[pdal-commits] [PDAL/PDAL] afbfcc: support reading s3 and http over the network by em...
GitHub
noreply at github.com
Wed Apr 27 12:14:22 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: afbfccab6b2a06dab22b8b5e2e9d3e2bdd9e384b
https://github.com/PDAL/PDAL/commit/afbfccab6b2a06dab22b8b5e2e9d3e2bdd9e384b
Author: Howard Butler <howard at hobu.co>
Date: 2016-04-12 (Tue, 12 Apr 2016)
Changed paths:
M CMakeLists.txt
A cmake/curl.cmake
M cmake/examples/hobu-config.sh
M pdal_defines.h.in
M src/CMakeLists.txt
M src/util/CMakeLists.txt
M src/util/FileUtils.cpp
M test/unit/UtilsTest.cpp
A vendor/arbiter/CMakeLists.txt
A vendor/arbiter/LICENSE
A vendor/arbiter/README
A vendor/arbiter/arbiter.cpp
A vendor/arbiter/arbiter.hpp
A vendor/jsoncpp-1.6.2/dist/CMakeLists.txt
Log Message:
support reading s3 and http over the network by embedding http://github.com/connormanning/arbiter
Commit: 34f7bc820ed434c86b4ad3a2e6ce656587f7666c
https://github.com/PDAL/PDAL/commit/34f7bc820ed434c86b4ad3a2e6ce656587f7666c
Date: 2016-04-13 (Wed, 13 Apr 2016)
Changed paths:
M vendor/arbiter/arbiter.hpp
Log Message:
try to unicode the windows
Commit: fca7bc3c588aa3da9b8f62c937e73d2ca69815b1
https://github.com/PDAL/PDAL/commit/fca7bc3c588aa3da9b8f62c937e73d2ca69815b1
Changed paths:
M vendor/arbiter/CMakeLists.txt
Log Message:
jsoncpp now compiled as a static lib
Commit: da8994911d3465022e72540dd14369c7aecdcc39
https://github.com/PDAL/PDAL/commit/da8994911d3465022e72540dd14369c7aecdcc39
Changed paths:
Log Message:
arbiter needs to be -fPIC?
Commit: c8c53f066be3a485adef6c9f324e18ea9a531554
https://github.com/PDAL/PDAL/commit/c8c53f066be3a485adef6c9f324e18ea9a531554
Changed paths:
A cmake/modules/FindCurl.cmake
Log Message:
need to add FindCurl.cmake
Commit: 0adb9acc4590507248b11b6de40f7d616f7e0188
https://github.com/PDAL/PDAL/commit/0adb9acc4590507248b11b6de40f7d616f7e0188
Changed paths:
M vendor/jsoncpp-1.6.2/dist/CMakeLists.txt
Log Message:
jsoncpp needs to be -fPIC
Commit: 37818c3f34c554123090e6980d4138f09b6dd942
https://github.com/PDAL/PDAL/commit/37818c3f34c554123090e6980d4138f09b6dd942
Changed paths:
M CMakeLists.txt
A cmake/json.cmake
M src/PipelineReaderJSON.cpp
M src/PipelineReaderJSON.hpp
M vendor/arbiter/arbiter.cpp
Log Message:
another swing at JSONCPP cmake config
Commit: 0663829e2ac3dcd4b86ad2cec904ded89f94ff95
https://github.com/PDAL/PDAL/commit/0663829e2ac3dcd4b86ad2cec904ded89f94ff95
Changed paths:
M include/pdal/util/ProgramArgs.hpp
M src/Kernel.cpp
M test/unit/ProgramArgsTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into read-s3
Commit: bd9832cfbd92c1170f31f147cefa619ce1517403
https://github.com/PDAL/PDAL/commit/bd9832cfbd92c1170f31f147cefa619ce1517403
Changed paths:
M cmake/json.cmake
M plugins/greyhound/CMakeLists.txt
Log Message:
more JSON, more pain
Commit: 56c591e28fe397e70a16b63276ea62ea37d652bf
https://github.com/PDAL/PDAL/commit/56c591e28fe397e70a16b63276ea62ea37d652bf
Changed paths:
Log Message:
update arbiter
Commit: 9b27f5aea50ee496060d24311018f01c40d914f2
https://github.com/PDAL/PDAL/commit/9b27f5aea50ee496060d24311018f01c40d914f2
Changed paths:
Log Message:
update arbiter
Commit: 871c941040c14dfa467639232e3998d7eb3f4d7f
https://github.com/PDAL/PDAL/commit/871c941040c14dfa467639232e3998d7eb3f4d7f
Changed paths:
M cmake/json.cmake
Log Message:
bump jsoncpp min version to 1.6.2
Commit: 87347e3f3c162bd767df7eca35e31153096eaafb
https://github.com/PDAL/PDAL/commit/87347e3f3c162bd767df7eca35e31153096eaafb
Changed paths:
M CMakeLists.txt
M cmake/json.cmake
Log Message:
be more specific about jsoncpp include/linkage
Commit: b54e88b59991b82b10c6dd8b6aa05f48ef259bed
https://github.com/PDAL/PDAL/commit/b54e88b59991b82b10c6dd8b6aa05f48ef259bed
Changed paths:
M CMakeLists.txt
M cmake/json.cmake
Log Message:
make sure JSONCPP is marked optional, and when we don't find it, use our embedded version
Commit: b3a626c904e937943ea15fd9da148eba830c080f
https://github.com/PDAL/PDAL/commit/b3a626c904e937943ea15fd9da148eba830c080f
