[pdal-commits] [PDAL/PDAL] a605b5: update the doc-building doc
GitHub noreply at github.com
Tue Nov 17 09:20:34 PST 2015
  Branch: refs/heads/stream
  Home:   https://github.com/PDAL/PDAL
  Commit: a605b521bc31743ae4f8eb924600a75f748f044b
      https://github.com/PDAL/PDAL/commit/a605b521bc31743ae4f8eb924600a75f748f044b
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-10-28 (Wed, 28 Oct 2015)
  Changed paths:
    M doc/apps.rst
    M doc/development/docs.rst
  Log Message:
  Commit: 4ec93451f16677b2f71866e8798fff49b0f79903
      https://github.com/PDAL/PDAL/commit/4ec93451f16677b2f71866e8798fff49b0f79903
  Changed paths:
    M src/PluginManager.cpp
  Log Message:
  lard up PluginManager with debugging lint for when PDAL_DEBUG enviro variable is set #997
  Commit: c4898cab0df4dadd643081cd5052fbba41251cf2
      https://github.com/PDAL/PDAL/commit/c4898cab0df4dadd643081cd5052fbba41251cf2
  Author: Connor Manning <connor at hobu.co>
  Changed paths:
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
  Log Message:
  Reintroduce ReprojectionFilter::filter, used by FilterWrapper for standalone Views.  Some performance tweaks.
  Commit: a9a350262b24dd72ba865c28229fd383f9fafcdd
      https://github.com/PDAL/PDAL/commit/a9a350262b24dd72ba865c28229fd383f9fafcdd
  Date:   2015-10-29 (Thu, 29 Oct 2015)
  Changed paths:
  Log Message:
  Merge pull request #1020 from PDAL/reprojection-filtering
ReprojectionFilter updates
  Commit: f7665802e1a6864ca1b1334f14ef610687bfb02c
      https://github.com/PDAL/PDAL/commit/f7665802e1a6864ca1b1334f14ef610687bfb02c
  Changed paths:
  Log Message:
  Correct reprojection culling by reverting to the original behavior.  Keep the reintroduced filter call.
  Commit: f643cb5c922b3bf079a3fd544fb1bd37764fb221
      https://github.com/PDAL/PDAL/commit/f643cb5c922b3bf079a3fd544fb1bd37764fb221
  Changed paths:
  Log Message:
  Oops, throw the error, not the string.
  Commit: 0e7308a8a80f33c6ad12aff1667b21d00da87f79
      https://github.com/PDAL/PDAL/commit/0e7308a8a80f33c6ad12aff1667b21d00da87f79
  Changed paths:
  Log Message:
  Merge branch 'master' into reprojection-filtering
Conflicts:
  Commit: f4b5e2b1fdc7541cd048cd40883852818794f645
      https://github.com/PDAL/PDAL/commit/f4b5e2b1fdc7541cd048cd40883852818794f645
  Author: Connor Manning <connormanning at users.noreply.github.com>
  Changed paths:
  Log Message:
  Merge pull request #1021 from PDAL/reprojection-filtering
Reprojection re-culling
  Commit: d74c460a45b536823261896c126f9859a865b66a
      https://github.com/PDAL/PDAL/commit/d74c460a45b536823261896c126f9859a865b66a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M plugins/nitf/io/NitfReader.cpp
  Log Message:
  Test changes for SRS setting in prepare().
  Commit: aff6ed851734dff194aca5ad7922f8a6687bfebe
      https://github.com/PDAL/PDAL/commit/aff6ed851734dff194aca5ad7922f8a6687bfebe
  Changed paths:
  Log Message:
  Merge pull request #1023 from PDAL/srs-prepare
  Commit: d97161738f544cca087f4af350aede2829df3cf3
      https://github.com/PDAL/PDAL/commit/d97161738f544cca087f4af350aede2829df3cf3
  Date:   2015-10-30 (Fri, 30 Oct 2015)
  Changed paths:
    M include/pdal/Stage.hpp
    M plugins/nitf/io/NitfReader.hpp
    M src/Stage.cpp
  Log Message:
  Move LAS metadata extraction to initialize().
