[pdal-commits] [PDAL/PDAL] 6a78d9: Catch up with changes in pdal output.
GitHub
noreply at github.com
Wed Feb 17 17:07:45 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 6a78d9b469287caa5f62ce0089f2151302b1e15f
https://github.com/PDAL/PDAL/commit/6a78d9b469287caa5f62ce0089f2151302b1e15f
Author: Mateusz Ĺoskot <mateusz at loskot.net>
Date: 2016-02-18 (Thu, 18 Feb 2016)
Changed paths:
M test/unit/apps/pc2pcTest.cpp
Log Message:
Utils::run_shell_command uses popen which only
captures stdout, but pdal command outputs some
diagnostics to stderr too.
So, pc2pcTest case has been updated to redirect pdal
stderr to stdout to allow capturing expected output.
Commit: 8ba6b37c0574f916a2d9cca367600a36d13a8012
https://github.com/PDAL/PDAL/commit/8ba6b37c0574f916a2d9cca367600a36d13a8012
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-02-17 (Wed, 17 Feb 2016)
Changed paths:
Log Message:
Merge pull request #1136 from mloskot/ml/fix-test-pc2pc
Compare: https://github.com/PDAL/PDAL/compare/05d02b509bc5...8ba6b37c0574
More information about the pdal-commits
