[pdal-commits] [PDAL/PDAL] d500d6: Redo zone calculation based on several sources fou...
GitHub noreply at github.com
Fri May 1 14:03:45 PDT 2015
  Branch: refs/heads/pdal-tindex
  Home:   https://github.com/PDAL/PDAL
  Commit: d500d672d1812f86629f7378395a723356490678
      https://github.com/PDAL/PDAL/commit/d500d672d1812f86629f7378395a723356490678
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-04-27 (Mon, 27 Apr 2015)
  Changed paths:
    M include/pdal/SpatialReference.hpp
    M src/SpatialReference.cpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Redo zone calculation based on several sources found elsewhere.  Eliminate
bad abs() call and resulting confusion.
  Commit: bcb0e4abe1e5da4899cf35a519550d7d36c190d6
      https://github.com/PDAL/PDAL/commit/bcb0e4abe1e5da4899cf35a519550d7d36c190d6
  Changed paths:
    M include/pdal/PointTable.hpp
    M io/rialto/RialtoCommon.cpp
    M io/rialto/RialtoCommon.hpp
  Log Message:
  Const applies to type, in this case a reference, which makes no sense,
so introduce a const type.
  Commit: 20d3f780232a685c5a98a988dfef70c7251f23cf
      https://github.com/PDAL/PDAL/commit/20d3f780232a685c5a98a988dfef70c7251f23cf
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-04-28 (Tue, 28 Apr 2015)
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into pdal-tindex
  Commit: 715f58c123920b6169fd107f08965ef5210b6cae
      https://github.com/PDAL/PDAL/commit/715f58c123920b6169fd107f08965ef5210b6cae
  Author: Andrew <andrew at abell-vb2.(none)>
  Date:   2015-04-29 (Wed, 29 Apr 2015)
  Changed paths:
    M include/pdal/PointView.hpp
    M plugins/nitf/io/MetadataReader.hpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/test/OCITest.cpp
    M src/PointView.cpp
    M test/unit/io/optech/OptechReaderTest.cpp
  Log Message:
  Fixes for g++/Ubuntu compilation.
  Commit: 4f8f9cb203380945ea401a9fceff90ad60ef24e5
      https://github.com/PDAL/PDAL/commit/4f8f9cb203380945ea401a9fceff90ad60ef24e5
  Author: Connor Manning <connor at hobu.co>
  Date:   2015-04-30 (Thu, 30 Apr 2015)
  Changed paths:
    M include/pdal/Utils.hpp
    M src/PointView.cpp
  Log Message:
  Remove boost::numeric_cast.
  Commit: c9eaccaf9316eb751d9fcad7107b603643b3479b
      https://github.com/PDAL/PDAL/commit/c9eaccaf9316eb751d9fcad7107b603643b3479b
  Date:   2015-05-01 (Fri, 01 May 2015)
  Changed paths:
    M src/PointView.cpp
  Log Message:
  Merge pull request #889 from PDAL/casting
  Commit: a46515c5ca5b35f0cbd21a713cc82c9c10e43a51
      https://github.com/PDAL/PDAL/commit/a46515c5ca5b35f0cbd21a713cc82c9c10e43a51
  Changed paths:
    M include/pdal/DbWriter.hpp
    M include/pdal/Writer.hpp
    M io/bpf/BpfWriter.cpp
    M io/las/LasWriter.cpp
    M src/DbWriter.cpp
    M src/Writer.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Add auto-scaling.
Close #888
  Commit: 4737de36e1aaeab92972002a9003f37b2126cf0c
      https://github.com/PDAL/PDAL/commit/4737de36e1aaeab92972002a9003f37b2126cf0c
  Changed paths:
    M src/DbWriter.cpp
    M src/Writer.cpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/02f0c7e6697f...4737de36e1aa
More information about the pdal-commits mailing list
