[pdal-commits] [PDAL/PDAL] 3a3aad: Initial commit of Mongus-inspired ground return se...
GitHub
noreply at github.com
Thu Aug 25 10:18:11 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 3a3aad97ab41dd03b43fec517bde7688de1db4ce
https://github.com/PDAL/PDAL/commit/3a3aad97ab41dd03b43fec517bde7688de1db4ce
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-08-25 (Thu, 25 Aug 2016)
Changed paths:
M filters/CMakeLists.txt
A filters/mongus/CMakeLists.txt
A filters/mongus/MongusFilter.cpp
A filters/mongus/MongusFilter.hpp
M src/StageFactory.cpp
Log Message:
Initial commit of Mongus-inspired ground return segmentation filter
Based off the work of Mongus and Zalik. (We take a different approach when
filtering control points against the interpolated surface.)
File this under experimental. I'll continue to tweak the control point
filtering at each iteration.
Commit: 5d13cbed56c67d41c310f5955ebde4cf535c50fb
https://github.com/PDAL/PDAL/commit/5d13cbed56c67d41c310f5955ebde4cf535c50fb
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1288 from PDAL/mongus-redux
Compare: https://github.com/PDAL/PDAL/compare/e4418d85c525...5d13cbed56c6
More information about the pdal-commits
