[pdal-commits] [PDAL/PDAL] e41d19: Fix UB caused by incrementing pass-the-end iterato...
GitHub
noreply at github.com
Wed Feb 17 08:43:54 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: e41d193900cb1099d43b2f30d435e303f122cfd6
https://github.com/PDAL/PDAL/commit/e41d193900cb1099d43b2f30d435e303f122cfd6
Author: Mateusz Ĺoskot <mateusz at loskot.net>
Date: 2016-02-17 (Wed, 17 Feb 2016)
Changed paths:
M include/pdal/util/Utils.hpp
Log Message:
Fix UB caused by incrementing pass-the-end iterator
Iterator returned from std::find_if may point pass-the-end,
but incrementing pass-the-end iterator is an undefined behaviour.
The bug was revealed by stringsplit case of the OptionsTest,
as well as UtilsTest, where final std::find_if returns end
iterator which must not be incremented.
Commit: 37b3f35e75ef8fd52c66f789d6c1b35460a81bdf
https://github.com/PDAL/PDAL/commit/37b3f35e75ef8fd52c66f789d6c1b35460a81bdf
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
Log Message:
Merge pull request #1129 from mloskot/ml/fix-utils-split2-ub
Compare: https://github.com/PDAL/PDAL/compare/476ff90bbe65...37b3f35e75ef
More information about the pdal-commits
