[pdal-commits] [PDAL/PDAL] c28d2f: set SOVERSION for plugins too #1119
GitHub noreply at github.com
Thu Feb 25 07:56:30 PST 2016
  Branch: refs/heads/json-pipeline
  Home:   https://github.com/PDAL/PDAL
  Commit: c28d2fef75ed68ec2224ed6761c6b226791c0311
      https://github.com/PDAL/PDAL/commit/c28d2fef75ed68ec2224ed6761c6b226791c0311
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-02-23 (Tue, 23 Feb 2016)
  Changed paths:
    M cmake/macros.cmake
  Log Message:
  Commit: 865c3b6b58c72c7cc09ff4c18b80c35b8ac0f52e
      https://github.com/PDAL/PDAL/commit/865c3b6b58c72c7cc09ff4c18b80c35b8ac0f52e
  Changed paths:
    M plugins/pgpointcloud/io/PgWriter.cpp
  Log Message:
  Sequence query for writers.pgpointcloud incorrect #1101
  Commit: 37a74fae3be29d38e816e37f0a7aac17a3482f17
      https://github.com/PDAL/PDAL/commit/37a74fae3be29d38e816e37f0a7aac17a3482f17
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M src/PointView.cpp
  Log Message:
  Add windows extern qualifier.
  Commit: 6059c1a502da759e41ea8623333c2b203f530ba8
      https://github.com/PDAL/PDAL/commit/6059c1a502da759e41ea8623333c2b203f530ba8
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M include/pdal/PointView.hpp
    M src/PointView.cpp
  Log Message:
  Extern not needed, but refs to m_lastId must be in the source, not header
  Commit: 82514acc43bc97f92af2f85920114c40627093c6
      https://github.com/PDAL/PDAL/commit/82514acc43bc97f92af2f85920114c40627093c6
  Changed paths:
    M src/PointView.cpp
  Log Message:
  Merge pull request #1150 from PDAL/fix-m_lastId
  Commit: e9663f7a35c96bd267cb574663bebefe9e1da26b
      https://github.com/PDAL/PDAL/commit/e9663f7a35c96bd267cb574663bebefe9e1da26b
  Date:   2016-02-24 (Wed, 24 Feb 2016)
  Changed paths:
  Log Message:
  Merge pull request #1148 from PDAL/hobu/1101-pgpointcloud-seq
  Commit: c27c74aeb78948a04608d602113dddd527059fed
      https://github.com/PDAL/PDAL/commit/c27c74aeb78948a04608d602113dddd527059fed
  Changed paths:
  Log Message:
  Merge pull request #1145 from PDAL/plugin-versioning
  Commit: f7d53040532c3e2f9087a029a32664bfd305a819
      https://github.com/PDAL/PDAL/commit/f7d53040532c3e2f9087a029a32664bfd305a819
  Changed paths:
    M include/pdal/KernelSupport.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M src/KernelSupport.cpp
  Log Message:
  Set options on stages in info kernel in a more controlled way.
Close #1088
  Commit: 29df6fbe216ea64ad4f261306e68d8f33c0794e2
      https://github.com/PDAL/PDAL/commit/29df6fbe216ea64ad4f261306e68d8f33c0794e2
  Changed paths:
    M cmake/unix_compiler_options.cmake
  Log Message:
  remove -Werror for now
  Commit: 617dc1257466a85d470c7f2f2e9002cabdf9ba6b
      https://github.com/PDAL/PDAL/commit/617dc1257466a85d470c7f2f2e9002cabdf9ba6b
  Changed paths:
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 5a21f1947c829ccb3a6b70c8af159f672d617b24
      https://github.com/PDAL/PDAL/commit/5a21f1947c829ccb3a6b70c8af159f672d617b24
  Changed paths:
    M apps/pdal.pc.in
  Log Message:
  install pkgconfig script into CMAKE_INSTALL_LIBDIR #1151
  Commit: b0f5d4eba95da7f6417e43f92d1e938d6151df2a
      https://github.com/PDAL/PDAL/commit/b0f5d4eba95da7f6417e43f92d1e938d6151df2a
  Author: Mateusz Łoskot <mateusz at loskot.net>
  Changed paths:
    M include/pdal/pdal_macros.hpp
  Log Message:
  Move PluginInfo out of anonymous namespace.
Since PluginInfo is public type, move to pdal namespace.
  Commit: 51987c9c7a50a52dfb7ac1929af97296952bc7c0
      https://github.com/PDAL/PDAL/commit/51987c9c7a50a52dfb7ac1929af97296952bc7c0
  Changed paths:
  Log Message:
  Merge pull request #1153 from mloskot/ml/plugininfo-to-pdal
  Commit: 4371daff6e19b2599ec495b8e822046c71376673
      https://github.com/PDAL/PDAL/commit/4371daff6e19b2599ec495b8e822046c71376673
  Changed paths:
    M apps/pdal.pc.in
  Log Message:
  Merge pull request #1152 from PDAL/pkgconfig-updates
  Commit: 83647b5f6959bc4042e3e22c7df9f7dc58a87f74
      https://github.com/PDAL/PDAL/commit/83647b5f6959bc4042e3e22c7df9f7dc58a87f74
  Changed paths:
    M appveyor.yml
    M scripts/appveyor/config.cmd
  Log Message:
  Switch AppVeyor to Visual Studio 2015
  Commit: 172102fb0e9ca365facc66478d5303436c0d0c99
      https://github.com/PDAL/PDAL/commit/172102fb0e9ca365facc66478d5303436c0d0c99
  Changed paths:
    M io/las/GeotiffSupport.cpp
    M io/las/GeotiffSupport.hpp
    M io/las/LasReader.cpp
  Log Message:
  Detect gross error in GeoTiff record.