Date: 2016-04-14 (Thu, 14 Apr 2016)
Changed paths:
Log Message:
arbiter update
Commit: 17a75fbdfd37fcca9187aa0a932ed4c90575e5db
https://github.com/PDAL/PDAL/commit/17a75fbdfd37fcca9187aa0a932ed4c90575e5db
Date: 2016-04-18 (Mon, 18 Apr 2016)
Changed paths:
M plugins/p2g/io/P2gWriter.cpp
Log Message:
no need to const_cast
Commit: dd723e283d3a7040b4d91e1d3f5d3d5d6f40ebf5
https://github.com/PDAL/PDAL/commit/dd723e283d3a7040b4d91e1d3f5d3d5d6f40ebf5
Date: 2016-04-23 (Sat, 23 Apr 2016)
Changed paths:
M apps/pdal.cpp
M doc/tutorial/overview.rst
M examples/writing-kernel/MyKernel.cpp
M include/pdal/Kernel.hpp
M include/pdal/Options.hpp
M include/pdal/PipelineManager.hpp
M io/derivative/DerivativeWriter.cpp
M kernels/delta/DeltaKernel.cpp
M kernels/diff/DiffKernel.cpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/merge/MergeKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/random/RandomKernel.cpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.cpp
M kernels/sort/SortKernel.hpp
M kernels/split/SplitKernel.cpp
M kernels/tindex/TIndexKernel.cpp
M kernels/translate/TranslateKernel.cpp
M kernels/translate/TranslateKernel.hpp
M plugins/cpd/kernel/Cpd.cpp
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/hexbin/kernel/DensityKernel.hpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/ViewKernel.cpp
M src/Kernel.cpp
M src/PipelineManager.cpp
M src/PipelineReaderXML.cpp
M src/PipelineReaderXML.hpp
M src/Stage.cpp
M src/StageFactory.cpp
Log Message:
Commit: 8c1d0d792f7479f88aa1c92fc84f3b81d86daf9c
https://github.com/PDAL/PDAL/commit/8c1d0d792f7479f88aa1c92fc84f3b81d86daf9c
Date: 2016-04-24 (Sun, 24 Apr 2016)
Changed paths:
M doc/Makefile
Log Message:
add a docker-buildable make command for docs
Commit: ccbcc7744864ab53089017948cd87ae6710728aa
https://github.com/PDAL/PDAL/commit/ccbcc7744864ab53089017948cd87ae6710728aa
Date: 2016-04-25 (Mon, 25 Apr 2016)
Changed paths:
Log Message:
our own asString method because some older jsoncpp don't quite behave how we want
Commit: b30c825149f9de7274412da71d2da48d68a2f4fa
https://github.com/PDAL/PDAL/commit/b30c825149f9de7274412da71d2da48d68a2f4fa
Changed paths:
Log Message:
use 64bit sized integer classes, rethrow exception from jsoncpp instead of swallowing it
Commit: da81adb7427891e1c0f597c57093796c613e2187
https://github.com/PDAL/PDAL/commit/da81adb7427891e1c0f597c57093796c613e2187
Changed paths:
Log Message:
catch up arbiter
Commit: c3bc091eee76ab54f460aa9684b8201b875cafa1
https://github.com/PDAL/PDAL/commit/c3bc091eee76ab54f460aa9684b8201b875cafa1
Date: 2016-04-26 (Tue, 26 Apr 2016)
Changed paths:
M CMakeLists.txt
M cmake/macros.cmake
A dimbuilder/CMakeLists.txt
A dimbuilder/DimBuilder.cpp
A dimbuilder/DimBuilder.hpp
M include/pdal/Compression.hpp
A include/pdal/DimDetail.hpp
A include/pdal/DimType.hpp
A include/pdal/DimUtil.hpp
R include/pdal/Dimension.hpp
M include/pdal/PointLayout.hpp
M include/pdal/PointView.hpp
M include/pdal/Stage.hpp
M io/las/CMakeLists.txt
M io/las/LasUtils.hpp
M io/sbet/CMakeLists.txt
A src/Dimension.json
Log Message:
Commit: a66b4db5ac2f38b85944617ad488d53929c40407
https://github.com/PDAL/PDAL/commit/a66b4db5ac2f38b85944617ad488d53929c40407
Changed paths:
M CMakeLists.txt
A cmake/dimension.cmake
Log Message:
Commit: cc13ec11107120107e300dfb600e0d2759f6e1ef
https://github.com/PDAL/PDAL/commit/cc13ec11107120107e300dfb600e0d2759f6e1ef
Changed paths:
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/icebridge/test/IcebridgeReaderTest.cpp
Log Message:
Commit: 02991819eeca5480e7426daa1da058b92a97e2ae
https://github.com/PDAL/PDAL/commit/02991819eeca5480e7426daa1da058b92a97e2ae
Date: 2016-04-27 (Wed, 27 Apr 2016)
Changed paths:
Log Message:
working Arbiter-based remote write
Commit: 0a569157a83fd4eaee8cc9b7a66ff5dc6143ddfb
https://github.com/PDAL/PDAL/commit/0a569157a83fd4eaee8cc9b7a66ff5dc6143ddfb
Changed paths:
Log Message:
catch up to arbiter
Compare: https://github.com/PDAL/PDAL/compare/97342d4aa29d...0a569157a83f
More information about the pdal-commits
