[pdal-commits] [PDAL/PDAL] 9c88b1: doc rename Height -> HeightAboveGround
GitHub
noreply at github.com
Mon Aug 22 14:04:40 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 9c88b144f824e2b321032bfbb3210b7652a9d592
https://github.com/PDAL/PDAL/commit/9c88b144f824e2b321032bfbb3210b7652a9d592
Author: Martijn Visser <mgvisser at gmail.com>
Date: 2016-08-09 (Tue, 09 Aug 2016)
Changed paths:
M doc/tutorial/calculating-normalized-heights.rst
Log Message:
>From 1.2.0 release notes:
- filters.height now uses the dimension 'HeightAboveGround' instead of a
dimension named 'Height' to be compatible with the filters.heightaboveground.
Commit: 696c6ac53c01b0654f15bec472569a167150f7e1
https://github.com/PDAL/PDAL/commit/696c6ac53c01b0654f15bec472569a167150f7e1
Changed paths:
M doc/stages/filters.hag.rst
M doc/stages/filters.height.rst
Log Message:
docs height: flip the ferry direction
syntax is <from> = <to>
this way the HeightAboveGround overwrites the Z dimension
Commit: faa99123ffc53c47b2319a65fa849b05881696b9
https://github.com/PDAL/PDAL/commit/faa99123ffc53c47b2319a65fa849b05881696b9
Author: Howard Butler <howard at hobu.co>
Date: 2016-08-22 (Mon, 22 Aug 2016)
Changed paths:
Log Message:
Merge pull request #1280 from visr/ferryflip
doc fixes: ferry direction and HeightAboveGround
Compare: https://github.com/PDAL/PDAL/compare/6b1017b06d0e...faa99123ffc5
More information about the pdal-commits
