[pdal-commits] [PDAL/PDAL] c8afe8: don't add filename arg to ProgramArgs for readers....
    GitHub
    noreply at github.com
    Sat Dec  3 08:49:09 PST 2016
  Branch: refs/tags/docker-master
  Home:   https://github.com/PDAL/PDAL
  Commit: c8afe8099b58d3f7bf3d4af38606ed7e82e90699
      https://github.com/PDAL/PDAL/commit/c8afe8099b58d3f7bf3d4af38606ed7e82e90699
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-11-22 (Tue, 22 Nov 2016)
  Changed paths:
    M plugins/mrsid/io/MrsidReader.cpp
  Log Message:
  don't add filename arg to ProgramArgs for readers.mrsid
  Commit: caf533b9357bec34e97c4c80c08dd1a54194aaee
      https://github.com/PDAL/PDAL/commit/caf533b9357bec34e97c4c80c08dd1a54194aaee
  Date:   2016-11-28 (Mon, 28 Nov 2016)
  Changed paths:
    M doc/apps/density.rst
    A doc/apps/hausdorff.rst
    A doc/apps/sort.rst
    A doc/stages/filters.computerange.rst
    M filters/CMakeLists.txt
    A filters/computerange/CMakeLists.txt
    A filters/computerange/ComputeRangeFilter.cpp
    A filters/computerange/ComputeRangeFilter.hpp
    M filters/mongus/MongusFilter.cpp
    M filters/mongus/MongusFilter.hpp
    M filters/smrf/SMRFilter.cpp
    M filters/smrf/SMRFilter.hpp
    M include/pdal/EigenUtils.hpp
    M include/pdal/PDALUtils.hpp
    M kernels/CMakeLists.txt
    M kernels/delta/DeltaKernel.cpp
    M kernels/diff/DiffKernel.cpp
    A kernels/hausdorff/CMakeLists.txt
    A kernels/hausdorff/HausdorffKernel.cpp
    A kernels/hausdorff/HausdorffKernel.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/merge/MergeKernel.cpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/hexbin/kernel/DensityKernel.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M src/EigenUtils.cpp
    M src/KernelFactory.cpp
    M src/PDALUtils.cpp
    M src/PluginManager.cpp
    M src/StageFactory.cpp
    M test/unit/CMakeLists.txt
    M test/unit/EigenTest.cpp
    A test/unit/apps/HausdorffTest.cpp
    A test/unit/filters/ComputeRangeFilterTest.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 53e71fb977959424e49c383cf38945309972fc03
      https://github.com/PDAL/PDAL/commit/53e71fb977959424e49c383cf38945309972fc03
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
    M scripts/docker/dependencies/Dockerfile.xenial
  Log Message:
  Commit: ff59e7d98077f0a793a288e8fc2d3bf404bff40f
      https://github.com/PDAL/PDAL/commit/ff59e7d98077f0a793a288e8fc2d3bf404bff40f
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-11-29 (Tue, 29 Nov 2016)
  Changed paths:
    M plugins/pcl/CMakeLists.txt
  Log Message:
  Fix #1410
  Commit: fd36f60f89a6c5ef620bba22ae269069bd7d791a
      https://github.com/PDAL/PDAL/commit/fd36f60f89a6c5ef620bba22ae269069bd7d791a
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #1411 from PDAL/issue/1410-pcd-writer
CMake missing PCD writer sources
  Commit: 7c1236d1a6ec640074ed8c75bc09c454d002ad79
      https://github.com/PDAL/PDAL/commit/7c1236d1a6ec640074ed8c75bc09c454d002ad79
  Date:   2016-11-30 (Wed, 30 Nov 2016)
  Changed paths:
  Log Message:
  Numerical gradient will be computed on matrices larger than 3x3, compute them properly
  Commit: b054407c311cde32ca9c51a01ce95293d512e6b0
      https://github.com/PDAL/PDAL/commit/b054407c311cde32ca9c51a01ce95293d512e6b0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M dimbuilder/CMakeLists.txt
  Log Message:
  Don't build dimbuilder with util lib.
  Commit: e6d6756a48700919eb983322220a3255c559eb87
      https://github.com/PDAL/PDAL/commit/e6d6756a48700919eb983322220a3255c559eb87
  Changed paths:
  Log Message:
  Merge pull request #1412 from PDAL/eigen-gradients-bug
  Commit: d9dd72af7c1dbfc259535c7a73f9a444e347a118
      https://github.com/PDAL/PDAL/commit/d9dd72af7c1dbfc259535c7a73f9a444e347a118
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/util/ProgramArgs.hpp
  Log Message:
  Commit: 6e247e3391b470bab187bc930923abeac9a64b1c
      https://github.com/PDAL/PDAL/commit/6e247e3391b470bab187bc930923abeac9a64b1c
  Changed paths:
  Log Message:
  Link with dl for dladdr on linux.
  Commit: 18cbbdd9bd3ee11e9c5830ca4f0ea29a2a5e1842
      https://github.com/PDAL/PDAL/commit/18cbbdd9bd3ee11e9c5830ca4f0ea29a2a5e1842
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: abb0c6786294672266c9451528ba363596d1010b
      https://github.com/PDAL/PDAL/commit/abb0c6786294672266c9451528ba363596d1010b
  Changed paths:
  Log Message:
  Commit: 9ea765c681172e1b21049caa0a1b80f57fd57415
      https://github.com/PDAL/PDAL/commit/9ea765c681172e1b21049caa0a1b80f57fd57415
  Date:   2016-12-02 (Fri, 02 Dec 2016)
  Changed paths:
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/hexbin/filters/HexBin.hpp
  Log Message:
  Allow user to control boundary smoothing (on by default) (#1416)
* Allow user to control boundary smoothing (on by default)
* updates based on abell's comments
  Commit: 5cb2e9e0ac8c3104af70edb483330bef983fab46
      https://github.com/PDAL/PDAL/commit/5cb2e9e0ac8c3104af70edb483330bef983fab46
  Changed paths:
    M src/PipelineReaderJSON.cpp
    A test/data/pipeline/issue1417.json.in
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Fix reader override with invalid file in pipeline.
Close #1417
  Commit: e33e0828cb70fcba8b293ad8272436e818342cc5
      https://github.com/PDAL/PDAL/commit/e33e0828cb70fcba8b293ad8272436e818342cc5
  Date:   2016-12-03 (Sat, 03 Dec 2016)
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  build docker container at make -j 2 due to DockerHub instances running out of memory when building
Compare: https://github.com/PDAL/PDAL/compare/f3602b17cede...e33e0828cb70
More information about the pdal-commits
