[pdal-commits] [PDAL/PDAL] 7a10e1: Rename PointRef to PointIdxRef.
GitHub
noreply at github.com
Thu Feb 4 17:18:58 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 7a10e1ca5e8268d3c49a17d449d2d713cea83001
https://github.com/PDAL/PDAL/commit/7a10e1ca5e8268d3c49a17d449d2d713cea83001
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2015-10-16 (Fri, 16 Oct 2015)
Changed paths:
M filters/sort/SortFilter.hpp
M include/pdal/PointView.hpp
M include/pdal/PointViewIter.hpp
Log Message:
Commit: 6b5baca594fdc8585433f0ac3f629be1974f24b4
https://github.com/PDAL/PDAL/commit/6b5baca594fdc8585433f0ac3f629be1974f24b4
Changed paths:
M include/pdal/PointTable.hpp
M src/PointTable.cpp
M test/unit/PointTableTest.cpp
Log Message:
Use Dimension::Id as long as possible.
Use std::copy instead of memcpy.
Commit: 709360bd6d5604b80b055cca383a79937e83321a
https://github.com/PDAL/PDAL/commit/709360bd6d5604b80b055cca383a79937e83321a
Date: 2015-10-19 (Mon, 19 Oct 2015)
Changed paths:
M doc/stages/writers.p2g.rst
Log Message:
Merge remote-tracking branch 'origin/masterupdates' into stream
Commit: ef977075cad5ecb83e22b3eb24d6338563e5699a
https://github.com/PDAL/PDAL/commit/ef977075cad5ecb83e22b3eb24d6338563e5699a
Date: 2015-10-20 (Tue, 20 Oct 2015)
Changed paths:
M include/pdal/Stage.hpp
M io/sbet/SbetReader.cpp
M io/sbet/SbetReader.hpp
M src/CMakeLists.txt
M src/PointView.cpp
Log Message:
First cut at streaming.
Commit: f94d313f32de1e3c3ea75606dfdb079caa54b7a8
https://github.com/PDAL/PDAL/commit/f94d313f32de1e3c3ea75606dfdb079caa54b7a8
Date: 2015-10-21 (Wed, 21 Oct 2015)
Changed paths:
M src/Stage.cpp
Log Message:
Create a fixed point table.
Commit: e56d595693a99aaa80c91799c13636fa9cbf2c21
https://github.com/PDAL/PDAL/commit/e56d595693a99aaa80c91799c13636fa9cbf2c21
Changed paths:
M src/Stage.cpp
Log Message:
First cut at stream execution. Doesn't handle filtering.
Commit: 04b37a0cb7b0ee09fc1f5cd17c4c630ab7f53aa2
https://github.com/PDAL/PDAL/commit/04b37a0cb7b0ee09fc1f5cd17c4c630ab7f53aa2
Date: 2015-10-22 (Thu, 22 Oct 2015)
Changed paths:
M src/Stage.cpp
M test/unit/CMakeLists.txt
Log Message:
First working simple streaming with test.
Commit: 17cd0a6660a621fa68ec69969b620bea34e4325a
https://github.com/PDAL/PDAL/commit/17cd0a6660a621fa68ec69969b620bea34e4325a
Changed paths:
A test/unit/StreamingTest.cpp
Log Message:
Missed new file.
Commit: 89e7457b417b4fc15dd4e86331c8d49ddf420564
https://github.com/PDAL/PDAL/commit/89e7457b417b4fc15dd4e86331c8d49ddf420564
Changed paths:
A test/data/sbet/autzen_trim.sbet
Log Message:
Missed test file.
Commit: c3aa7576443c6f3fadacec15aea235b11e0762cd
https://github.com/PDAL/PDAL/commit/c3aa7576443c6f3fadacec15aea235b11e0762cd
Changed paths:
A include/pdal/PointContainer.hpp
A include/pdal/PointRef.hpp
Log Message:
More missed files.