  Commit: bcdfe9a79d4e89d87e24cf5279efae914fb6581b
      https://github.com/PDAL/PDAL/commit/bcdfe9a79d4e89d87e24cf5279efae914fb6581b
  Changed paths:
    M doc/Makefile
  Log Message:
  output docs to build directory
  Commit: ce639f4376265f15b9516614e1fa49bb1aa146c4
      https://github.com/PDAL/PDAL/commit/ce639f4376265f15b9516614e1fa49bb1aa146c4
  Changed paths:
    M cmake/examples/hobu-config.sh
  Log Message:
  update my example cmake to catch up to elcapitan
  Commit: 79109d81f4b93061a4a405bacc4464e02505e2f3
      https://github.com/PDAL/PDAL/commit/79109d81f4b93061a4a405bacc4464e02505e2f3
  Date:   2015-11-01 (Sun, 01 Nov 2015)
  Changed paths:
  Log Message:
  Merge pull request #1018 from PDAL/issues/997-plugin-debug
  Commit: dd368d7024c03e646784addc69d2dff896d43140
      https://github.com/PDAL/PDAL/commit/dd368d7024c03e646784addc69d2dff896d43140
  Changed paths:
  Log Message:
  output the PDAL plugin search path to stderr when PDAL_DEBUG environment variable is set
  Commit: 9c9819a90443d6f478cb38c7725291522f9b30db
      https://github.com/PDAL/PDAL/commit/9c9819a90443d6f478cb38c7725291522f9b30db
  Changed paths:
    M doc/stages/filters.colorization.rst
  Log Message:
  document GDAL_CACHEMAX sensitivity in filters.colorization
  Commit: 1d629bd84ae2962d4baec6fc0a547272c47d75b1
      https://github.com/PDAL/PDAL/commit/1d629bd84ae2962d4baec6fc0a547272c47d75b1
  Changed paths:
  Log Message:
  typos
  Commit: b5b8954f1d6cd41170c2f4ec1efd4a515837c411
      https://github.com/PDAL/PDAL/commit/b5b8954f1d6cd41170c2f4ec1efd4a515837c411
  Changed paths:
    M doc/stages/filters.attribute.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.divider.rst
    M doc/stages/filters.predicate.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/filters.voxelgrid.rst
  Log Message:
  more doc tweaks
  Commit: e61f27bf3cfcfb451bf4eef3a6c566489780777a
      https://github.com/PDAL/PDAL/commit/e61f27bf3cfcfb451bf4eef3a6c566489780777a
  Date:   2015-11-02 (Mon, 02 Nov 2015)
  Changed paths:
    M doc/compilation/unix.rst
  Log Message:
  point to vagrant in compilation doc
  Commit: 590059989f448d7e7a2f9b5c51eafc8862382a6d
      https://github.com/PDAL/PDAL/commit/590059989f448d7e7a2f9b5c51eafc8862382a6d
  Changed paths:
    M doc/compilation/windows.rst
  Log Message:
  point to OSGeo4W and Vagrant in windows compilation doc
  Commit: bc1b31d57b5a12a9477ac69bba1ab7616c2e92e4
      https://github.com/PDAL/PDAL/commit/bc1b31d57b5a12a9477ac69bba1ab7616c2e92e4
  Changed paths:
    M doc/index.rst
  Log Message:
  add PDAL logo back
  Commit: b3b0b5ba746b365565825de24d64e5e47202029f
      https://github.com/PDAL/PDAL/commit/b3b0b5ba746b365565825de24d64e5e47202029f
  Changed paths:
    M doc/stages/index.rst
  Log Message:
  introductory material for stages
  Commit: af0fcf8973043e0617895ee33f296017a49bc4fb
      https://github.com/PDAL/PDAL/commit/af0fcf8973043e0617895ee33f296017a49bc4fb
  Date:   2015-11-03 (Tue, 03 Nov 2015)
  Changed paths:
    M doc/compilation/dependencies.rst
    M doc/compilation/index.rst
    M doc/download.rst
  Log Message:
  more doc tweaks
  Commit: cdc2c377856d7848b05929acde231f495666b4c1
      https://github.com/PDAL/PDAL/commit/cdc2c377856d7848b05929acde231f495666b4c1
  Author: Scott Lewis <scott.lewis at nsidc.org>
  Date:   2015-11-05 (Thu, 05 Nov 2015)
  Changed paths:
    M doc/tutorial/writing.rst
    M examples/writing/tutorial.cpp
  Log Message:
  Updated Writing tutorial.
Fixed the tutorial code to match the changes to the main codebase,
as well as to use the StageFactory as described in the tutorial
text.  Also cleaned up the tutorial documentation to display the
correct line numbers.
