[pdal-commits] [PDAL/PDAL] 116d7d: Merge kernel.
GitHub
noreply at github.com
Wed May 6 07:32:04 PDT 2015
Branch: refs/heads/pdal-tindex
Home: https://github.com/PDAL/PDAL
Commit: 116d7d867af69da601ced096d9cf46f19709d78f
https://github.com/PDAL/PDAL/commit/116d7d867af69da601ced096d9cf46f19709d78f
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-05-04 (Mon, 04 May 2015)
Changed paths:
M include/pdal/Kernel.hpp
M include/pdal/Options.hpp
M include/pdal/Stage.hpp
M kernels/CMakeLists.txt
A kernels/merge/CMakeLists.txt
A kernels/merge/MergeKernel.cpp
A kernels/merge/MergeKernel.hpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/translate/TranslateKernel.cpp
M src/Kernel.cpp
M src/KernelFactory.cpp
M src/Options.cpp
M test/unit/CMakeLists.txt
A test/unit/apps/MergeTest.cpp
Log Message:
Merge kernel.
Commit: 73d0ee2581b7a58fbf40795f27dea5377f153583
https://github.com/PDAL/PDAL/commit/73d0ee2581b7a58fbf40795f27dea5377f153583
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M test/unit/apps/MergeTest.cpp
Log Message:
Add space between filename and output redirection
Without the space, the 2 became part of the filename, at least on OSX.
I'm not sure why this didn't break on Travis...
Commit: 5c365960e6e2b38d06fc8468e70e80056a029d70
https://github.com/PDAL/PDAL/commit/5c365960e6e2b38d06fc8468e70e80056a029d70
Changed paths:
Log Message:
Merge pull request #891 from gadomski/fix-merge-test
Commit: 4502463b0d578150cd28a2efa761660dfb7fd7a2
https://github.com/PDAL/PDAL/commit/4502463b0d578150cd28a2efa761660dfb7fd7a2
Changed paths:
M CMakeLists.txt
M doc/stages/index.rst
A doc/stages/readers.ply.rst
M io/CMakeLists.txt
A io/ply/CMakeLists.txt
A io/ply/PlyReader.cpp
A io/ply/PlyReader.hpp
M src/StageFactory.cpp
A test/data/ply/no_vertex.ply
A test/data/ply/simple_binary.ply
A test/data/ply/simple_text.ply
A test/unit/io/ply/PlyReaderTest.cpp
A vendor/rply-1.1.3/LICENSE
A vendor/rply-1.1.3/etc/convert.c
A vendor/rply-1.1.3/etc/dump.c
A vendor/rply-1.1.3/etc/input.ply
A vendor/rply-1.1.3/etc/sconvert.c
A vendor/rply-1.1.3/manual/manual.html
A vendor/rply-1.1.3/manual/reference.css
A vendor/rply-1.1.3/manual/rply.png
A vendor/rply-1.1.3/rply.c
A vendor/rply-1.1.3/rply.h
Log Message:
Add a ply reader
Includes rply 1.1.3 in vendor/. Ply reader is included as a native
driver.
Works on #878
Commit: 1da0856f8bcd40e82b094c7f71815f39cfcc9b0d
https://github.com/PDAL/PDAL/commit/1da0856f8bcd40e82b094c7f71815f39cfcc9b0d
Changed paths:
M CMakeLists.txt
M io/CMakeLists.txt
Log Message:
Merge pull request #892 from gadomski/issues/878-ply-reader
Add a ply reader
Commit: 87123897f7d3b2b9daf1523266b6b685e1dac7aa
https://github.com/PDAL/PDAL/commit/87123897f7d3b2b9daf1523266b6b685e1dac7aa
Changed paths:
A doc/stages/writers.ply.rst
M io/ply/CMakeLists.txt
A io/ply/PlyWriter.cpp
A io/ply/PlyWriter.hpp
A test/unit/io/ply/PlyWriterTest.cpp
Log Message:
Add a ply writer
Fixes #878
Commit: e76b74132bf350acc82ddb1d30acc008cef31add
https://github.com/PDAL/PDAL/commit/e76b74132bf350acc82ddb1d30acc008cef31add
Date: 2015-05-05 (Tue, 05 May 2015)
Changed paths:
Log Message:
Merge pull request #894 from gadomski/issues/878-ply-writer
Add a ply writer
Commit: 5d86d99a34c050d742b06643eb421534b68ab7a7
https://github.com/PDAL/PDAL/commit/5d86d99a34c050d742b06643eb421534b68ab7a7
Changed paths:
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
Log Message:
Fix extra options for PCL kernels.
Commit: 12b3b992a556eff8a96c94cb1476abf5ed7461f9
https://github.com/PDAL/PDAL/commit/12b3b992a556eff8a96c94cb1476abf5ed7461f9
Changed paths:
Log Message:
Merge branch 'master' of https://github.com/PDAL/PDAL
Commit: 78119eeb8607ccbc58645ee371e98de79d669cb8
https://github.com/PDAL/PDAL/commit/78119eeb8607ccbc58645ee371e98de79d669cb8
Changed paths:
A doc/stages/readers.bpf.rst
A doc/stages/writers.bpf.rst
M doc/stages/writers.las.rst
Log Message:
Add doc for BPF reader/writer.
Add description of "auto" scaling.
Commit: c7152e9e0c7131240786d5adaef6ebd86c8a046e
https://github.com/PDAL/PDAL/commit/c7152e9e0c7131240786d5adaef6ebd86c8a046e
Changed paths:
M include/pdal/GDALUtils.hpp
M include/pdal/Log.hpp
M plugins/nitf/io/NitfReader.hpp
M src/GDALUtils.cpp
M src/Log.cpp
R test/unit/GDALUtilsTest.cpp
Log Message:
Remove boost from Log code.
Remove dead code from GDALUtils.
Commit: b5f9ae83e236a458992682d8d546e269f243ba31
https://github.com/PDAL/PDAL/commit/b5f9ae83e236a458992682d8d546e269f243ba31
Date: 2015-05-06 (Wed, 06 May 2015)
Changed paths:
M CMakeLists.txt
M io/CMakeLists.txt
M src/GDALUtils.cpp
M src/Kernel.cpp
M src/Log.cpp
M src/Options.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into tindex
Commit: 5e5649eff27e6526818be6aa22590a4cc9e64866
https://github.com/PDAL/PDAL/commit/5e5649eff27e6526818be6aa22590a4cc9e64866
Changed paths:
M kernels/tindex/TIndexKernel.cpp
M kernels/tindex/TIndexKernel.hpp
M src/Kernel.cpp
Log Message:
Small tindex cleanups.
Compare: https://github.com/PDAL/PDAL/compare/4737de36e1aa...5e5649eff27e
More information about the pdal-commits
