[pdal-commits] [PDAL/PDAL] 72e66e: add toGeoJSON to BOX2D
GitHub noreply at github.com
Tue Feb 9 15:37:17 PST 2016
  Branch: refs/heads/textreader
  Home:   https://github.com/PDAL/PDAL
  Commit: 72e66ed50e61a2b2a3e8496b23f81e8b8772b04d
      https://github.com/PDAL/PDAL/commit/72e66ed50e61a2b2a3e8496b23f81e8b8772b04d
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-02-05 (Fri, 05 Feb 2016)
  Changed paths:
    M include/pdal/util/Bounds.hpp
    M test/unit/BoundsTest.cpp
  Log Message:
  Commit: 628b6a8ba5979504be6a02ce68c58b172ca777f7
      https://github.com/PDAL/PDAL/commit/628b6a8ba5979504be6a02ce68c58b172ca777f7
  Changed paths:
    M include/pdal/Metadata.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/SpatialReference.hpp
    M src/CMakeLists.txt
    A src/Metadata.cpp
    M src/SpatialReference.cpp
    M test/unit/MetadataTest.cpp
  Log Message:
  pull SpatialReference include out of Metadata header so we can have SpatialReference::getAsMetadata() method
  Commit: 6d8784a9667880eed61f90c88a55ecae3a361948
      https://github.com/PDAL/PDAL/commit/6d8784a9667880eed61f90c88a55ecae3a361948
  Date:   2016-02-07 (Sun, 07 Feb 2016)
  Changed paths:
    M include/pdal/Polygon.hpp
    M src/Polygon.cpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Construct a Polygon from a BOX2D. Test using it to reproject BOX2D
  Commit: 85cb8f5b6fd85c1296d125094fe576716d29ad9f
      https://github.com/PDAL/PDAL/commit/85cb8f5b6fd85c1296d125094fe576716d29ad9f
  Date:   2016-02-08 (Mon, 08 Feb 2016)
  Changed paths:
  Log Message:
  need to export MetadataNodeImpl now that we're implementing setValue(SpatialReference) elsewhere
  Commit: 303e241b8e861fa7524097ccc0ad4e0a9c96c9c4
      https://github.com/PDAL/PDAL/commit/303e241b8e861fa7524097ccc0ad4e0a9c96c9c4
  Changed paths:
    M kernels/info/InfoKernel.cpp
    M src/Stage.cpp
  Log Message:
  add 'srs' metadata node
  Commit: 538e6dff6d5a8849f39dad9687077f84c9eb6249
      https://github.com/PDAL/PDAL/commit/538e6dff6d5a8849f39dad9687077f84c9eb6249
  Changed paths:
  Log Message:
  'Polygon' : ambiguous symbol thanks to 'Windows Kits\8.0\Include\um\wingdi.h(4972) : BOOL Polygon(HDC,const POINT *,int)'
  Commit: 0d930a915e36907b57ad64b6c57420a9f673ef4a
      https://github.com/PDAL/PDAL/commit/0d930a915e36907b57ad64b6c57420a9f673ef4a
  Changed paths:
    M src/GEOSUtils.cpp
  Log Message:
  remove debug lint
  Commit: 00a44fa6e31b74529c8a5cdc2609df5477de7d5f
      https://github.com/PDAL/PDAL/commit/00a44fa6e31b74529c8a5cdc2609df5477de7d5f
  Changed paths:
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M include/pdal/PDALUtils.hpp
    M src/Polygon.cpp
  Log Message:
  Add bbox output to filter.stats, which adds a lat/lon bbox convenience too #1080
  Commit: 1bb0522b2f2e8f3fb3d51bc8ed1410a9d391df27
      https://github.com/PDAL/PDAL/commit/1bb0522b2f2e8f3fb3d51bc8ed1410a9d391df27
  Changed paths:
  Log Message:
  export PDAL_DLL for setValue(SpatialReference&)
  Commit: 8f24711a1bdac494c6e0b6cfe6e511014f95051a
      https://github.com/PDAL/PDAL/commit/8f24711a1bdac494c6e0b6cfe6e511014f95051a
  Changed paths:
    M src/Stage.cpp
  Log Message:
  move toMetadata to Utils for SpatialReference, make sure to PDAL_DLL inferType
  Commit: 673674b63508f4b5a8d1a87da57bafeaa490970b
      https://github.com/PDAL/PDAL/commit/673674b63508f4b5a8d1a87da57bafeaa490970b
  Changed paths:
  Log Message:
  support fetching horizontal and vertical units for convenience #1089
  Commit: cfcc8f1a8d3670976221122985169ab19dac57a3
      https://github.com/PDAL/PDAL/commit/cfcc8f1a8d3670976221122985169ab19dac57a3
  Date:   2016-02-09 (Tue, 09 Feb 2016)
  Changed paths:
    M src/Polygon.cpp
  Log Message:
  output Z dimension for WKT when requested, use that for filter.stats box reprojection
  Commit: 7c9e0288e6a26067470ba76f16def43ceeac50ef
      https://github.com/PDAL/PDAL/commit/7c9e0288e6a26067470ba76f16def43ceeac50ef
  Changed paths:
    M doc/stages/readers.gdal.rst
    M include/pdal/GDALUtils.hpp
    M include/pdal/PipelineManager.hpp
    R include/pdal/PipelineReader.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/pipeline/PipelineKernel.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M python/pdal/Pipeline.cpp
    M python/pdal/Pipeline.hpp
    M src/GDALUtils.cpp
    M src/KernelSupport.cpp
    M src/PipelineManager.cpp
    M src/PipelineReader.cpp
    A src/PipelineReader.hpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  Merge branch 'master' into lat-lon-metadata
  Commit: 287b6c4196c980eef17d6395f3e922cbea6d1261
      https://github.com/PDAL/PDAL/commit/287b6c4196c980eef17d6395f3e922cbea6d1261
  Changed paths:
    M plugins/mrsid/test/MrsidTest.cpp
  Log Message:
  PipelineReader is gone
  Commit: 8690552b810c3e1d5b76631d9e59c4cb18032f17
      https://github.com/PDAL/PDAL/commit/8690552b810c3e1d5b76631d9e59c4cb18032f17
  Changed paths:
    M src/Polygon.cpp
    M test/unit/PolygonTest.cpp
  Log Message:
  remove BOX3D(BOX2D) constructor
  Commit: 0de42305a4bc8664d2d6c2eaa97243dbbd0fffd6
      https://github.com/PDAL/PDAL/commit/0de42305a4bc8664d2d6c2eaa97243dbbd0fffd6
  Changed paths:
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Merge pull request #1103 from PDAL/lat-lon-metadata
Output more convenient metadata for bbox and SRS
  Commit: f3012175ab969113377b41b797cce8e204dd7e05
      https://github.com/PDAL/PDAL/commit/f3012175ab969113377b41b797cce8e204dd7e05
  Changed paths:
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into textreader
Compare: https://github.com/PDAL/PDAL/compare/2e4b44070ccc...f3012175ab96
More information about the pdal-commits mailing list
