAL] 84810d: first cut at silencing a number of windows related...
GitHub
noreply at github.com
Tue Mar 17 12:02:43 PDT 2015
Branch: refs/heads/windows-warnings
Home: https://github.com/PDAL/PDAL
Commit: 84810d3c812ac6cb1d2347e6d20ec18f07860c9a
https://github.com/PDAL/PDAL/commit/84810d3c812ac6cb1d2347e6d20ec18f07860c9a
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-03-17 (Tue, 17 Mar 2015)
Changed paths:
M include/pdal/Metadata.hpp
M include/pdal/PipelineManager.hpp
M include/pdal/util/IStream.hpp
M include/pdal/util/OStream.hpp
M plugins/pcl/io/PcdReader.cpp
M test/unit/Support.cpp
Log Message:
first cut at silencing a number of windows related warnings
Commit: 6e405ccaf0bffacc1819f4bf5e61042676280df1
https://github.com/PDAL/PDAL/commit/6e405ccaf0bffacc1819f4bf5e61042676280df1
Changed paths:
M include/pdal/pdal_macros.hpp
M src/StageFactory.cpp
Log Message:
getting PluginManager instance lots of places that we do not have to
Commit: 6b62915137aeff4285196e5c75f1f97f8fbf3815
https://github.com/PDAL/PDAL/commit/6b62915137aeff4285196e5c75f1f97f8fbf3815
Changed paths:
M include/pdal/PointBuffer.hpp
Log Message:
unused
Commit: abfae5de93c6ef06d8d8cb944a34cf795ecb8f92
https://github.com/PDAL/PDAL/commit/abfae5de93c6ef06d8d8cb944a34cf795ecb8f92
Changed paths:
M filters/chipper/ChipperFilter.cpp
M filters/chipper/ChipperFilter.hpp
Log Message:
emit never used the narrow dimension
Commit: 635d5128e8109f429ac7142d10d6d38838999279
https://github.com/PDAL/PDAL/commit/635d5128e8109f429ac7142d10d6d38838999279
Changed paths:
M filters/colorization/ColorizationFilter.hpp
M filters/range/RangeFilter.cpp
M filters/reprojection/ReprojectionFilter.cpp
M src/pdal_config.cpp
M src/util/Bounds.cpp
Log Message:
more standard handling of Wfloat-equal on various compilers
Commit: 6d936441bdef5b816323305f1d61dbaa56b9336f
https://github.com/PDAL/PDAL/commit/6d936441bdef5b816323305f1d61dbaa56b9336f
Changed paths:
M test/unit/BoundsTest.cpp
Log Message:
double comparison, not float
Commit: f764eebb4c1ea3399e90f60f4ddc9b216a17c851
https://github.com/PDAL/PDAL/commit/f764eebb4c1ea3399e90f60f4ddc9b216a17c851
Changed paths:
M plugins/attribute/filters/AttributeFilter.cpp
Log Message:
no cast to bool and unused variable
Commit: 24e25a6c57322d70a28ab45709af57d6888159e7
https://github.com/PDAL/PDAL/commit/24e25a6c57322d70a28ab45709af57d6888159e7
Changed paths:
M filters/crop/CropFilter.cpp
M filters/stats/StatsFilter.cpp
M include/pdal/KDIndex.hpp
M io/las/VariableLengthRecord.cpp
M io/text/TextWriter.cpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/nitf/test/NitfWriterTest.cpp
M plugins/pcl/test/PCLBlockFilterTest.cpp
M src/KDIndex.cpp
M src/KernelSupport.cpp
M src/PDALUtils.cpp
M src/SpatialReference.cpp
M test/unit/MetadataTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/StreamFactoryTest.cpp
M test/unit/UserCallbackTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/RangeFilterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/filters/TransformationFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/las/LasReaderTest.cpp
M test/unit/io/optech/OptechReaderTest.cpp
M test/unit/io/rialto/RialtoWriterTest.cpp
Log Message:
remove unused and other warnings
Commit: ae185cc6281626257791559843ba1a50a9f2c8a2
https://github.com/PDAL/PDAL/commit/ae185cc6281626257791559843ba1a50a9f2c8a2
Changed paths:
M include/pdal/Utils.hpp
Log Message:
probably safer tolower/toupper, also no warnings
Commit: 0546b1a744c96e003dae2cd4b97e46f5f7603ffc
https://github.com/PDAL/PDAL/commit/0546b1a744c96e003dae2cd4b97e46f5f7603ffc
Changed paths:
Log Message:
avoid the constant expression warning
Commit: b6d1b6f6e54469c844613b37b4897bdb15f38f46
https://github.com/PDAL/PDAL/commit/b6d1b6f6e54469c844613b37b4897bdb15f38f46
Changed paths:
Log Message:
properly initialize string in toupper/tolower, try to fix EXPECT_DOUBLE_EQ issues
Compare: https://github.com/PDAL/PDAL/compare/586bab8206b6...b6d1b6f6e544
More information about the pdal-commits
