[pdal-commits] [PDAL/PDAL] 2003c9: Clean up the main CMakeLists.txt
GitHub
noreply at github.com
Fri Apr 8 11:55:14 PDT 2016
Branch: refs/heads/clear-gdal-errors
Home: https://github.com/PDAL/PDAL
Commit: 2003c9fd71a1832c9b2c2c95aec7ed5a1d10191f
https://github.com/PDAL/PDAL/commit/2003c9fd71a1832c9b2c2c95aec7ed5a1d10191f
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-04-05 (Tue, 05 Apr 2016)
Changed paths:
M CMakeLists.txt
A cmake/cpack.cmake
M cmake/directories.cmake
A cmake/gtest.cmake
A cmake/options.cmake
A cmake/rpath.cmake
Log Message:
Commit: 6ae5fdfb67263b59e23ea63710e2bdecbd34409a
https://github.com/PDAL/PDAL/commit/6ae5fdfb67263b59e23ea63710e2bdecbd34409a
Changed paths:
M include/pdal/PDALUtils.hpp
M include/pdal/PointTable.hpp
M include/pdal/PointView.hpp
M kernels/info/InfoKernel.cpp
M src/PDALUtils.cpp
M src/PointTable.cpp
M src/PointView.cpp
M src/SpatialReference.cpp
M src/Stage.cpp
M test/unit/PDALUtilsTest.cpp
Log Message:
Move some stuff from PDALUtils to the classes in which they belong.
Commit: 276d125140423a9673f69003606e960ee4790317
https://github.com/PDAL/PDAL/commit/276d125140423a9673f69003606e960ee4790317
Changed paths:
M include/pdal/PointRef.hpp
Log Message:
Fix bad conversion error message.
Commit: 0bb38faa0d493e1d87f0b749f171d57a2b497939
https://github.com/PDAL/PDAL/commit/0bb38faa0d493e1d87f0b749f171d57a2b497939
Date: 2016-04-06 (Wed, 06 Apr 2016)
Changed paths:
M RELEASENOTES.txt
M include/pdal/Dimension.hpp
M io/sbet/SbetCommon.cpp
M plugins/icebridge/io/IcebridgeReader.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
Log Message:
Rename dimension PlatformHeader to Azimuth.
Commit: 18a9dfccab250a289510a805855484f8040fadc4
https://github.com/PDAL/PDAL/commit/18a9dfccab250a289510a805855484f8040fadc4
Changed paths:
M plugins/icebridge/test/IcebridgeReaderTest.cpp
Log Message:
Fix dimension name.
Commit: 01a363889e5636bdfbaac1a5eeb3b5c76ad03809
https://github.com/PDAL/PDAL/commit/01a363889e5636bdfbaac1a5eeb3b5c76ad03809
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M scripts/docker/Dockerfile
Log Message:
Remove PDAL and PRC dirs from Docker image
These directories weren't being removed b/c we were inside of the
directory, so the relative path removal didn't work but still succeeded
thanks to `-f`.
Commit: d496dfe40fca3308b4868e9dd1e747efcd022a77
https://github.com/PDAL/PDAL/commit/d496dfe40fca3308b4868e9dd1e747efcd022a77
Changed paths:
M scripts/docker/rivlib/Dockerfile
Log Message:
Switch rivlib Dockerfile to pdal/pdal
pdal/master doesn't exist anymore.
[skip ci]
Commit: b705fc8caefe827d4827b3210755d0c57cf8b348
https://github.com/PDAL/PDAL/commit/b705fc8caefe827d4827b3210755d0c57cf8b348
Changed paths:
M kernels/tindex/TIndexKernel.cpp
Log Message:
Use single-quotes with GDAL column value.
Close #1219
Commit: 9dcf410c50612600732072d27587c99d16f54fce
https://github.com/PDAL/PDAL/commit/9dcf410c50612600732072d27587c99d16f54fce
Changed paths:
M scripts/docker/dependencies/Dockerfile
Log Message:
[docker] Clean up after each install
Commit: 50c1f96e367b260325cfb6ff273b45d2bcfb108f
https://github.com/PDAL/PDAL/commit/50c1f96e367b260325cfb6ff273b45d2bcfb108f
Author: Howard Butler <howard at hobu.co>
Date: 2016-04-07 (Thu, 07 Apr 2016)
Changed paths:
Log Message:
Merge pull request #1218 from gadomski/docker-update
Docker update
Commit: aa56f826795a18d901bc26b17b8a024a90678dc6
https://github.com/PDAL/PDAL/commit/aa56f826795a18d901bc26b17b8a024a90678dc6
Date: 2016-04-08 (Fri, 08 Apr 2016)
Changed paths:
M include/pdal/GDALUtils.hpp
M src/GDALUtils.cpp
Log Message:
simplify gdal::ErrorHandler
Commit: 86427fc9ffd6482e62ba604cf10da7734fd81c4c
https://github.com/PDAL/PDAL/commit/86427fc9ffd6482e62ba604cf10da7734fd81c4c
Changed paths:
M CMakeLists.txt
M RELEASENOTES.txt
A cmake/cpack.cmake
A cmake/gtest.cmake
A cmake/rpath.cmake
M src/PDALUtils.cpp
M src/PointView.cpp
M src/Stage.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into clear-gdal-errors
Compare: https://github.com/PDAL/PDAL/compare/9287aa338ed4...86427fc9ffd6
More information about the pdal-commits
