[pdal-commits] [PDAL/PDAL] d99f16: Fix tests for debug/verbose.
GitHub
noreply at github.com
Thu Aug 25 06:54:43 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d99f16d6af6648ca5d42faa79a34dce3e6419ce9
https://github.com/PDAL/PDAL/commit/d99f16d6af6648ca5d42faa79a34dce3e6419ce9
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-08-25 (Thu, 25 Aug 2016)
Changed paths:
M plugins/oci/test/OCITest.cpp
M plugins/pcl/test/PCLBlockFilterTest.cpp
M test/data/apps/pdalinfo_stage.txt
M test/data/apps/pdalinfo_stage_nosrs.txt
M test/data/filters/merge3.json.in
M test/data/filters/merge3.xml.in
M test/data/filters/reproject.xml.in
M test/data/nitf/reader.xml
M test/data/oracle/big-write.xml
M test/data/oracle/qfit-write.xml
M test/data/oracle/read-colorize.xml
M test/data/pipeline/nitf-chipper.json.in
M test/data/pipeline/p2g-writer.json.in
M test/data/pipeline/pipeline_interpolate.xml.in
M test/data/pipeline/qfit2las.json.in
M test/data/pipeline/reproject.json.in
M test/data/pipeline/transformation.json.in
M test/data/qfit/conversion.xml.in
M test/data/qfit/little-endian-conversion.xml.in
M test/data/qfit/reader.xml.in
M test/data/soci/read-cloud.xml
M test/data/soci/read.xml
M test/unit/filters/MergeTest.cpp
M test/unit/io/las/LasReaderTest.cpp
Log Message:
More information about the pdal-commits
