[pdal-commits] [PDAL/PDAL] f5f526: better error handling, as per #927
GitHub
noreply at github.com
Tue May 26 07:41:08 PDT 2015
Branch: refs/heads/sqlite_error_handling
Home: https://github.com/PDAL/PDAL
Commit: f5f52667abb7487a2db7e51adbf0764b14c0a3c0
https://github.com/PDAL/PDAL/commit/f5f52667abb7487a2db7e51adbf0764b14c0a3c0
Author: Michael P. Gerlek <mpg at flaxen.com>
Date: 2015-05-26 (Tue, 26 May 2015)
Changed paths:
M plugins/sqlite/io/SQLiteCommon.hpp
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
Log Message:
made return codes and error handling consistent
removed derived exception types
added missing finalize() call (which caused random crashes), and
enforced resetting of m_statement (which is shared between insert() and
query())
(nothing readily unit-testable)
Commit: 0d383c66f96be48fcda66dd7721be4942dcbfc6f
https://github.com/PDAL/PDAL/commit/0d383c66f96be48fcda66dd7721be4942dcbfc6f
Changed paths:
M plugins/sqlite/test/SQLiteTest.cpp
Log Message:
explicitly scope the database read & write
otherwise we can’t be assured the dtors will be called so the files get
closed out properly
Compare: https://github.com/PDAL/PDAL/compare/f5f52667abb7^...0d383c66f96b
More information about the pdal-commits