  Commit: e3083e86052593e45e330dc24d62ba19f0b025ef
      https://github.com/PDAL/PDAL/commit/e3083e86052593e45e330dc24d62ba19f0b025ef
  Date:   2015-11-06 (Fri, 06 Nov 2015)
  Changed paths:
  Log Message:
  Merge pull request #1026 from scott-lewis-nsidc/update-writing-tutorial
  Commit: b29ec326e3556f5ae505aea8bc806227310bb7d0
      https://github.com/PDAL/PDAL/commit/b29ec326e3556f5ae505aea8bc806227310bb7d0
  Changed paths:
  Log Message:
  capitalization tweak from #1026
  Commit: d8a7ee9efa1b96080b55cff6a0086a27fe15ddb8
      https://github.com/PDAL/PDAL/commit/d8a7ee9efa1b96080b55cff6a0086a27fe15ddb8
  Changed paths:
    A doc/docbuild/Dockerfile
    A doc/docbuild/run.sh
  Log Message:
  add Dockerfile that builds pdal.io
  Commit: 288529a137187aae1f4e55363f1b80c88f2c6da3
      https://github.com/PDAL/PDAL/commit/288529a137187aae1f4e55363f1b80c88f2c6da3
  Date:   2015-11-07 (Sat, 07 Nov 2015)
  Changed paths:
    M io/faux/FauxReader.cpp
  Log Message:
  Avoid possibly uninitialized value warning.
  Commit: 223cedddedc5639932d391ede2ebfd13c80e575d
      https://github.com/PDAL/PDAL/commit/223cedddedc5639932d391ede2ebfd13c80e575d
  Date:   2015-11-09 (Mon, 09 Nov 2015)
  Changed paths:
  Log Message:
  Print warning if we can't read GeoTiff VLR when one exists.
Close #128
  Commit: c7d55293c4aabea9b82f8fe4f1e8f4c442c59be6
      https://github.com/PDAL/PDAL/commit/c7d55293c4aabea9b82f8fe4f1e8f4c442c59be6
  Changed paths:
    M include/pdal/PDALUtils.hpp
  Log Message:
  fcntl.h no impliclitly included in later libc++
  Commit: 6e384e53ebeea845c391617a17a375c3dbd435ab
      https://github.com/PDAL/PDAL/commit/6e384e53ebeea845c391617a17a375c3dbd435ab
  Changed paths:
    A doc/tutorial/autzen-shapes-clipped.png
    A doc/tutorial/autzen-shapes-point-cloud.png
    A doc/tutorial/autzen-shapes-to-clip.png
    A doc/tutorial/clipping-with-shapefile.rst
    M doc/tutorial/index.rst
  Log Message:
  add a tutorial to describe clipping with shapefiles
  Commit: dea9fa373917de306b0a8c8cc03324208ae8d13f
      https://github.com/PDAL/PDAL/commit/dea9fa373917de306b0a8c8cc03324208ae8d13f
  Changed paths:
    M doc/tutorial/clipping-with-shapefile.rst
  Log Message:
  clean up extra paragraph in tutorial
  Commit: 982be4f7e3bb0cada3ad6e6f916479871451ef72
      https://github.com/PDAL/PDAL/commit/982be4f7e3bb0cada3ad6e6f916479871451ef72
  Changed paths:
  Log Message:
  don't include fnctl if _WIN32
  Commit: f9f3402d66402d002100fc788633fa40745ff47a
      https://github.com/PDAL/PDAL/commit/f9f3402d66402d002100fc788633fa40745ff47a
  Changed paths:
    A test/data/autzen/attributes.json
    A test/data/autzen/attributes.vrt
  Log Message:
  clipping doc tweaks
  Commit: ab6e5aa25a13c2e05eb08d02bb869dbc4ea9d903
      https://github.com/PDAL/PDAL/commit/ab6e5aa25a13c2e05eb08d02bb869dbc4ea9d903
  Changed paths:
  Log Message:
  a note about using other dimensions besides classification
  Commit: a9c191f6e0ac80fe2c9bac4432444351659ba869
      https://github.com/PDAL/PDAL/commit/a9c191f6e0ac80fe2c9bac4432444351659ba869
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2015-11-10 (Tue, 10 Nov 2015)
  Changed paths:
    M doc/apps.rst
  Log Message:
  Remove extra apostrophe in apps.rst
  Commit: f807fb5eef1fa23fa90e0a076d848bd8f45234a8
      https://github.com/PDAL/PDAL/commit/f807fb5eef1fa23fa90e0a076d848bd8f45234a8
  Changed paths:
    M include/pdal/Options.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M src/Options.cpp
    M test/unit/OptionsTest.cpp
  Log Message:
  Fix option names in ground kernel.