  Commit: b48ea0b4c983e2a9591129a1a2ae7064feec18e6
      https://github.com/PDAL/PDAL/commit/b48ea0b4c983e2a9591129a1a2ae7064feec18e6
  Changed paths:
    M apps/pdal.pc.in
    M appveyor.yml
    M src/PointView.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 7052973bf512db3062bba5816e584538a429b101
      https://github.com/PDAL/PDAL/commit/7052973bf512db3062bba5816e584538a429b101
  Changed paths:
    M include/pdal/SpatialReference.hpp
    M include/pdal/Stage.hpp
    M src/Stage.cpp
  Log Message:
  Doxygen.
  Commit: 18ccea2dd8bfa9bb99d08fefd9d1dbde6bb8d4dc
      https://github.com/PDAL/PDAL/commit/18ccea2dd8bfa9bb99d08fefd9d1dbde6bb8d4dc
  Changed paths:
    M io/las/LasReader.hpp
    M plugins/nitf/io/NitfReader.hpp
  Log Message:
  Create structure to manage LAS file interface.
  Commit: d242c6704aafe85fd49fda11adae63d07ce11b76
      https://github.com/PDAL/PDAL/commit/d242c6704aafe85fd49fda11adae63d07ce11b76
  Changed paths:
  Log Message:
  Commit: 930d1f810e57aea75cc3fb43a016dea6a46acd9c
      https://github.com/PDAL/PDAL/commit/930d1f810e57aea75cc3fb43a016dea6a46acd9c
  Changed paths:
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Replace EXPECT_TRUE with EXPECT_EQ
EXPECT_EQ allows to report actual values that are being
compared.
  Commit: d048d2e300f38a2d22821c11c2dfa7275f0c540f
      https://github.com/PDAL/PDAL/commit/d048d2e300f38a2d22821c11c2dfa7275f0c540f
  Changed paths:
  Log Message:
  Merge pull request #1155 from mloskot/ml/srstest-use-expect-eq
  Commit: 959984d2b0c5545986528596b24a95c1402a2a13
      https://github.com/PDAL/PDAL/commit/959984d2b0c5545986528596b24a95c1402a2a13
  Changed paths:
    M examples/writing-kernel/MyKernel.cpp
    M include/pdal/Kernel.hpp
    R include/pdal/KernelSupport.hpp
    M kernels/merge/MergeKernel.cpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/test/CpdKernelTest.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/HeightAboveGroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M src/CMakeLists.txt
    M src/Kernel.cpp
    R src/KernelSupport.cpp
  Log Message:
  Remove KernelSupport.
Fix InfoKernel reader initialization.
  Commit: f9608b760e67b28d9228dcd38d31e482250271f9
      https://github.com/PDAL/PDAL/commit/f9608b760e67b28d9228dcd38d31e482250271f9
  Changed paths:
  Log Message:
  Commit: e045882a31dba31cfec4ef92a6aba8663348eddb
      https://github.com/PDAL/PDAL/commit/e045882a31dba31cfec4ef92a6aba8663348eddb
  Changed paths:
    M test/unit/CMakeLists.txt
    A test/unit/PluginManagerTest.cpp
  Log Message:
  Add test for PluginManager.
Test the manager basics.
Test a plugin registration at run-time which, after
static and shared, is a third way to register plugins with PDAL.
  Commit: 4e510e91cc2694ac8614707d50303143a2ff272f
      https://github.com/PDAL/PDAL/commit/4e510e91cc2694ac8614707d50303143a2ff272f
  Changed paths:
    M README.md
  Log Message:
  Nudge AppVeyor
  Commit: de3a8c379061e08420eb3cdd08780f4f1df36441
      https://github.com/PDAL/PDAL/commit/de3a8c379061e08420eb3cdd08780f4f1df36441
  Changed paths:
  Log Message:
  Merge pull request #1156 from mloskot/ml/plugin-manager-test
  Commit: 1642ca424bfe839db46aea06879af887d0320a4f
      https://github.com/PDAL/PDAL/commit/1642ca424bfe839db46aea06879af887d0320a4f
  Date:   2016-02-25 (Thu, 25 Feb 2016)
  Changed paths:
    M appveyor.yml
  Log Message:
  Remove (some) OSGeo4W hacks as no longer required on AppVeyor.