Commit: 13d3c7f6beac5f9899ff0bd22a1113583eb6fb01
https://github.com/PDAL/PDAL/commit/13d3c7f6beac5f9899ff0bd22a1113583eb6fb01
Date: 2015-10-28 (Wed, 28 Oct 2015)
Changed paths:
M CMakeLists.txt
M doc/Makefile
A doc/_templates/layout.html
R doc/_themes/bootstrap/bootstrap.js
R doc/_themes/bootstrap/bootstrap.min.js
R doc/_themes/bootstrap/indexsidebar.html
R doc/_themes/bootstrap/static/bootstrap-default.css
R doc/_themes/bootstrap/static/bootstrap-default.min.css
R doc/_themes/bootstrap/static/bootstrap-dropdown.js
R doc/_themes/bootstrap/static/bootstrap-engineauth.css
R doc/_themes/bootstrap/static/bootstrap-engineauth.min.css
R doc/_themes/bootstrap/static/bootstrap-responsive.css
R doc/_themes/bootstrap/static/bootstrap-responsive.min.css
R doc/_themes/bootstrap/static/bootstrap-sapling.css
R doc/_themes/bootstrap/static/jquery.js
R doc/_themes/bootstrap/static/sphinx-bootstrap.css
M doc/api/cpp/bounds.rst
A doc/api/cpp/filter.rst
M doc/api/cpp/index.rst
M doc/api/cpp/log.rst
M doc/api/cpp/metadata.rst
R doc/api/cpp/option.rst
M doc/api/cpp/options.rst
M doc/api/cpp/pointtable.rst
M doc/api/cpp/pointview.rst
M doc/api/cpp/reader.rst
M doc/api/cpp/stage.rst
M doc/api/cpp/writer.rst
M doc/api/index.rst
M doc/community.rst
M doc/compilation/media/OSGeo4WInstallIConv.png
M doc/compilation/unix.rst
M doc/conf.py
M doc/development/index.rst
R doc/docs.rst
M doc/faq.rst
M doc/index.rst
M doc/stages/filters.chipper.rst
A doc/stages/filters.divider.rst
A doc/stages/filters.randomize.rst
M doc/stages/filters.range.rst
M doc/stages/filters.sort.rst
M doc/stages/filters.statisticaloutlier.rst
M doc/stages/index.rst
A doc/stages/ranges.rst
M doc/stages/readers.bpf.rst
M doc/stages/readers.gdal.rst
M doc/stages/readers.geowave.rst
M doc/stages/readers.las.rst
M doc/stages/readers.ply.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.geowave.rst
M doc/stages/writers.las.rst
M doc/stages/writers.nitf.rst
M doc/tutorial/liblas_to_pdal.rst
M doc/tutorial/pcl_ground.rst
M doc/tutorial/reading.rst
M doc/tutorial/using.rst
M doc/tutorial/writing-filter.rst
M doc/tutorial/writing-kernel.rst
M doc/tutorial/writing-reader.rst
M doc/tutorial/writing-writer.rst
M doc/tutorial/writing.rst
M doc/vagrant.rst
M filters/CMakeLists.txt
A filters/divider/CMakeLists.txt
A filters/divider/DividerFilter.cpp
A filters/divider/DividerFilter.hpp
A filters/randomize/CMakeLists.txt
A filters/randomize/RandomizeFilter.cpp
A filters/randomize/RandomizeFilter.hpp
M filters/range/RangeFilter.cpp
M filters/range/RangeFilter.hpp
M filters/reprojection/ReprojectionFilter.cpp
M filters/reprojection/ReprojectionFilter.hpp
M include/pdal/PointLayout.hpp
M io/faux/FauxReader.cpp
M io/faux/FauxReader.hpp
M io/las/LasReader.cpp
M io/ply/CMakeLists.txt
M src/Stage.cpp
R test/data/logs/logtest.txt
M test/unit/LogTest.cpp
M test/unit/StreamingTest.cpp
A test/unit/filters/DividerFilterTest.cpp
A test/unit/filters/RandomizeFilterTest.cpp
M test/unit/filters/RangeFilterTest.cpp
M test/unit/io/faux/FauxReaderTest.cpp
R vendor/rply-1.1.3/LICENSE
R vendor/rply-1.1.3/etc/convert.c
R vendor/rply-1.1.3/etc/dump.c
R vendor/rply-1.1.3/etc/input.ply
R vendor/rply-1.1.3/etc/sconvert.c
R vendor/rply-1.1.3/manual/manual.html
R vendor/rply-1.1.3/manual/reference.css
R vendor/rply-1.1.3/manual/rply.png
R vendor/rply-1.1.3/rply.c
R vendor/rply-1.1.3/rply.h
A vendor/rply-1.1.4/LICENSE
A vendor/rply-1.1.4/etc/convert.c
A vendor/rply-1.1.4/etc/dump.c
A vendor/rply-1.1.4/etc/input.ply
A vendor/rply-1.1.4/etc/sconvert.c
A vendor/rply-1.1.4/manual/manual.html
A vendor/rply-1.1.4/manual/reference.css
A vendor/rply-1.1.4/manual/rply.png
A vendor/rply-1.1.4/rply.c
A vendor/rply-1.1.4/rply.h
A vendor/rply-1.1.4/rplyfile.h
Log Message:
Merge remote-tracking branch 'origin/master' into stream
Commit: a6222e3af98c9774dec9347d2a0cc60245376cb5
https://github.com/PDAL/PDAL/commit/a6222e3af98c9774dec9347d2a0cc60245376cb5
Changed paths:
M src/Stage.cpp
Log Message:
Filtered streaming works.