Add debug information in the case that a bad option name is found.
Add a simple test for invalid option names.
Close #1029
  Commit: 75596db6151b4845f2ef28cdaa7dcc142458a420
      https://github.com/PDAL/PDAL/commit/75596db6151b4845f2ef28cdaa7dcc142458a420
  Changed paths:
    M doc/apps.rst
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 68cc4b4e9fdd3764cb76bfc11832105039438f75
      https://github.com/PDAL/PDAL/commit/68cc4b4e9fdd3764cb76bfc11832105039438f75
  Changed paths:
    M src/Options.cpp
  Log Message:
  gcc doesn't take declaration in argument, apparently.
  Commit: ce3feb42e2286a3b0dd652c2574b7a2fcdb2756b
      https://github.com/PDAL/PDAL/commit/ce3feb42e2286a3b0dd652c2574b7a2fcdb2756b
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-11-11 (Wed, 11 Nov 2015)
  Changed paths:
    M doc/tutorial/writing-filter.rst
    M examples/writing-filter/MyFilter.cpp
    M examples/writing-filter/MyFilter.hpp
  Log Message:
  Update the filter writing tutorial
  Commit: 1aa21171e492c85742286adbb54d5821ac1a227a
      https://github.com/PDAL/PDAL/commit/1aa21171e492c85742286adbb54d5821ac1a227a
  Changed paths:
    A doc/stages/filters.height.rst
    A doc/tutorial/calculating-normalized-heights.rst
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/HeightFilter.cpp
    A plugins/pcl/filters/HeightFilter.hpp
  Log Message:
  Initial commit of PCL-based normalized height filter
  Commit: 8eb66a6974c177d4496b61b21f6a0853220d5d70
      https://github.com/PDAL/PDAL/commit/8eb66a6974c177d4496b61b21f6a0853220d5d70
  Changed paths:
    A doc/tutorial/autzen-elevation.png
    A doc/tutorial/autzen-height.png
    M doc/tutorial/calculating-normalized-heights.rst
    M plugins/pcl/filters/HeightFilter.cpp
  Log Message:
  Add some error checking, examples, and finalize the tutorial
  Commit: 6462e06ff79ee5ae875f39d588c6577c642ac427
      https://github.com/PDAL/PDAL/commit/6462e06ff79ee5ae875f39d588c6577c642ac427
  Changed paths:
    M plugins/pcl/filters/HeightFilter.hpp
  Log Message:
  getDefaultOptions is unused, check for Classification dim when preparing filter
  Commit: de44ca6b00c513706cf73a3fa4da69cb6c9fc880
      https://github.com/PDAL/PDAL/commit/de44ca6b00c513706cf73a3fa4da69cb6c9fc880
  Changed paths:
  Log Message:
  Add note about ASPRS/LAS point classifications
  Commit: e3a357a2a83c59460aa6c4dffb43102aad81498c
      https://github.com/PDAL/PDAL/commit/e3a357a2a83c59460aa6c4dffb43102aad81498c
  Changed paths:
    M doc/tutorial/overview.rst
  Log Message:
  Add labels for filter tutorial update
  Commit: 56328bf10506043dd151a62875cb2e9670348044
      https://github.com/PDAL/PDAL/commit/56328bf10506043dd151a62875cb2e9670348044
  Changed paths:
  Log Message:
  Fix small typo in filter tutorial
  Commit: 8b902327de7b3effbb9af1888763755b834b745d
      https://github.com/PDAL/PDAL/commit/8b902327de7b3effbb9af1888763755b834b745d
  Date:   2015-11-12 (Thu, 12 Nov 2015)
  Changed paths:
  Log Message:
  Merge pull request #1030 from PDAL/height-filter
Add PCL-based height (above ground) filter
  Commit: a84994a13cfecd43e1c0c33b81548f92543e37e7
      https://github.com/PDAL/PDAL/commit/a84994a13cfecd43e1c0c33b81548f92543e37e7
  Changed paths:
  Log Message:
  Merge pull request #1027 from PDAL/pdal-docs-docker
  Commit: 492bdfeab5f2c22054ccdb8b0ff964cc1cc1431f
      https://github.com/PDAL/PDAL/commit/492bdfeab5f2c22054ccdb8b0ff964cc1cc1431f
  Changed paths:
    M io/bpf/BpfWriter.cpp
  Log Message:
  Make XYZ auto offset by default in BPF writer
  Commit: 1ee8a55bcaa9b18c8ba18e29644cbf00ec5fcb94
      https://github.com/PDAL/PDAL/commit/1ee8a55bcaa9b18c8ba18e29644cbf00ec5fcb94
  Changed paths:
    M doc/stages/writers.bpf.rst
  Log Message:
  Add doc note for BPF offset=auto
  Commit: 15af30070008a196c5eb49be3407657e405cfef9
      https://github.com/PDAL/PDAL/commit/15af30070008a196c5eb49be3407657e405cfef9
  Changed paths:
    M doc/tutorial/writing-kernel.rst
    M examples/writing-kernel/MyKernel.cpp
    M examples/writing-kernel/MyKernel.hpp
  Log Message:
  Updating Kernel tutorial to work with new code.
