[pdal-commits] [PDAL/PDAL] 7e723f: Initial TextReader.
GitHub
noreply at github.com
Wed Feb 10 08:38:16 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 7e723fc8f43c5672def93116245105fc6cc29d40
https://github.com/PDAL/PDAL/commit/7e723fc8f43c5672def93116245105fc6cc29d40
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-02-04 (Thu, 04 Feb 2016)
Changed paths:
M include/pdal/util/Algorithm.hpp
M io/text/CMakeLists.txt
A io/text/TextReader.cpp
A io/text/TextReader.hpp
Log Message:
Initial TextReader.
Commit: cf9d949c3269c7122a2c7f632046be0987cc3f2e
https://github.com/PDAL/PDAL/commit/cf9d949c3269c7122a2c7f632046be0987cc3f2e
Date: 2016-02-05 (Fri, 05 Feb 2016)
Changed paths:
A doc/stages/readers.text.rst
M io/text/TextReader.cpp
M src/StageFactory.cpp
A test/data/text/utm17_1.txt
A test/data/text/utm17_2.txt
A test/data/text/utm17_3.txt
M test/unit/CMakeLists.txt
A test/unit/io/text/TextReaderTest.cpp
Log Message:
TextReader with doc and test.
Commit: 62b1d0e154e14c7181ee2bcf4342800a9a3930db
https://github.com/PDAL/PDAL/commit/62b1d0e154e14c7181ee2bcf4342800a9a3930db
Changed paths:
M io/text/TextReader.hpp
Log Message:
Add doxygen.
Commit: 94253c874fc9c6a8c8cf0ee5557deadbae4106d1
https://github.com/PDAL/PDAL/commit/94253c874fc9c6a8c8cf0ee5557deadbae4106d1
Author: Howard Butler <howard at hobu.co>
Date: 2016-02-09 (Tue, 09 Feb 2016)
Changed paths:
M CMakeLists.txt
M PDALConfig.cmake.in
M apps/pdal.cpp
M appveyor.yml
M doc/contributors.rst
M doc/stages/readers.gdal.rst
M doc/tutorial/index.rst
M examples/writing-kernel/MyKernel.cpp
M examples/writing-kernel/MyKernel.hpp
M examples/writing/tutorial.cpp
M include/pdal/GDALUtils.hpp
M include/pdal/Kernel.hpp
M include/pdal/PipelineManager.hpp
R include/pdal/PipelineReader.hpp
A include/pdal/util/ProgramArgs.hpp
M include/pdal/util/Utils.hpp
M io/ilvis2/Ilvis2Reader.cpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.cpp
M kernels/diff/DiffKernel.hpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/merge/MergeKernel.cpp
M kernels/merge/MergeKernel.hpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/pipeline/PipelineKernel.hpp
M kernels/random/RandomKernel.cpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.cpp
M kernels/sort/SortKernel.hpp
M kernels/split/SplitKernel.cpp
M kernels/split/SplitKernel.hpp
M kernels/tindex/TIndexKernel.cpp
M kernels/tindex/TIndexKernel.hpp
M kernels/translate/TranslateKernel.cpp
M kernels/translate/TranslateKernel.hpp
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/kernel/Cpd.hpp
M plugins/icebridge/test/IcebridgeReaderTest.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/GroundKernel.hpp
M plugins/pcl/kernel/HeightAboveGroundKernel.cpp
M plugins/pcl/kernel/HeightAboveGroundKernel.hpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/pcl/kernel/ViewKernel.cpp
M plugins/pcl/kernel/ViewKernel.hpp
M plugins/pcl/test/PCLBlockFilterTest.cpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M plugins/python/test/PredicateFilterTest.cpp
M plugins/python/test/ProgrammableFilterTest.cpp
M python/pdal/Pipeline.cpp
M python/pdal/Pipeline.hpp
M python/test/__init__.py
M python/test/test_libpdal.py
A scripts/appveyor/config.cmd
M scripts/appveyor/install.cmd
M scripts/ci/script.sh
M scripts/docker/dependencies/Dockerfile
M src/CMakeLists.txt
M src/GDALUtils.cpp
M src/Kernel.cpp
M src/KernelSupport.cpp
M src/PipelineManager.cpp
M src/PipelineReader.cpp
A src/PipelineReader.hpp
M src/util/Utils.cpp
A test/unit/ProgramArgsTest.cpp
M test/unit/apps/MergeTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/apps/pcpipelineTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/MergeTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
M test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
Log Message:
Merge branch 'master' into textreader
Commit: 2e4b44070cccfd9ff13170ee33ada488241065cf
https://github.com/PDAL/PDAL/commit/2e4b44070cccfd9ff13170ee33ada488241065cf
Changed paths:
M plugins/mrsid/test/MrsidTest.cpp
Log Message:
PipelineReader is gone
Commit: f3012175ab969113377b41b797cce8e204dd7e05
https://github.com/PDAL/PDAL/commit/f3012175ab969113377b41b797cce8e204dd7e05
Changed paths:
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M include/pdal/Metadata.hpp
M include/pdal/PDALUtils.hpp
M include/pdal/PointTable.hpp
M include/pdal/Polygon.hpp
M include/pdal/SpatialReference.hpp
M include/pdal/util/Bounds.hpp
M src/GEOSUtils.cpp
A src/Metadata.cpp
M src/Polygon.cpp
M src/SpatialReference.cpp
M src/Stage.cpp
M test/unit/BoundsTest.cpp
M test/unit/MetadataTest.cpp
M test/unit/PolygonTest.cpp
M test/unit/SpatialReferenceTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into textreader
Commit: a99b0ffe03c09aedde22b5f898dd4010bb686acd
https://github.com/PDAL/PDAL/commit/a99b0ffe03c09aedde22b5f898dd4010bb686acd
Date: 2016-02-10 (Wed, 10 Feb 2016)
Changed paths:
Log Message:
Merge pull request #1100 from PDAL/textreader
TextReader
Compare: https://github.com/PDAL/PDAL/compare/f08e79b4d2ee...a99b0ffe03c0
More information about the pdal-commits