Update RangeFilter to streaming.
Update FauxReader to streaming.
Add real streaming test.
Commit: 744d90c112778d8f453ad44ef4f8b4c6593fb63f
https://github.com/PDAL/PDAL/commit/744d90c112778d8f453ad44ef4f8b4c6593fb63f
Date: 2015-10-30 (Fri, 30 Oct 2015)
Changed paths:
Log Message:
Pass PointRef as reference. (Need a better name).
Commit: 4a9715460a5c4039e68550c161d904e4d4b8c05c
https://github.com/PDAL/PDAL/commit/4a9715460a5c4039e68550c161d904e4d4b8c05c
Author: Connor Manning <connor at hobu.co>
Date: 2015-11-17 (Tue, 17 Nov 2015)
Changed paths:
M cmake/examples/hobu-config.sh
M doc/Makefile
M doc/apps.rst
M doc/compilation/dependencies.rst
M doc/compilation/index.rst
M doc/compilation/windows.rst
M doc/development/docs.rst
A doc/docbuild/Dockerfile
A doc/docbuild/run.sh
M doc/download.rst
M doc/index.rst
M doc/stages/filters.attribute.rst
M doc/stages/filters.colorization.rst
A doc/stages/filters.dartsample.rst
M doc/stages/filters.decimation.rst
M doc/stages/filters.divider.rst
A doc/stages/filters.height.rst
M doc/stages/filters.predicate.rst
M doc/stages/filters.transformation.rst
M doc/stages/filters.voxelgrid.rst
A doc/tutorial/autzen-elevation.png
A doc/tutorial/autzen-height.png
A doc/tutorial/autzen-shapes-clipped.png
A doc/tutorial/autzen-shapes-point-cloud.png
A doc/tutorial/autzen-shapes-to-clip.png
A doc/tutorial/calculating-normalized-heights.rst
A doc/tutorial/clipping-with-shapefile.rst
A doc/tutorial/dart-throwing.rst
M doc/tutorial/index.rst
M doc/tutorial/overview.rst
A doc/tutorial/subsample-ex1.png
A doc/tutorial/subsample-ex2.png
A doc/tutorial/subsample-ex3.png
A doc/tutorial/subsample-ex4.png
A doc/tutorial/subsample-ex5.png
M examples/writing-filter/MyFilter.cpp
M examples/writing-filter/MyFilter.hpp
M examples/writing-kernel/MyKernel.cpp
M examples/writing-kernel/MyKernel.hpp
M examples/writing-reader/MyReader.cpp
M examples/writing-reader/MyReader.hpp
A examples/writing-reader/pipeline-myreader.xml
A examples/writing-reader/test-reader-input.txt
M examples/writing/tutorial.cpp
A include/pdal/Geometry.hpp
M include/pdal/Options.hpp
M include/pdal/PDALUtils.hpp
M io/bpf/BpfWriter.cpp
M io/las/LasReader.hpp
M kernels/tindex/TIndexKernel.cpp
M kernels/tindex/TIndexKernel.hpp
M plugins/hexbin/filters/HexBin.cpp
M plugins/nitf/io/NitfReader.cpp
M plugins/nitf/io/NitfReader.hpp
M plugins/pcl/CMakeLists.txt
A plugins/pcl/dartsample/dart_sample.cpp
A plugins/pcl/dartsample/dart_sample.h
A plugins/pcl/dartsample/dart_sample.hpp
A plugins/pcl/filters/DartSampleFilter.cpp
A plugins/pcl/filters/DartSampleFilter.hpp
A plugins/pcl/filters/HeightFilter.cpp
A plugins/pcl/filters/HeightFilter.hpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/rxp/io/RxpReader.hpp
M src/Options.cpp
M src/PluginManager.cpp
M src/Stage.cpp
A test/data/autzen/attributes.json
A test/data/autzen/attributes.vrt
