[pdal-commits] [PDAL/PDAL] 52b7a0: Add filter to locate max value in a given dimensio...
GitHub
noreply at github.com
Wed Dec 21 11:26:50 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 52b7a02ef0ebc7e8cb911e86926604d87cb2efc3
https://github.com/PDAL/PDAL/commit/52b7a02ef0ebc7e8cb911e86926604d87cb2efc3
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-12-21 (Wed, 21 Dec 2016)
Changed paths:
A doc/stages/filters.locatemax.rst
A filters/LocateMaxFilter.cpp
A filters/LocateMaxFilter.hpp
M pdal/StageFactory.cpp
M test/unit/CMakeLists.txt
A test/unit/filters/LocateMaxFilterTest.cpp
Log Message:
Add filter to locate max value in a given dimension
If many points share the max value, this simply gives you the first one.
Commit: 67fed24a05707c230a5c8b5f6b43ccf631787d44
https://github.com/PDAL/PDAL/commit/67fed24a05707c230a5c8b5f6b43ccf631787d44
Changed paths:
A doc/stages/filters.locate.rst
R doc/stages/filters.locatemax.rst
A filters/LocateFilter.cpp
A filters/LocateFilter.hpp
R filters/LocateMaxFilter.cpp
R filters/LocateMaxFilter.hpp
A test/unit/filters/LocateFilterTest.cpp
R test/unit/filters/LocateMaxFilterTest.cpp
Log Message:
Locate filter can now locate min or max value
Commit: c0491d2c64f8a9ad76d35d34352e06d7ba01e588
https://github.com/PDAL/PDAL/commit/c0491d2c64f8a9ad76d35d34352e06d7ba01e588
Changed paths:
M doc/stages/filters.locate.rst
Log Message:
Typo in filters.locate docs
Commit: 71b0b6c570083e168c161b96abfe9d220bfb08e5
https://github.com/PDAL/PDAL/commit/71b0b6c570083e168c161b96abfe9d220bfb08e5
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1453 from PDAL/locatemax
Compare: https://github.com/PDAL/PDAL/compare/f4942fcb68a1...71b0b6c57008
More information about the pdal-commits