Following OSGeo4W fixes https://trac.osgeo.org/osgeo4w/ticket/485
* Add -k to auto-confirm license selection (e.g. szip)
* Remove szip manual deployment.
Prefer PowerShell DownloadFile cmdlet instead of wget.
Remove cache as never feasible due to archive size >100MB.
  Commit: fda4a12ee975f61b0328443c576071289046aebb
      https://github.com/PDAL/PDAL/commit/fda4a12ee975f61b0328443c576071289046aebb
  Changed paths:
    M appveyor.yml
  Log Message:
  Remove on_finish enabling RDP connectivity
  Commit: a600b4189771292a0898cd6b750d1dd5e3d46e0f
      https://github.com/PDAL/PDAL/commit/a600b4189771292a0898cd6b750d1dd5e3d46e0f
  Changed paths:
    M apps/CMakeLists.txt
  Log Message:
  install pdal.pc pkgconfig in CMAKE_INSTALL_LIBDIR
  Commit: fbf258b20cad3f2da851318dc97655d97e26fde0
      https://github.com/PDAL/PDAL/commit/fbf258b20cad3f2da851318dc97655d97e26fde0
  Changed paths:
    M CMakeLists.txt
  Log Message:
  more CMAKE_INSTALL_LIBDIR tweaks
  Commit: bdf57a19d876440bb921d35daa1de735a85b6f78
      https://github.com/PDAL/PDAL/commit/bdf57a19d876440bb921d35daa1de735a85b6f78
  Changed paths:
    M appveyor.yml
  Log Message:
  Enable shallow clones on AppVeyor
  Commit: 6a62fda5ccb8da67cced2933b26183220646383a
      https://github.com/PDAL/PDAL/commit/6a62fda5ccb8da67cced2933b26183220646383a
  Changed paths:
    M src/PipelineReader.hpp
    M src/PipelineWriter.cpp
    M src/Stage.cpp
  Log Message:
  Move boost/property_tree/ptree.hpp where it is actually needed.
Add missing <iterator> for std::back_inserter.
  Commit: 1e73738cf126da24e62546e7b54c8372fb82c98f
      https://github.com/PDAL/PDAL/commit/1e73738cf126da24e62546e7b54c8372fb82c98f
  Changed paths:
    M include/pdal/Metadata.hpp
  Log Message:
  address #1157 -- invalid JSON output due to \r\n
  Commit: 3ac6c94c99db1bfa924246d635adfd4bcc0fa9d3
      https://github.com/PDAL/PDAL/commit/3ac6c94c99db1bfa924246d635adfd4bcc0fa9d3
  Changed paths:
    M CMakeLists.txt
  Log Message:
  use PDAL_LIB_INSTALL_DIR instead of CMAKE_INSTALL_LIBDIR
  Commit: 117eeb828f3c051a011e8fdb0e2ba11ee7d5042d
      https://github.com/PDAL/PDAL/commit/117eeb828f3c051a011e8fdb0e2ba11ee7d5042d
  Changed paths:
    M appveyor.yml
  Log Message:
  Commit: 400c02aa5453a4c65d686c96c3461eb51a98a717
      https://github.com/PDAL/PDAL/commit/400c02aa5453a4c65d686c96c3461eb51a98a717
  Changed paths:
    M src/Stage.cpp
  Log Message:
  Merge pull request #1159 from mloskot/ml/ptree-includes-cleanup
  Commit: 286bc97034ce2fc16e339ae6dcd4eb9aeb2aa4bb
      https://github.com/PDAL/PDAL/commit/286bc97034ce2fc16e339ae6dcd4eb9aeb2aa4bb
  Changed paths:
    M appveyor.yml
  Log Message:
  try using webhook instead of app for slack notifications
  Commit: 8b91f286a842e1315dd3f267566997d09d934cf7
      https://github.com/PDAL/PDAL/commit/8b91f286a842e1315dd3f267566997d09d934cf7
  Changed paths:
    M CMakeLists.txt
  Log Message:
  one more PDAL_LIB_INSTALL_DIR fix
  Commit: d0c1220943b299c0c553f45b1e289d04ab115183
      https://github.com/PDAL/PDAL/commit/d0c1220943b299c0c553f45b1e289d04ab115183
  Changed paths:
    M appveyor.yml
  Log Message:
  typo'd incoming_webhook defn
  Commit: 0884085967888a7cd344604c35c9666351243c62
      https://github.com/PDAL/PDAL/commit/0884085967888a7cd344604c35c9666351243c62
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge remote-tracking branch 'origin/master' into appveyor-webhook
  Commit: da6de0fdd98632f99530549447944f8ca9175d47
      https://github.com/PDAL/PDAL/commit/da6de0fdd98632f99530549447944f8ca9175d47
  Changed paths:
    M CMakeLists.txt
    M README.md
    M apps/pdal.pc.in
    M appveyor.yml
    M src/Kernel.cpp
    M src/PointView.cpp
    M src/Stage.cpp
  Log Message:
  Catch up to master
Compare: https://github.com/PDAL/PDAL/compare/6841f4c127d2...da6de0fdd986
More information about the pdal-commits mailing list