Using StageFactory as described in the previous version of the
tutorial, and updating the macro to use the general shared
plugin, rather than the kernel-specific macro which no longer
exists.
  Commit: 3f31924dc723293de0563192a53b427e025e1f5b
      https://github.com/PDAL/PDAL/commit/3f31924dc723293de0563192a53b427e025e1f5b
  Changed paths:
  Log Message:
  Changed library filename to be inline
  Commit: bdbcf0e1f9a77e050e6c973cf969abcfe7a1aa50
      https://github.com/PDAL/PDAL/commit/bdbcf0e1f9a77e050e6c973cf969abcfe7a1aa50
  Changed paths:
  Log Message:
  Merge pull request #1033 from scott-lewis-nsidc/update-write-kernel-tutorial
Update write kernel tutorial
  Commit: 2bd54ae2161b7f2406e3dfe593a181c33eb382aa
      https://github.com/PDAL/PDAL/commit/2bd54ae2161b7f2406e3dfe593a181c33eb382aa
  Changed paths:
  Log Message:
  Link the correct tutorial image
  Commit: 9f6936ab92e7a377470080ca25da71212ae4d99d
      https://github.com/PDAL/PDAL/commit/9f6936ab92e7a377470080ca25da71212ae4d99d
  Changed paths:
  Log Message:
  Fix italics in tutorial
  Commit: 8fde8256ac7b242e4d0872ec582cbe27546cd215
      https://github.com/PDAL/PDAL/commit/8fde8256ac7b242e4d0872ec582cbe27546cd215
  Date:   2015-11-13 (Fri, 13 Nov 2015)
  Changed paths:
    M doc/tutorial/writing-reader.rst
    M examples/writing-reader/MyReader.cpp
    M examples/writing-reader/MyReader.hpp
    A examples/writing-reader/pipeline-myreader.xml
    A examples/writing-reader/test-reader-input.txt
  Log Message:
  Updating reader tutorial.
Modifying reader tutorial to discuss the steps needed for a reader,
including a sample input file and pipeline flie to use.
  Commit: 042a7d469e2108ecfb93572a9840a965ea232847
      https://github.com/PDAL/PDAL/commit/042a7d469e2108ecfb93572a9840a965ea232847
  Changed paths:
    M src/Options.cpp
  Log Message:
  Fix reporting check for nameValid().
  Commit: e35ded5196ed19aad5b65bd7490511771af71fae
      https://github.com/PDAL/PDAL/commit/e35ded5196ed19aad5b65bd7490511771af71fae
  Changed paths:
  Log Message:
  Merge pull request #1036 from scott-lewis-nsidc/update-writing-reader-tutorial
  Commit: f9ed8b65600734e62c8be513bd85852fd3816e24
      https://github.com/PDAL/PDAL/commit/f9ed8b65600734e62c8be513bd85852fd3816e24
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2015-11-14 (Sat, 14 Nov 2015)
  Changed paths:
    M plugins/rxp/io/RxpReader.hpp
  Log Message:
  Set default value for boolean in RxpReader
This boolean value was not initialized on default reader creation,
which caused tests to fail on some machines. I don't know if this would
affect actual usages, but its a bugfix.