M test/unit/OptionsTest.cpp
M test/unit/PointViewTest.cpp
Log Message:
Merge branch 'master' into stream
Conflicts:
Commit: 7bc2cd2267dc929ca32238ba8154f8564ace86cc
https://github.com/PDAL/PDAL/commit/7bc2cd2267dc929ca32238ba8154f8564ace86cc
Date: 2015-11-24 (Tue, 24 Nov 2015)
Changed paths:
M doc/Makefile
M doc/apps.rst
M doc/development/conventions.rst
M doc/development/errorhandling.rst
M doc/development/goals.rst
M doc/development/testing.rst
R doc/development/usecases.rst
M doc/download.rst
M doc/index.rst
M doc/stages/filters.hexbin.rst
M doc/stages/ranges.rst
A doc/stages/readers.tindex.rst
M examples/writing-writer/MyWriter.cpp
M examples/writing-writer/MyWriter.hpp
A examples/writing-writer/pipeline-mywriter.xml
M filters/crop/CropFilter.cpp
M filters/crop/CropFilter.hpp
M filters/merge/MergeFilter.cpp
M filters/merge/MergeFilter.hpp
M include/pdal/FlexWriter.hpp
M include/pdal/GDALUtils.hpp
M include/pdal/Metadata.hpp
M include/pdal/SpatialReference.hpp
M include/pdal/StageWrapper.hpp
M include/pdal/util/Algorithm.hpp
M include/pdal/util/Utils.hpp
M io/CMakeLists.txt
M io/bpf/BpfWriter.hpp
M io/derivative/DerivativeWriter.cpp
M io/derivative/DerivativeWriter.hpp
M io/las/LasError.hpp
M io/las/LasHeader.hpp
M io/las/LasWriter.cpp
M io/las/LasWriter.hpp
M io/text/TextWriter.cpp
A io/tindex/CMakeLists.txt
A io/tindex/TIndexReader.cpp
A io/tindex/TIndexReader.hpp
M pdal_defines.h.in
M plugins/hexbin/filters/HexBin.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/NitfWriter.hpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/p2g/io/P2gWriter.cpp
M plugins/p2g/io/P2gWriter.hpp
M plugins/pgpointcloud/io/PgReader.cpp
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M plugins/python/filters/ProgrammableFilter.cpp
R plugins/python/plang/CMakeLists.txt
R plugins/python/plang/Plang.cpp
R plugins/python/plang/Plang.hpp
M src/Options.cpp
M src/PointLayout.cpp
M src/SpatialReference.cpp
M src/Stage.cpp
M src/StageFactory.cpp
M src/plang/Environment.cpp
A test/data/filters/merge2.xml.in
A test/data/filters/merge3.xml.in
A test/data/las/test_epsg_4047.las
A test/data/las/test_epsg_4326.las
A test/data/las/test_epsg_4326x3.las
A test/data/las/test_utm16.las
A test/data/las/test_utm17.las
A test/data/pipeline/tindex.xml
A test/data/pipeline/tindex.xml.in
M test/unit/SpatialReferenceTest.cpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/MergeTest.cpp
M test/unit/io/las/LasWriterTest.cpp
Log Message:
Commit: 386e2f1e255ca067112c235fc9cb3c2083b0b644
https://github.com/PDAL/PDAL/commit/386e2f1e255ca067112c235fc9cb3c2083b0b644
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/stream' into stream
Commit: a9e1024cd20ef7d4dd6ac476fa7e97fca0391be2
https://github.com/PDAL/PDAL/commit/a9e1024cd20ef7d4dd6ac476fa7e97fca0391be2
Changed paths:
Log Message:
Remove errant semicolon.
