[pdal-commits] [PDAL/PDAL] d2dd44: Enable hexbin tests on travis
GitHub
noreply at github.com
Wed May 20 07:37:16 PDT 2015
Branch: refs/heads/hexboundary-on-travis
Home: https://github.com/PDAL/PDAL
Commit: d2dd446abb9eebb6845ff0ca71682c894d4454c8
https://github.com/PDAL/PDAL/commit/d2dd446abb9eebb6845ff0ca71682c894d4454c8
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2015-05-20 (Wed, 20 May 2015)
Changed paths:
M scripts/ci/before_install.sh
M scripts/ci/script.sh
Log Message:
The travis package is called "hexboundary", because there's already a
debian packaged named hexbin.
Commit: 008dfc471009d8db23c7946c0a3a14590a0a66ed
https://github.com/PDAL/PDAL/commit/008dfc471009d8db23c7946c0a3a14590a0a66ed
Changed paths:
M plugins/hexbin/test/HexbinFilterTest.cpp
Log Message:
Remove outfile check in the hexbin test
Hexbin appears to be non-deterministic in the ordering of its output
hexes, and so this test was failing on Ubuntu precise even though the
output polygons appeared correct to visual inspection (just in a
different order).
Compare: https://github.com/PDAL/PDAL/compare/d2dd446abb9e^...008dfc471009
More information about the pdal-commits