  Commit: 1394a1aeecda974faee66d69477c74d6cb54729c
      https://github.com/PDAL/PDAL/commit/1394a1aeecda974faee66d69477c74d6cb54729c
  Changed paths:
  Log Message:
  Merge pull request #1037 from gadomski/rivlib-cleanup
  Commit: a2419671fa443886ef2d9d2aeb93a04ef62f3eee
      https://github.com/PDAL/PDAL/commit/a2419671fa443886ef2d9d2aeb93a04ef62f3eee
  Date:   2015-11-16 (Mon, 16 Nov 2015)
  Changed paths:
  Log Message:
  Merge pull request #1032 from PDAL/bpf-auto-xyz-offsets
BPF should use auto offsets by default for XYZ dimensions
  Commit: b5bda2a7ddff9f3ba7d15adaa840e362934c0cb8
      https://github.com/PDAL/PDAL/commit/b5bda2a7ddff9f3ba7d15adaa840e362934c0cb8
  Changed paths:
    A doc/stages/filters.dartsample.rst
    A doc/tutorial/dart-throwing.rst
    A doc/tutorial/subsample-ex1.png
    A doc/tutorial/subsample-ex2.png
    A doc/tutorial/subsample-ex3.png
    A doc/tutorial/subsample-ex4.png
    A doc/tutorial/subsample-ex5.png
    A plugins/pcl/dartsample/dart_sample.cpp
    A plugins/pcl/dartsample/dart_sample.h
    A plugins/pcl/dartsample/dart_sample.hpp
    A plugins/pcl/filters/DartSampleFilter.cpp
    A plugins/pcl/filters/DartSampleFilter.hpp
  Log Message:
  Add PCL DartSample filter, and a PDAL filter to wrap it
  Commit: f7b7218f925cd6a1fd4a2dbc8d0cb54229e38301
      https://github.com/PDAL/PDAL/commit/f7b7218f925cd6a1fd4a2dbc8d0cb54229e38301
  Changed paths:
  Log Message:
  Merge pull request #1041 from PDAL/pcl-dartsample-filter
  Commit: 2f142d22ff1aeea99636fa6b6f080c0e79a32d41
      https://github.com/PDAL/PDAL/commit/2f142d22ff1aeea99636fa6b6f080c0e79a32d41
  Changed paths:
    M include/pdal/PointView.hpp
    M test/unit/PointViewTest.cpp
  Log Message:
  Check point view size in `getFieldAs`
`PointView::getFieldInternal` uses `deque::operator[]` to map index
values to raw point ids. This means that a user can silently access
beyond the end of of the `m_index` deque with an ill-advised
`getFieldAs` call, leading to either garbage results or a segfault.
Per
[discussion](https://github.com/gadomski/PDAL/commit/c1d54e56e2de841d37f2a1b1c218ed723053f6a9#commitcomment-14415138)
with @abellgithub, this should be considered a user error, albeit one
that we can protect against when in debug mode. Therefore, we use an
assert to check the bounds inside `getFieldAs`.
  Commit: 193667bb226c4e40365e2268a3ee0abb0d0e7ad6
      https://github.com/PDAL/PDAL/commit/193667bb226c4e40365e2268a3ee0abb0d0e7ad6
  Changed paths:
  Log Message:
  Merge pull request #1039 from gadomski/point-view-bounds-checking
Check point view size in `getFieldInternal`
  Commit: fbd7949fc4547a3e2f553d0bd81c806895160a1c
      https://github.com/PDAL/PDAL/commit/fbd7949fc4547a3e2f553d0bd81c806895160a1c
  Changed paths:
    A include/pdal/Geometry.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/tindex/TIndexKernel.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/pcl/dartsample/dart_sample.hpp
    M src/CMakeLists.txt
  Log Message:
  Smooth hexbin-generated boundaries.
  Commit: e0a5fdb599252f7c6640936faf243a7173a68a02
      https://github.com/PDAL/PDAL/commit/e0a5fdb599252f7c6640936faf243a7173a68a02
  Changed paths:
  Log Message:
  Commit: d5b114052a6ee904deecf915b6429b06af970071
      https://github.com/PDAL/PDAL/commit/d5b114052a6ee904deecf915b6429b06af970071
  Changed paths:
  Log Message:
  Don't include hexbin node twice.
  Commit: 4a9715460a5c4039e68550c161d904e4d4b8c05c
      https://github.com/PDAL/PDAL/commit/4a9715460a5c4039e68550c161d904e4d4b8c05c
  Date:   2015-11-17 (Tue, 17 Nov 2015)
  Changed paths:
    M doc/Makefile
    M doc/apps.rst
    M doc/download.rst
    M doc/index.rst
    M src/Options.cpp
    M src/Stage.cpp
  Log Message:
  Merge branch 'master' into stream
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/744d90c11277...4a9715460a5c
More information about the pdal-commits mailing list