Commit: 73259df8d765fec941b75ddc6654a6d783d521f7
https://github.com/PDAL/PDAL/commit/73259df8d765fec941b75ddc6654a6d783d521f7
Date: 2015-11-30 (Mon, 30 Nov 2015)
Changed paths:
M include/pdal/PointRef.hpp
M test/unit/io/las/LasReaderTest.cpp
Log Message:
Add streaming support for LasReader.
Commit: bde12d7bc1c1c8db651ac173242ef1947dcc35aa
https://github.com/PDAL/PDAL/commit/bde12d7bc1c1c8db651ac173242ef1947dcc35aa
Date: 2015-12-01 (Tue, 01 Dec 2015)
Changed paths:
Log Message:
Ifdef laszip/lazperf on tests.
Commit: 133137aa520088c75132298fcd132915fbf12a55
https://github.com/PDAL/PDAL/commit/133137aa520088c75132298fcd132915fbf12a55
Date: 2015-12-02 (Wed, 02 Dec 2015)
Changed paths:
M .travis.yml
M CMakeLists.txt
A ChangeLog
A RELEASENOTES.txt
A doc/docker.rst
M doc/download.rst
M doc/index.rst
M include/pdal/Geometry.hpp
M include/pdal/util/Bounds.hpp
M io/ilvis2/Ilvis2Reader.cpp
M io/ilvis2/Ilvis2Reader.hpp
M io/tindex/TIndexReader.cpp
M io/tindex/TIndexReader.hpp
M scripts/ci/before_install.sh
M scripts/ci/common.sh
M scripts/ci/script.sh
A scripts/docker/Dockerfile
A scripts/docker/dependencies/Dockerfile
A scripts/docker/packaging/Dockerfile
Log Message:
Commit: 781b6ad5761253433b4b9cf848452ca6d3f59d20
https://github.com/PDAL/PDAL/commit/781b6ad5761253433b4b9cf848452ca6d3f59d20
Date: 2015-12-03 (Thu, 03 Dec 2015)
Changed paths:
M src/Stage.cpp
Log Message:
Make LAS writer work with streaming.
Commit: 305dec964bcdd6add22b63313e070ffd818cc309
https://github.com/PDAL/PDAL/commit/305dec964bcdd6add22b63313e070ffd818cc309
Changed paths:
Log Message:
Only allocate a single buffer for writing LAS data in streaming mode.
Consolidate LAS writer code for streaming and non-streaming modes.
Commit: 07c068fdda1e50be358b0e9d4bcc3aaeb0271406
https://github.com/PDAL/PDAL/commit/07c068fdda1e50be358b0e9d4bcc3aaeb0271406
Changed paths:
M src/Stage.cpp
Log Message:
Allow a streaming point table to be subclassed.
Commit: 7ab0b3af1259d5fbc25c6780451e2c758257088f
https://github.com/PDAL/PDAL/commit/7ab0b3af1259d5fbc25c6780451e2c758257088f
Date: 2015-12-04 (Fri, 04 Dec 2015)
Changed paths:
M io/bpf/BpfReader.cpp
M io/bpf/BpfReader.hpp
M test/unit/io/bpf/BPFTest.cpp
Log Message:
Streaming for BPF reading.
Commit: 15843c6b208f9d8ee363c22578b89a4ea563ee7d
https://github.com/PDAL/PDAL/commit/15843c6b208f9d8ee363c22578b89a4ea563ee7d
Changed paths:
Log Message:
Use function to get layout.
Commit: 05342593a37cf0000fb8943f948f4369b9d95012
https://github.com/PDAL/PDAL/commit/05342593a37cf0000fb8943f948f4369b9d95012
Date: 2015-12-06 (Sun, 06 Dec 2015)
Changed paths:
Log Message:
Add streaming capability to reprojection filter.
