[pdal-commits] [PDAL/PDAL] 3f1af0: Load only one plugin when guessing plugin names
GitHub
noreply at github.com
Fri May 8 10:47:33 PDT 2015
Branch: refs/heads/rialto-tiling
Home: https://github.com/PDAL/PDAL
Commit: 3f1af0f4350acce47d02422e84d78ca3d569a38d
https://github.com/PDAL/PDAL/commit/3f1af0f4350acce47d02422e84d78ca3d569a38d
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2015-04-26 (Sun, 26 Apr 2015)
Changed paths:
M src/PluginManager.cpp
Log Message:
In `PluginManager::guessLoadByPath`, the driverName was not being
entirely used when loading plugins. Only the plugin type (filter,
reader, writer) was used. This patch checks the actual name of the
driver (e.g. hexbin) against the filename of the library, and only loads
the plugin if the name matches.
Since a plugin only needs to be loaded once, the return value of the
`loadByPath` call is returned from `guessLoadByPath`. If no plugins are
found, the `guessLoadByPath` now returns -1.
Commit: 6e210d468195e27c0beae0a7b60489105e0c0a2c
https://github.com/PDAL/PDAL/commit/6e210d468195e27c0beae0a7b60489105e0c0a2c
Author: Connor Manning <connor at hobu.co>
Changed paths:
M include/pdal/PluginManager.hpp
M include/pdal/pdal_macros.hpp
M src/KernelFactory.cpp
M src/StageFactory.cpp
Log Message:
Plugin manager tweaks. Avoid integer return codes and simplify a couple things.
Commit: d639bd7e00416631da5451db5492eb2d64669221
https://github.com/PDAL/PDAL/commit/d639bd7e00416631da5451db5492eb2d64669221
Changed paths:
Log Message:
Merge remote-tracking branch 'gadomski/missing-plugin-cleanup' into pm-consistency
Conflicts:
Commit: 715f58c123920b6169fd107f08965ef5210b6cae
https://github.com/PDAL/PDAL/commit/715f58c123920b6169fd107f08965ef5210b6cae
Author: Andrew <andrew at abell-vb2.(none)>
Date: 2015-04-29 (Wed, 29 Apr 2015)
Changed paths:
M include/pdal/PointView.hpp
M plugins/nitf/io/MetadataReader.hpp
M plugins/nitf/io/NitfFile.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/test/OCITest.cpp
M src/PointView.cpp
M test/unit/io/optech/OptechReaderTest.cpp
Log Message:
Fixes for g++/Ubuntu compilation.
Commit: 4f8f9cb203380945ea401a9fceff90ad60ef24e5
https://github.com/PDAL/PDAL/commit/4f8f9cb203380945ea401a9fceff90ad60ef24e5
Date: 2015-04-30 (Thu, 30 Apr 2015)
Changed paths:
M include/pdal/Utils.hpp
M src/PointView.cpp
Log Message:
Remove boost::numeric_cast.
Commit: c9eaccaf9316eb751d9fcad7107b603643b3479b
https://github.com/PDAL/PDAL/commit/c9eaccaf9316eb751d9fcad7107b603643b3479b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-05-01 (Fri, 01 May 2015)
Changed paths:
M src/PointView.cpp
Log Message:
Merge pull request #889 from PDAL/casting
Commit: a46515c5ca5b35f0cbd21a713cc82c9c10e43a51
https://github.com/PDAL/PDAL/commit/a46515c5ca5b35f0cbd21a713cc82c9c10e43a51
Changed paths:
M include/pdal/DbWriter.hpp
M include/pdal/Writer.hpp
M io/bpf/BpfWriter.cpp
M io/las/LasWriter.cpp
M src/DbWriter.cpp
M src/Writer.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/io/las/LasWriterTest.cpp
Log Message:
Add auto-scaling.
Close #888
Commit: 116d7d867af69da601ced096d9cf46f19709d78f
https://github.com/PDAL/PDAL/commit/116d7d867af69da601ced096d9cf46f19709d78f
Date: 2015-05-04 (Mon, 04 May 2015)
Changed paths:
M include/pdal/Kernel.hpp
M include/pdal/Options.hpp
M include/pdal/Stage.hpp
M kernels/CMakeLists.txt
A kernels/merge/CMakeLists.txt
A kernels/merge/MergeKernel.cpp
A kernels/merge/MergeKernel.hpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/translate/TranslateKernel.cpp
M src/Kernel.cpp
M src/Options.cpp
M test/unit/CMakeLists.txt
A test/unit/apps/MergeTest.cpp
Log Message:
Merge kernel.
