[pdal-commits] [PDAL/PDAL] d8b779: Fix logic for reading raster bands.
GitHub
noreply at github.com
Thu Feb 11 18:40:35 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d8b7790ea501e769b1cda78a3b4eb544f5522dcb
https://github.com/PDAL/PDAL/commit/d8b7790ea501e769b1cda78a3b4eb544f5522dcb
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-02-11 (Thu, 11 Feb 2016)
Changed paths:
M include/pdal/GDALUtils.hpp
M src/GDALUtils.cpp
Log Message:
Commit: 83db43e04cee1bdd1ebf968b6700b6776da91c2b
https://github.com/PDAL/PDAL/commit/83db43e04cee1bdd1ebf968b6700b6776da91c2b
Changed paths:
M doc/api/cpp/index.rst
A doc/api/cpp/programargs.rst
M doc/compilation/python.rst
M doc/stages/filters.height.rst
A doc/stages/readers.text.rst
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
M include/pdal/Metadata.hpp
M include/pdal/PDALUtils.hpp
M include/pdal/PipelineManager.hpp
R include/pdal/PipelineReader.hpp
M include/pdal/PointTable.hpp
M include/pdal/Polygon.hpp
M include/pdal/SpatialReference.hpp
M include/pdal/util/Algorithm.hpp
M include/pdal/util/Bounds.hpp
M io/derivative/DerivativeWriter.cpp
M io/ilvis2/Ilvis2Reader.cpp
M io/ilvis2/Ilvis2Reader.hpp
M io/text/CMakeLists.txt
A io/text/TextReader.cpp
A io/text/TextReader.hpp
M kernels/info/InfoKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/pipeline/PipelineKernel.hpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/icebridge/io/IcebridgeReader.hpp
M plugins/icebridge/test/IcebridgeReaderTest.cpp
M plugins/mrsid/test/MrsidTest.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/pcl/filters/HeightFilter.cpp
M plugins/pcl/filters/HeightFilter.hpp
M plugins/pcl/test/PCLBlockFilterTest.cpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/python/test/PredicateFilterTest.cpp
M plugins/python/test/ProgrammableFilterTest.cpp
M python/pdal/Pipeline.cpp
M python/pdal/Pipeline.hpp
M src/CMakeLists.txt
M src/GEOSUtils.cpp
M src/KernelSupport.cpp
A src/Metadata.cpp
M src/PipelineManager.cpp
M src/PipelineReader.cpp
A src/PipelineReader.hpp
M src/Polygon.cpp
M src/SpatialReference.cpp
M src/Stage.cpp
M src/StageFactory.cpp
A test/data/text/utm17_1.txt
A test/data/text/utm17_2.txt
A test/data/text/utm17_3.txt
M test/unit/BoundsTest.cpp
M test/unit/CMakeLists.txt
M test/unit/MetadataTest.cpp
M test/unit/PolygonTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/MergeTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
M test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
A test/unit/io/text/TextReaderTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/81c55937ed4e...83db43e04cee
More information about the pdal-commits