Commit: c2dc156fd405a0da2ed1d68333901934951ca122
https://github.com/PDAL/PDAL/commit/c2dc156fd405a0da2ed1d68333901934951ca122
Date: 2015-12-08 (Tue, 08 Dec 2015)
Changed paths:
Log Message:
PointLayout as argument to PointTable.
Commit: f383053881eb6290aef08558485f41c50831aac3
https://github.com/PDAL/PDAL/commit/f383053881eb6290aef08558485f41c50831aac3
Date: 2015-12-10 (Thu, 10 Dec 2015)
Changed paths:
Log Message:
Merge branch 'stream' of github.com:PDAL/PDAL into stream
Commit: 609758d62c0a99a1760bcaad80ffb13ccf29ebc5
https://github.com/PDAL/PDAL/commit/609758d62c0a99a1760bcaad80ffb13ccf29ebc5
Changed paths:
M filters/colorization/ColorizationFilter.cpp
M filters/colorization/ColorizationFilter.hpp
Log Message:
Support streaming with colorization.
Commit: 96e4e9fc59cee0276b9fa9fc706e400750a2e4f9
https://github.com/PDAL/PDAL/commit/96e4e9fc59cee0276b9fa9fc706e400750a2e4f9
Changed paths:
M include/pdal/util/OStream.hpp
Log Message:
Don't crash when creating OStreamMarker on unopen stream.
Commit: 10a593c6445cff04fd1e9c144bddf4758f6f9d80
https://github.com/PDAL/PDAL/commit/10a593c6445cff04fd1e9c144bddf4758f6f9d80
Date: 2015-12-11 (Fri, 11 Dec 2015)
Changed paths:
M appveyor.yml
M cmake/geos.cmake
M include/pdal/Compression.hpp
M include/pdal/Dimension.hpp
M scripts/docker/Dockerfile
M scripts/docker/dependencies/Dockerfile
M src/pdal_config.cpp
A test/data/las/test1_4.las
Log Message:
Commit: c94c31d8c794a75608cf1c30259bfd7f936979a5
https://github.com/PDAL/PDAL/commit/c94c31d8c794a75608cf1c30259bfd7f936979a5
Changed paths:
M appveyor.yml
M cmake/geos.cmake
Log Message:
Commit: 736993b65c155cc1d868019ce7af4604c614a7ba
https://github.com/PDAL/PDAL/commit/736993b65c155cc1d868019ce7af4604c614a7ba
Changed paths:
A filters/streamcallback/CMakeLists.txt
A filters/streamcallback/StreamCallbackFilter.cpp
A filters/streamcallback/StreamCallbackFilter.hpp
M test/unit/filters/ColorizationFilterTest.cpp
Log Message:
Add StreamCallbackFilter.
Add tests for streaming colorization.
Commit: fdb74537c504c012951332902388fe7d62f00226
https://github.com/PDAL/PDAL/commit/fdb74537c504c012951332902388fe7d62f00226
Changed paths:
M src/Stage.cpp
Log Message:
Use references instead of pointers when possible.
Commit: da2346f7aabb1d1dc8b45bf6775c6d3c6ec73c72
https://github.com/PDAL/PDAL/commit/da2346f7aabb1d1dc8b45bf6775c6d3c6ec73c72
Author: Connor Manning <connormanning at users.noreply.github.com>
Changed paths:
M src/Stage.cpp
Log Message:
Merge pull request #1069 from PDAL/stream-ref
Commit: 5d078b1b550cd59917c890a4eb50e64d1a7bf7f2
https://github.com/PDAL/PDAL/commit/5d078b1b550cd59917c890a4eb50e64d1a7bf7f2
Date: 2015-12-12 (Sat, 12 Dec 2015)
Changed paths:
Log Message:
Initialize primitives.
Commit: 16c3063ba4492bc6c1567b4c2bfa78a6a46c0504
https://github.com/PDAL/PDAL/commit/16c3063ba4492bc6c1567b4c2bfa78a6a46c0504
Date: 2015-12-14 (Mon, 14 Dec 2015)
Changed paths:
M src/Stage.cpp
Log Message:
Streaming for crop filter.
