[pdal-commits] [PDAL/PDAL] 2f142d: Check point view size in `getFieldAs`
GitHub
noreply at github.com
Mon Nov 16 13:24:24 PST 2015
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 2f142d22ff1aeea99636fa6b6f080c0e79a32d41
https://github.com/PDAL/PDAL/commit/2f142d22ff1aeea99636fa6b6f080c0e79a32d41
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2015-11-16 (Mon, 16 Nov 2015)
Changed paths:
M include/pdal/PointView.hpp
M test/unit/PointViewTest.cpp
Log Message:
`PointView::getFieldInternal` uses `deque::operator[]` to map index
values to raw point ids. This means that a user can silently access
beyond the end of of the `m_index` deque with an ill-advised
`getFieldAs` call, leading to either garbage results or a segfault.
Per
[discussion](https://github.com/gadomski/PDAL/commit/c1d54e56e2de841d37f2a1b1c218ed723053f6a9#commitcomment-14415138)
with @abellgithub, this should be considered a user error, albeit one
that we can protect against when in debug mode. Therefore, we use an
assert to check the bounds inside `getFieldAs`.
Commit: 193667bb226c4e40365e2268a3ee0abb0d0e7ad6
https://github.com/PDAL/PDAL/commit/193667bb226c4e40365e2268a3ee0abb0d0e7ad6
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
Log Message:
Merge pull request #1039 from gadomski/point-view-bounds-checking
Check point view size in `getFieldInternal`
Compare: https://github.com/PDAL/PDAL/compare/f7b7218f925c...193667bb226c
More information about the pdal-commits