Commit: 73d0ee2581b7a58fbf40795f27dea5377f153583
https://github.com/PDAL/PDAL/commit/73d0ee2581b7a58fbf40795f27dea5377f153583
Changed paths:
M test/unit/apps/MergeTest.cpp
Log Message:
Add space between filename and output redirection
Without the space, the 2 became part of the filename, at least on OSX.
I'm not sure why this didn't break on Travis...
Commit: 5c365960e6e2b38d06fc8468e70e80056a029d70
https://github.com/PDAL/PDAL/commit/5c365960e6e2b38d06fc8468e70e80056a029d70
Changed paths:
Log Message:
Merge pull request #891 from gadomski/fix-merge-test
Commit: 4502463b0d578150cd28a2efa761660dfb7fd7a2
https://github.com/PDAL/PDAL/commit/4502463b0d578150cd28a2efa761660dfb7fd7a2
Changed paths:
M CMakeLists.txt
M doc/stages/index.rst
A doc/stages/readers.ply.rst
M io/CMakeLists.txt
A io/ply/CMakeLists.txt
A io/ply/PlyReader.cpp
A io/ply/PlyReader.hpp
A test/data/ply/no_vertex.ply
A test/data/ply/simple_binary.ply
A test/data/ply/simple_text.ply
A test/unit/io/ply/PlyReaderTest.cpp
A vendor/rply-1.1.3/LICENSE
A vendor/rply-1.1.3/etc/convert.c
A vendor/rply-1.1.3/etc/dump.c
A vendor/rply-1.1.3/etc/input.ply
A vendor/rply-1.1.3/etc/sconvert.c
A vendor/rply-1.1.3/manual/manual.html
A vendor/rply-1.1.3/manual/reference.css
A vendor/rply-1.1.3/manual/rply.png
A vendor/rply-1.1.3/rply.c
A vendor/rply-1.1.3/rply.h
Log Message:
Add a ply reader
Includes rply 1.1.3 in vendor/. Ply reader is included as a native
driver.
Works on #878
Commit: 1da0856f8bcd40e82b094c7f71815f39cfcc9b0d
https://github.com/PDAL/PDAL/commit/1da0856f8bcd40e82b094c7f71815f39cfcc9b0d
Changed paths:
M CMakeLists.txt
M io/CMakeLists.txt
Log Message:
Merge pull request #892 from gadomski/issues/878-ply-reader
Add a ply reader
Commit: 87123897f7d3b2b9daf1523266b6b685e1dac7aa
https://github.com/PDAL/PDAL/commit/87123897f7d3b2b9daf1523266b6b685e1dac7aa
Changed paths:
A doc/stages/writers.ply.rst
M io/ply/CMakeLists.txt
A io/ply/PlyWriter.cpp
A io/ply/PlyWriter.hpp
A test/unit/io/ply/PlyWriterTest.cpp
Log Message:
Add a ply writer
Fixes #878
Commit: e76b74132bf350acc82ddb1d30acc008cef31add
https://github.com/PDAL/PDAL/commit/e76b74132bf350acc82ddb1d30acc008cef31add
Date: 2015-05-05 (Tue, 05 May 2015)
Changed paths:
Log Message:
Merge pull request #894 from gadomski/issues/878-ply-writer
Add a ply writer
Commit: 5d86d99a34c050d742b06643eb421534b68ab7a7
https://github.com/PDAL/PDAL/commit/5d86d99a34c050d742b06643eb421534b68ab7a7
Changed paths:
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
Log Message:
Fix extra options for PCL kernels.
Commit: 12b3b992a556eff8a96c94cb1476abf5ed7461f9
https://github.com/PDAL/PDAL/commit/12b3b992a556eff8a96c94cb1476abf5ed7461f9
Changed paths:
Log Message:
Merge branch 'master' of https://github.com/PDAL/PDAL
Commit: 78119eeb8607ccbc58645ee371e98de79d669cb8
https://github.com/PDAL/PDAL/commit/78119eeb8607ccbc58645ee371e98de79d669cb8
Changed paths:
A doc/stages/readers.bpf.rst
A doc/stages/writers.bpf.rst
M doc/stages/writers.las.rst
Log Message:
Add doc for BPF reader/writer.
Add description of "auto" scaling.
Commit: c7152e9e0c7131240786d5adaef6ebd86c8a046e
https://github.com/PDAL/PDAL/commit/c7152e9e0c7131240786d5adaef6ebd86c8a046e
Changed paths:
M include/pdal/GDALUtils.hpp
M include/pdal/Log.hpp
M plugins/nitf/io/NitfReader.hpp
M src/GDALUtils.cpp
M src/Log.cpp
R test/unit/GDALUtilsTest.cpp
Log Message:
Remove boost from Log code.