Commit: 7c1a270645add5ef7f05c774dcd8618d01d538f4
https://github.com/PDAL/PDAL/commit/7c1a270645add5ef7f05c774dcd8618d01d538f4
Changed paths:
M src/Stage.cpp
Log Message:
Commit: 7d90671666b6c0f7eaf1503064344e63650ccc45
https://github.com/PDAL/PDAL/commit/7d90671666b6c0f7eaf1503064344e63650ccc45
Changed paths:
A test/data/ilvis2/ILVIS2_TEST_FILE.TXT
M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
Log Message:
Commit: 497ddabf6e940ddfb97f2f9be65ab4e6bef0a476
https://github.com/PDAL/PDAL/commit/497ddabf6e940ddfb97f2f9be65ab4e6bef0a476
Changed paths:
M filters/decimation/DecimationFilter.cpp
M filters/decimation/DecimationFilter.hpp
M test/unit/filters/DecimationFilterTest.cpp
Log Message:
Support streaming on the decimation filter.
Commit: 07d279a8acd24fad1916954123b1dca75b466059
https://github.com/PDAL/PDAL/commit/07d279a8acd24fad1916954123b1dca75b466059
Changed paths:
M filters/ferry/FerryFilter.cpp
M filters/ferry/FerryFilter.hpp
M test/unit/filters/FerryFilterTest.cpp
Log Message:
Add streaming to FerryFilter.
Commit: 031a4b688c42989bdb3b7f3e50675aad9e4df9ac
https://github.com/PDAL/PDAL/commit/031a4b688c42989bdb3b7f3e50675aad9e4df9ac
Changed paths:
Log Message:
Add stream test for RangeFilter.
Commit: 18f9338b0c7f7b23298013722ff132a055c01084
https://github.com/PDAL/PDAL/commit/18f9338b0c7f7b23298013722ff132a055c01084
Date: 2015-12-15 (Tue, 15 Dec 2015)
Changed paths:
M test/unit/filters/ReprojectionFilterTest.cpp
Log Message:
Streaming test for ReprojectionFilter.
Fix streaming for ReprojectionFilter.
Commit: 6d698abf01e7333659a31dec644efe46817f310c
https://github.com/PDAL/PDAL/commit/6d698abf01e7333659a31dec644efe46817f310c
Changed paths:
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
Streaming for StatsFilter.
Commit: 8deeeb78860f675dc0d0bc90f6bd1e3c4878b7cf
https://github.com/PDAL/PDAL/commit/8deeeb78860f675dc0d0bc90f6bd1e3c4878b7cf
Changed paths:
M src/Stage.cpp
Log Message:
Support multi-source streaming.
Commit: 68ffc95bd168cfe5b2fe4ab58eaad1917dd71f4e
https://github.com/PDAL/PDAL/commit/68ffc95bd168cfe5b2fe4ab58eaad1917dd71f4e
Date: 2015-12-16 (Wed, 16 Dec 2015)
Changed paths:
M filters/transformation/TransformationFilter.cpp
M filters/transformation/TransformationFilter.hpp
Log Message:
Streaming support for TransformationFilter.
Commit: 49e2eb9b67615c2a16dc084af8b405bc9755320c
https://github.com/PDAL/PDAL/commit/49e2eb9b67615c2a16dc084af8b405bc9755320c
Changed paths:
Log Message:
Return 'true' from processOne().
Commit: d7ffe3a37a841805f525b1268c5b5321ebdb667d
https://github.com/PDAL/PDAL/commit/d7ffe3a37a841805f525b1268c5b5321ebdb667d
Date: 2015-12-20 (Sun, 20 Dec 2015)
Changed paths:
M include/pdal/util/IStream.hpp
M io/gdal/GDALReader.cpp
M io/gdal/GDALReader.hpp
M src/GDALUtils.cpp
A test/data/png/autzen-height.png
R test/data/pointbuffer/metadata.txt
A test/unit/io/gdal/GDALReaderTest.cpp
Log Message:
Close BFP files between prepare/ready.
Open/close GDAL files on ready/done.
Add GDALReader test.
Handle setting of spatial reference from empty string.
