[pdal-commits] [PDAL/PDAL] cdc2c3: Updated Writing tutorial.
GitHub noreply at github.com
Fri Nov 6 08:13:43 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: cdc2c377856d7848b05929acde231f495666b4c1
      https://github.com/PDAL/PDAL/commit/cdc2c377856d7848b05929acde231f495666b4c1
  Author: Scott Lewis <scott.lewis at nsidc.org>
  Date:   2015-11-05 (Thu, 05 Nov 2015)
  Changed paths:
    M doc/tutorial/writing.rst
    M examples/writing/tutorial.cpp
  Log Message:
Fixed the tutorial code to match the changes to the main codebase,
as well as to use the StageFactory as described in the tutorial
text.  Also cleaned up the tutorial documentation to display the
correct line numbers.
  Commit: e3083e86052593e45e330dc24d62ba19f0b025ef
      https://github.com/PDAL/PDAL/commit/e3083e86052593e45e330dc24d62ba19f0b025ef
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-11-06 (Fri, 06 Nov 2015)
  Changed paths:
  Log Message:
  Merge pull request #1026 from scott-lewis-nsidc/update-writing-tutorial
Compare: https://github.com/PDAL/PDAL/compare/af0fcf897304...e3083e860525
More information about the pdal-commits mailing list