Remove dead code from GDALUtils.
Commit: 95d30acd8de2f4a234c8f2b4d88ff3651811bc45
https://github.com/PDAL/PDAL/commit/95d30acd8de2f4a234c8f2b4d88ff3651811bc45
Author: Michael P. Gerlek <mpg at flaxen.com>
Date: 2015-05-06 (Wed, 06 May 2015)
Changed paths:
M .gitignore
Log Message:
temp outputs
Commit: 6981805cad769a812aedba382b0e7f00f67ebce1
https://github.com/PDAL/PDAL/commit/6981805cad769a812aedba382b0e7f00f67ebce1
Changed paths:
M plugins/sqlite/io/SQLiteCommon.hpp
M plugins/sqlite/test/SQLiteTest.cpp
Log Message:
fix for #895
Commit: 4c3114c7dee91a337995d3af085b0675c6b69986
https://github.com/PDAL/PDAL/commit/4c3114c7dee91a337995d3af085b0675c6b69986
Date: 2015-05-07 (Thu, 07 May 2015)
Changed paths:
Log Message:
Remove extraneous semicolons.
Commit: a3e93db03d95cc6d7271c29727a0d5a74a35886e
https://github.com/PDAL/PDAL/commit/a3e93db03d95cc6d7271c29727a0d5a74a35886e
Author: Sandro Santilli <strk at keybit.net>
Date: 2015-05-08 (Fri, 08 May 2015)
Changed paths:
M README.md
Log Message:
Add website link to README file
I could not find it anywhere else (quickly)
Commit: 1ee93cbe662c00f22bcb9366fd7a50dfd31a6331
https://github.com/PDAL/PDAL/commit/1ee93cbe662c00f22bcb9366fd7a50dfd31a6331
Changed paths:
M doc/stages/writers.pgpointcloud.rst
Log Message:
Document "pcid" option of PgPointcloud writer plugin
Commit: aeb457e616747eb6379ff9f103c828eed36b8fcb
https://github.com/PDAL/PDAL/commit/aeb457e616747eb6379ff9f103c828eed36b8fcb
Author: Howard Butler <howard at hobu.co>
Changed paths:
M README.md
Log Message:
Merge pull request #898 from strk/patch-2
Commit: 1f96d9459ab7f5c9b6b2cdc523d5131e66373057
https://github.com/PDAL/PDAL/commit/1f96d9459ab7f5c9b6b2cdc523d5131e66373057
Changed paths:
Log Message:
Merge pull request #899 from strk/pointcloud-docs
Commit: 397936b8cf96dea6056ac582564fd311f6ae1180
https://github.com/PDAL/PDAL/commit/397936b8cf96dea6056ac582564fd311f6ae1180
Changed paths:
Log Message:
loadByPath should load DynamicLibrary if they're not already loaded
Commit: 87499e59ff74379510145ef06af54b471978ba0b
https://github.com/PDAL/PDAL/commit/87499e59ff74379510145ef06af54b471978ba0b
Changed paths:
Log Message:
Merge pull request #887 from PDAL/pm-consistency
PluginManager consistency
Commit: b3ad3813db4bc3f119257ea867d4f9843dc1776d
https://github.com/PDAL/PDAL/commit/b3ad3813db4bc3f119257ea867d4f9843dc1776d
Changed paths:
M .gitignore
Log Message:
Merge pull request #896 from PDAL/issue-895
Fix for SQLiteCommon::doesTableExist() iteration bug
(merge approved by @hobu)
Commit: 43f17ebc04c22a194e28a1f8f9cc8ae7ac57480d
https://github.com/PDAL/PDAL/commit/43f17ebc04c22a194e28a1f8f9cc8ae7ac57480d
Changed paths:
M .gitignore
M CMakeLists.txt
M README.md
M io/CMakeLists.txt
M src/DbWriter.cpp
M src/GDALUtils.cpp
M src/Kernel.cpp
M src/Log.cpp
M src/Options.cpp
M src/Writer.cpp
Log Message:
merge master down into my branch, 3 conflicts resolved
Commit: b30d5eb93024201bc5a33b85d3af0310a8c65320
https://github.com/PDAL/PDAL/commit/b30d5eb93024201bc5a33b85d3af0310a8c65320
Changed paths:
M plugins/rialto/io/RialtoDb.cpp
M plugins/rialto/io/RialtoDb.hpp
M plugins/rialto/test/RialtoDbWriterTest.cpp
Log Message:
small, temporary include fix for Oscar
Compare: https://github.com/PDAL/PDAL/compare/d307367eeb98...b30d5eb93024
More information about the pdal-commits