Commit: d9f07a4121c41f7a61ef3c9ca8b23ea82186ac4b
https://github.com/PDAL/PDAL/commit/d9f07a4121c41f7a61ef3c9ca8b23ea82186ac4b
Changed paths:
M test/data/ilvis2/ILVIS2_TEST_FILE.TXT
Log Message:
Streaming support for ILVIS2.
Commit: 99487f22b31f79e9ac9a3b4ed3014a8b5cba6f30
https://github.com/PDAL/PDAL/commit/99487f22b31f79e9ac9a3b4ed3014a8b5cba6f30
Date: 2015-12-21 (Mon, 21 Dec 2015)
Changed paths:
M doc/stages/filters.crop.rst
M src/GDALUtils.cpp
Log Message:
Commit: d424c4b78ae504ba3606af2a81c014e5cfaaf421
https://github.com/PDAL/PDAL/commit/d424c4b78ae504ba3606af2a81c014e5cfaaf421
Changed paths:
M src/GDALUtils.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into reopen
Commit: 5d793b43f2d13810292f278bfffd84ae9d80e40b
https://github.com/PDAL/PDAL/commit/5d793b43f2d13810292f278bfffd84ae9d80e40b
Changed paths:
M kernels/random/RandomKernel.cpp
A test/unit/apps/RandomTest.cpp
Log Message:
Commit: fab4630312ed9b2a007f95bfb02e87776885180e
https://github.com/PDAL/PDAL/commit/fab4630312ed9b2a007f95bfb02e87776885180e
Changed paths:
Log Message:
Commit: 1684996ac5678b3a392093f7b9002de035bff38b
https://github.com/PDAL/PDAL/commit/1684996ac5678b3a392093f7b9002de035bff38b
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/stream' into reopen
Commit: b1ad778968aa1cb00d9308c783c5e358d4abcdfe
https://github.com/PDAL/PDAL/commit/b1ad778968aa1cb00d9308c783c5e358d4abcdfe
Date: 2015-12-22 (Tue, 22 Dec 2015)
Changed paths:
Log Message:
Multiple file opening for tindex.
Commit: 2bdb50fcf74f97081a9fac722804d6352eeccea8
https://github.com/PDAL/PDAL/commit/2bdb50fcf74f97081a9fac722804d6352eeccea8
Date: 2016-02-04 (Thu, 04 Feb 2016)
Changed paths:
Log Message:
Remove dead code.
Commit: 427bfd03b957aa55a238098a68dd2bb6cf862c61
https://github.com/PDAL/PDAL/commit/427bfd03b957aa55a238098a68dd2bb6cf862c61
Changed paths:
M CMakeLists.txt
M PDALConfig.cmake.in
M doc/contributors.rst
M python/pdal/Pipeline.cpp
M python/test/__init__.py
M python/test/test_libpdal.py
Log Message:
Commit: 10445fea95c74378a5dbfe636c06397419d52ecb
https://github.com/PDAL/PDAL/commit/10445fea95c74378a5dbfe636c06397419d52ecb
Changed paths:
M apps/pdal.cpp
M include/pdal/Kernel.hpp
A include/pdal/util/ProgramArgs.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.cpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/merge/MergeKernel.cpp
M kernels/merge/MergeKernel.hpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.cpp
M kernels/sort/SortKernel.hpp
M kernels/split/SplitKernel.cpp
M kernels/split/SplitKernel.hpp
M kernels/translate/TranslateKernel.cpp
M kernels/translate/TranslateKernel.hpp
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/kernel/Cpd.hpp
M plugins/pcl/kernel/GroundKernel.hpp
M plugins/pcl/kernel/HeightAboveGroundKernel.cpp
M plugins/pcl/kernel/HeightAboveGroundKernel.hpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/pcl/kernel/ViewKernel.cpp
M plugins/pcl/kernel/ViewKernel.hpp
M src/Kernel.cpp
M src/util/Utils.cpp
A test/unit/ProgramArgsTest.cpp
M test/unit/apps/MergeTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/apps/pcpipelineTest.cpp
Log Message:
ProgramArgs with tests.
Compare: https://github.com/PDAL/PDAL/compare/48e74a09a5b3...10445fea95c7
More information about the pdal-commits
